Go Back   RX8Club.com > General Topics > General Automotive
Old 06-15-2009, 10:57 PM   #1
9krpmrx8
Crazy Cone Chaser
Trader Score: (7)
Send a message via MSN to 9krpmrx8 Send a message via Yahoo to 9krpmrx8 Send a message via Skype™ to 9krpmrx8
TX How does this tranny work?
Honda+NSX+GT1+Onboard+%2c+650+HP
Some times he uses the clutch and some times he does not. Enlighten me please.
9krpmrx8 is offline   Reply With Quote
Old 06-15-2009, 11:11 PM   #2
8 Maniac
8 Maniac's Avatar
I haven't watched yet, but you can shift without using the clutch in our car as well. I've done it a couple times, but I'm can never get it as smooth as with using the clutch. It pops out of gear with ease as soon as you let off the throttle but it's a bit more difficult timing wise to get back in gear.
and edit for after watching... It's a sequential gearbox and only needs clutch on down shifts.
here's a decent explanation http://en.wikipedia.org/wiki/Sequent...l_transmission
8 Maniac is offline   Reply With Quote
Old 06-16-2009, 02:59 PM   #3
philipchan
philipchan's Avatar
That's call DOT gear
You will need the clutch for down shift
up/push is down shift, down/pull us up shift
Because the gear gap is huge(due to high HP and need biggie and stronger gears),
you just need to pull the gear to up shift without punching the clutch
But that tranny sounds even louder than the engine tho =_=
Take a good look of the video, only use the clutch for down shifting
The DOT gear is so popular now, cost a lot less compare to the tiptronic one's
The RX-8 in Rolax, they use tiptronic tranny, it cost over $10k each
philipchan is offline   Reply With Quote
Old 06-16-2009, 03:47 PM   #4
9krpmrx8
Crazy Cone Chaser
Trader Score: (7)
Cool, thanks. That car has no lag what so ever.
Hand brake doesn't fully work work Interpol Wheels, Tires, Brakes & Suspension 5 09-25-2008 11:52 PM
Need Tranny work in S. FL magikone69 SE RX-8 Forum 7 08-16-2008 02:20 PM
Warranty Work - Rebuilt Tranny - Rotors - Brakes O MY!!! SilverHokie RX-8 Discussion 7 05-03-2008 06:14 PM
Which grease do you use for tranny work ? nycgps The Tech Garage 24 01-08-2008 07:00 AM
race tranny or built tranny intakedrotary Aftermarket Performance Modifications 6 01-24-2005 11:26 AM
