Bridgeport RX8
Old May 5, 2009 | 03:25 PM
Philip_SA's Avatar
Rotary lover
Bridgeport RX8
Hi
All have been waiting for a bridgeport RX8,
Mine was just done and drivin today, still being run in,
i will collect in tomorrow.
I will let all know more in few days on what it feels like,
one thing so far no CELs,
we made a bridge at the primary and secondarys, we made the primarys a bit bigger and made the exhaust ports open a bit earlier and cleaned all up a bit
Cat was removed (long ago already) and box at back changed to 2 small units
It sounds excellent and i will as soon as it is running well, run in, post some clips
So far all fine
brap brap brap
Old May 5, 2009 | 03:41 PM
cfm251's Avatar
sweet! update soon cant wait to hear it. Maybe a dyno??? sometime in the future???
Old May 5, 2009 | 03:50 PM
rx8shift's Avatar
Cant wait to hear more of your impressions see actual HP and TQ numbers from this mod. Keep us posted
Old May 5, 2009 | 04:06 PM
fastlaneracing's Avatar
Rotor User
I will take a guess, 260 fwhp =)
Old May 5, 2009 | 04:14 PM
rotarygod's Avatar
Since a stock port Renesis can do that when tuned very well, I'd say that's a decent guess.
Old May 5, 2009 | 04:25 PM
Easy_E1's Avatar
I'd like to see some pics of the ports.
Old May 5, 2009 | 04:30 PM
I8U's Avatar
I8U
^+1, also some video.
Nemesis8's Avatar
Bigus Rotus
Cool - new territory discovered. Wonder how he tuned it?
Old May 5, 2009 | 08:58 PM
05rex8's Avatar
sold the 8... :(
oh I need sounds clips/vids please!
Old May 5, 2009 | 09:00 PM
chancejat's Avatar
Drive it like u stole it!
dyno or it didnt happen
Old May 6, 2009 | 01:36 PM
Philip_SA's Avatar
Rotary lover
Pics and clips to follow
Hi All
Yes i will send some video clips, i have one i made but it is 8meg,
wil make some more and post,
at the moment i am still running in, only did approx 100miles so far and not going over 4000rpm, but i can feel there is power,
i battle a small bit with the idling as the std ecu wants to let it idle at approx 750 -800rpm, but it even goes down to 700 and then wants to die, for now until run in (as idling etc might change when a bit more loose, they made a bracket at the pedal, adjustable with screw and locknut, it works fine, now idles like a real bridgy at 1200-1300 rpm.
I am not that often on the site due to not at office a lot, but will try to go on everyday.
On port pictures, i wanted to take once but they werent finished, when i wanted to take they were closed already, but i did see enough, the ports were al made as i think what RG said about the intake opening earlier and primary a bit bigger, cleaning up and rounding to help side seal issue, the bridges was made at primary and secondary (not the high rpm ports, although they did do it there, it was decided to leave due to not so easy with the tube on inside.) the bridge is approx 5mm wide (the port of it) and running the length of the port itself.
I hope to send clips in day or two,
what is the best, to put on Youtube?
And yes i will dyno later, much later, this was supposed to be a rebuild as 2 of my side seals broke as well as the corner seal inbetween, at 208 000km (130 000miles) thus not bad,
due to it being open we went for it as i experiment, so far the std ecu manages
Will keep up to date
Philip
Old May 6, 2009 | 01:43 PM
Philip_SA's Avatar
Rotary lover
tuning
We didnt change anything on tuning yet as first want to run it in,
it wasnt that big extra porting and we worked out that std injectors would be sufficient anyway, we will see how it goes in weeks time after run in,
we will check all to be sure it is not too lean, but a head technician at mazda on RX8s (in South Africa) said the ecu will see if it needs more fuel to std curve, we might not get best power now, but still more than std, with aftermarket ecu, will be big change, at least it wont run too lean.
i must say the throttle respons is better and feels better than std already, even when running to only 4000rpm for now,
will push to 5000rpm in day
just too scared for damages
Philip
Old May 6, 2009 | 02:08 PM
rotarygod's Avatar
It's scary but someone has to do it! When I said you can't bridge a Renesis, I was referring to the exhaust ports. The intake ports do make me nervous though as that would have to be a pretty thin bridge or a very small eyebrow port.
Old May 6, 2009 | 03:07 PM
Philip_SA's Avatar
Rotary lover
Your right,
the bridge is very thin, but luckily enough flesh downwards into port (or depth) and not so long,
i was also very scared at the part where the corner seal runs on, but they tested all before assembling to make sure nothing can hook or fall out,
i would have made the bridge 1mm wider and port 1mm narrower for safety.
To be honest our real test is when we run it at full throttle high revs in week or so, to be sure there is not fuel starvation,
but idea for that already,
we were thinking of putting in HP pump in front with regulator, at just a bit higher than standard or firstly try to bypass regulator in pump housing and then putting new regulator in front, and lifting it just a bit, the std pump can do a bit more, if the pump cant keep up, then we will have to go for option 1,
bad thing is, cash flow is a bit tight, so going to take it very slow
Philip
Old May 6, 2009 | 03:13 PM
Philip_SA's Avatar
Rotary lover
In power i think it might be more than 260, a bit maybe 270
as the following is now already done,
Cat removed, presilencer still in but pipe in cats place (cat cut out from standard and pipe distance piece inserted), at back we made the same as with mazdaspeed type 2 smaller silencers,
Then the bridgeporting, and a BMC F1 air filter,
and of coarse i will put my Royal Purple fluids in again after run in,
we are changing oil after week.
Philip
Old May 6, 2009 | 03:16 PM
lepichichi's Avatar
I LuV mY Rotary....
interesting subscribing
Old May 6, 2009 | 04:00 PM
Brettus's Avatar
Boosted Kiwi
interesting - but I think you will be dissapointed when you dyno it .
Old May 6, 2009 | 04:48 PM
pdxhak's Avatar
Official Post Whore
I want to hear this motor! GL with your build
Old May 6, 2009 | 05:13 PM
Easy_E1's Avatar
Is it worth the effort. There really isn't much room for any additional porting on that side of intake port. It would very small indeed. That's why I asked for pictures.
Old May 7, 2009 | 05:49 AM
Philip_SA's Avatar
Rotary lover
Yes,
sorry about pictures,
i didnt take of the porting, i wanted to but was too late, i can make drawing of what i saw, the port was not that big as you say, it was about 5 or 6mm wide, and bridge approx 2mm wide
i will put video clip on tonight hopefully
Philip
Old May 7, 2009 | 01:27 PM
Philip_SA's Avatar
Rotary lover
Here is the video clip link to you tube
Hi All
Here is the link to clip i just uploaded on you tube
http://www.youtube.com/watch?v=9Xs7b2ZUedo
Let me know what you think
Philip
Old May 7, 2009 | 01:32 PM
Red Devil's Avatar
Very cool! Are you the guy from before that was trying FD rotors in the Renesis?
Old May 7, 2009 | 01:34 PM
jjc3925's Avatar
yup that def sounds like a bridgeported rotary....
thats soo cool....cant wait for dyno numbers and some good videos in action
Old May 7, 2009 | 01:42 PM
Philip_SA's Avatar
Rotary lover
Can be
a year or so back i asked around to use renesis rotors in normal Fd / series 5 motor to have higher compression,
at end stayed with the renesis, as i needed housings as well, other management etc,
would have been costly
I wanted and will make another clip showing the rensesis motor and then back to hear sound
I got a small water leak somewhere as i lost a bit of water today, 4 hours of driving and bad traffic due to accidents, idling a lot.
will check again tomorrow to see if not waterpump
starting is already going much easier
will post again
Philip
Old May 7, 2009 | 01:45 PM
Philip_SA's Avatar
Rotary lover
I will give more info on how it goes after run in at end of next week, will then be fine and we will have done the first oil change
