help please!!! just installed AEM CAI
Old May 12, 2009 | 08:58 PM
NACer4lyf's Avatar
oh yeah!
ok had no problems installing the intake. i looked at the directions somewhat but it was pretty straight forward.
my question is. i plugged up the three hoses before the MAF does it matter which hose goes on which plug? i just put them on whichever fit the best.
second question. (i know i should have pics but ill take em in the morning) i plugged the MAF in and there is a connector just hanging there and also there was like 3 other hoses/connectors that didnt have anywhere to be put what do i do with these? right now there are just laying in there
i took there car for a drive it sounded good i like it no check engine lights but after the car was fully warmed up and everything i would drive to about 6k 6.5k and it would lag a little and when i shifted it acted like it had a hard time catching back up...you know what i mean idk how to explain it though.
is this normal? kinda worried me
what do i do w/ the excess hoses and loose stuff hanging around? because there is one part that is really small opening its a hose but really small i placed my finger over it w/ engine running and it was sucking in air.
i just dont know what the next step to do.
help me out guys...hope this was explained good enough and also i apologize for not having pics to refer to.
Old May 12, 2009 | 09:05 PM
jjc3925's Avatar
u should have ONE connecter just chillin
and you should have ONE hose just chillin....its the thin hose that goes to thee throttle body i believe...you just gotta plug the end of it.
as far as the order of the 3 hoses i dont really think it matters....but i plugged them the same exact as stock.
Old May 12, 2009 | 09:07 PM
NACer4lyf's Avatar
oh yeah!
oh ok. well i had a couple i think just chillin and i plugged them in to make one long one i guess with a small opening at the end should i put something over it so its not to suck up dirt. my dad said i should shorten the hoses and mount them and stuff but i was like uhh damn that sounds like a lot of work haha
Old May 12, 2009 | 09:11 PM
myriadshalaks's Avatar
rot8ing
probably just need to let the computer re-adjust.
i plugged my hoses back up the same as stock too. i don't see how it would matter though.
the other connector goes to the secondary vacuum on your stock intake which you removed. it now goes no where. tape it back.
i just had a thread going through the same thing.
it's fun to install stuff. enjoy it!
Old May 12, 2009 | 09:12 PM
rot8ing
i shortened the hoses too.
i don't recommend plugging things in where they don't belong.
Old May 12, 2009 | 09:13 PM
NACer4lyf's Avatar
oh yeah!
^ +1 i actually had a blast doing it. ok so best thing to do is just tape it back or get it out of the way some how. what about that little vacuum hose. did you put a cap on it or anything?
Old May 12, 2009 | 09:14 PM
rot8ing
you can remove all that vacuum stuff. it goes nowhere.
Old May 12, 2009 | 09:15 PM
rot8ing
and make sure you cap the vacuum inlet on the throttle body. it should have been very difficult, so you would remember doing it.
not doing that might explain your lack of power.
Old May 12, 2009 | 09:16 PM
jjc3925's Avatar
yea i believe its a green connector right?? that one just fasten to the side somewhere...and the lil thin hose you want to plug...
you did plug the MAF back in right??
Old May 12, 2009 | 09:18 PM
NACer4lyf's Avatar
oh yeah!
yeah i did plug that back in
and that little green part your talking about its like white/green right? how do i cap that?
Old May 12, 2009 | 09:20 PM
Jon316G's Avatar
Grasshopper
The green/white is probably the one-way valve.
He is talking about the green wire harness that plugs into the solenoid.
Just cap the nipple behind the throttle body and remove the whole VFAD assembly.
Old May 12, 2009 | 09:21 PM
rot8ing
no, he was talking about the green connecor we've been saying to ape back. it's in the wire bundle with the maf.
you said there was still vacuum tubing in your bay. that should be disconnected at the throttle body and removed.
and the inlet on the throttle body that you pull the hose from should be CAPPed. there should have been a very small cap in your kit. it goes there.
Old May 12, 2009 | 09:23 PM
NACer4lyf's Avatar
oh yeah!
hmm i got it used but there is a little rubber cap laying on my garage floor i bet that would work lol.
damn
ill take pictures tomorrow because some of this stuff is going over my head lol sorry
so basically all the excess hoses i just take off?
Old May 12, 2009 | 09:24 PM
NACer4lyf's Avatar
oh yeah!
ok wont that throw a check engine light? and where exactly is the VFAD can you explain that a little more
Old May 12, 2009 | 09:25 PM
Jon316G's Avatar
Grasshopper
As long as you cap the nipple behind the throttle body, you won't get a CEL.
Let me dig-up some pics I posted in other threads showing the assembly.
Old May 12, 2009 | 09:27 PM
rot8ing
you can do this.
the the throttle body is the metal thing your cai is connected to.
on the bottom side of it, there's a nipple, an inlet. it probably has one end of your vacuum hose connected to it.
remove the hose and cap it. it's going to be hard. but keep at it.
all of the hose can be removed. the screws that hold it down, the mounts, the connectors, everything, all the way to the front of your car.
that's it.
NACer4lyf's Avatar
oh yeah!
ok thanks man that will help out a lot!!!!
Old May 12, 2009 | 09:28 PM
NACer4lyf's Avatar
oh yeah!
Originally Posted by myriadshalaks
you can do this.
that's it.
ok can this be done w/out take the intake back out? id really rather not lol and whats the best thing to use for capping it?
rot8ing
and don't drive it before capping the inlet again. you don't want unfiltered particles going directly into the throttle body.
Old May 12, 2009 | 09:29 PM
rot8ing
you probably will need to remove the strut bar if you've put that back on.
be careful not to strip the nuts.
NACer4lyf's Avatar
oh yeah!
dang ok lol thanks for the heads up on that though i didnt feel quite right driving it w/out exactly knowing or not lol
Old May 12, 2009 | 09:30 PM
Jon316G's Avatar
Grasshopper
VFAD assembly is everything with a dash-line outline:
NACer4lyf's Avatar
oh yeah!
haha ok i tried once already to take that baby off...lets just say i worked around that lol but ill try again haha
Old May 12, 2009 | 09:31 PM
NACer4lyf's Avatar
oh yeah!
ah ok what do you recomend using to cap it off?
Old May 12, 2009 | 09:32 PM
Jon316G's Avatar
Grasshopper
If you weren't given one, go to Autozone and buy a variety pack of vacuum caps.
Its only a couple bucks.
Then use the size that fits snug.
