Help with wiring and custom switches
Old May 12, 2009 | 01:31 AM
wyldechild's Avatar
Hi, I was hoping some one could point me in the direction of a previous thread or help me themselves. I've searched too... Well I'm planning on putting some toggle switches where the ashtray is in order to control the footwell LEDS. I just want to start with the footwell LEDS but will move onto adding underbody neons and etc. So if anyone can tell me how to wire the footwell LEDS (rx8strakes.com) to the ashtray area in order to use toggle switches for on and off functions that would be great. Thank you very much fellow RX8club members.
Old May 12, 2009 | 02:05 AM
laythor's Avatar
I zoom therefore I am.
since you're using the ashtray might as well use the cigarette lighter wires for power. there isnt really any need for a thread or how to since it's just splice wire to wire and you're done.
Old May 12, 2009 | 10:20 AM
Socket7's Avatar
ಠ_ಠ
Follow the install instructions for the footwell kit, only wire a switch into the circuit, and instead of tapping the courtesy lights, tap into a 12V source.
If you wanted to get really fancy, you could use a relay wired to a distribution block, and then turn everything wired to the block on and off by the switch connected to the relay.
wyldechild's Avatar
ok thanks a lot
Old May 12, 2009 | 11:00 AM
L337fpc's Avatar
ლ(ಠ益ಠლ)
I used the free area in the stereo for my interior and exterior led switches. It is the plate that covers the Tape/MD area.
I also just used a 12v plug to power the LEDs. It was like $3 @ pepboys. Plus I always have the ashtray closed, so you can't see the plug.
I followed this DIY: Custom Switched
Old May 17, 2009 | 02:13 AM
wyldechild's Avatar
ya but I plan on using the ashtray area for where the switches will go. so that way they're easily visible and easily accessible from shifter.
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
Brokegang
Jan 3, 2016 12:45 PM
stickmantijuana
Rotary Swaps
11
Sep 24, 2015 12:47 AM
stickmantijuana
Non-Rotary Swaps
Sep 19, 2015 03:15 PM
