Help !! don't wanna CEL with new Midpipe???
Old Jun 19, 2009 | 08:43 AM
realBlackSunshine's Avatar
SC Help !! don't wanna CEL with new Midpipe???
Just bought a new mid-pipe cat delete no RES, from a member here . now how do I avoid a Cel . I know I have seen a DIY for this but can't find it, I need to put a spacer in for my O2 sensor ............plaese help???
Old Jun 19, 2009 | 10:55 AM
dmp's Avatar
dmp
RX8 and a Truk....
try this
http://www.scoobymods.com/rear_o2_se...68.html?t=5468
Old Jun 19, 2009 | 11:02 AM
dozer's Avatar
on his 3rd rx8
for some reason my CEL went off a couple of weeks ago and hasnt returned...
Old Jun 19, 2009 | 03:35 PM
04RX8man's Avatar
Rotary Powered Countryboy
Accessport!
Old Jun 19, 2009 | 03:55 PM
^^ Basically The CEL will be there cause there is no CAT
...deal with it...or mask it with the Accessport
The other options usually don't work...so don't waste your money
Old Jun 19, 2009 | 04:15 PM
dozer's Avatar
on his 3rd rx8
or you MIGHT get lucky like me and the CEL will accidentally turn off
Old Sep 24, 2009 | 01:55 AM
jessedrifter's Avatar
so cal
theres no way just to clear the code? foreverrr
Old Sep 24, 2009 | 02:06 AM
Jon316G's Avatar
Grasshopper
Nope.
Buy an AccessPort or use black electrical tape to cover it and you'll never see it
Old Sep 24, 2009 | 05:33 AM
@!!narotordo's Avatar
FLAME ON!
What about removing the vfad. I did that and caped it and my cel has not come back on.
Old Sep 24, 2009 | 05:54 AM
Jon316G's Avatar
Grasshopper
What does that have to do with the O2 sensor?
Old Sep 24, 2009 | 06:09 AM
DarthRX8's Avatar
Force User
The Accessport can mask a CEL?
Haha, beat Laythor and Flashwing!
Old Sep 24, 2009 | 07:14 AM
40thrx8whynot's Avatar
dose tape really work ?
Old Sep 24, 2009 | 07:20 AM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
well, instead of the Check engine light on your dash, you have electrical tape. . . the light is still on, you just have tape over it so you can't see it. . . I can write a DIY if you'd like?
Old Sep 24, 2009 | 07:43 AM
just kill yourself, now .....
Old Sep 24, 2009 | 07:45 AM
Yeah without the Access port it will stay regardless of what you do.
Old Sep 24, 2009 | 08:36 AM
Vyndictive's Avatar
wow, that's a tad harsh, even for the RX8club!
Old Sep 24, 2009 | 02:43 PM
Jon316G's Avatar
Grasshopper
I actually thought that was pretty funny.
Old Sep 24, 2009 | 02:57 PM
Spoolin8's Avatar
The back o2 sensor is just for making sure the cat is in good condition right? I know our cars have a wideband setup and i want to make sure that its not the same sensor, because if you use the spark plug trick and that sensor is the wideband one then your messing with the readings and fuel injection.
Old Sep 24, 2009 | 04:23 PM
Jon316G's Avatar
Grasshopper
Originally Posted by Spoolin8
... because if you use the spark plug trick...
Let us know how that "trick" works out for you
gwailo
May 14, 2024 06:57 AM
tgaffner
Aug 20, 2015 10:55 AM
yapakanichi
16
Jul 28, 2015 03:44 PM
dbarber
Jul 25, 2015 01:34 PM
Jvswan
28
Jul 23, 2015 09:02 AM
