strut bar removal
Old Dec 29, 2003 | 02:52 PM
cardinal35's Avatar
Thumbs up strut bar removal
Does anyone know if the strut bar in the engine bay is attached with some kind of threadlock on the bolts? and if I remove it will I need to get more thread lock to put it back on?
Old Dec 29, 2003 | 03:11 PM
mikeb's Avatar
100% Italian
no, you can remove it easily
its just two bolts on each side
Old Dec 29, 2003 | 03:15 PM
cardinal35's Avatar
thank you I was afraid to try and then screw up something- I really doubt these things can drive without one
Old Dec 29, 2003 | 07:04 PM
wakeech's Avatar
mostly harmless
...why would you say that?
Old Dec 29, 2003 | 09:44 PM
syntrix's Avatar
I like cheese!
If I remember correctly, it's a 12mm nut.
13-19.5 ft-lbs
Old Dec 30, 2003 | 07:37 AM
Samyv's Avatar
If your looking to replace it you should check out the thread titled thanks under the Canadian forum. You will find a picture of a Triangular strut bar from cpracing. I had the mod installed on my car--what a difference in handling. You can order one at cpracing.ca. It's easy to install.
Old Dec 30, 2003 | 07:45 AM
cardinal35's Avatar
"...why would you say that?" .......being winter-I don't need even the most minute loss of control
Old Dec 30, 2003 | 09:10 AM
wakeech's Avatar
mostly harmless
oh, it's just an ancillary structural peice, which benefits your suspension under only the heaviest load. so, in winter especially (with the low speeds everywhere), it's not a big deal if you had to leave it off
Old Dec 30, 2003 | 09:44 AM
cardinal35's Avatar
wakeech- thanks! I was worried about getting my timing right to get it back on before I drove it to work- now I am in the cool- thanx for the response- your advice is always heeded with the upmost respect
RX-8 Racing
20
May 14, 2016 06:25 PM
Racingjunkie
Sep 29, 2015 05:05 PM
xAgyex
Sep 28, 2015 08:54 AM
Learners_Permit
Sep 27, 2015 07:38 PM
