Driver door lock stopped working
Old Apr 20, 2009 | 04:54 PM
Rogueain's Avatar
As the title says, It just stopped working. I had DIY installed the alarm shock sensor, and everything worked perfectly for two days. Then the driver's side door lock just stopped working.
I spoke to a mazda tech, and he asked me if the dome lights still come on and off when I lock or unlock the driver door. I told him yes, and he told me that the actuator isn't fried, and should still be working.
I've gone over the wiring three times, everything is correct. I don't know what to do, other than rip that piece of **** out, or throw 3-500 dollars at mazda to have them tell me I need to give them more.
Any ideas?
Edit: The shock sensor box says it was manufactured in 04, but the alarm works great, and so does the passenger door.
Old Apr 20, 2009 | 05:46 PM
DeViLbOi's Avatar
The devil made me do it
If you unplug the shock sensor does your door lock start working?
Does your door lock work if you physically lock the door with the lever?
Does your door lock work if you use your key?
Does your door lock work if you use your drivers side switch?
Does your door lock work if you use the passenger side switch?
Does your door lock work if you use the remote?
Old Apr 20, 2009 | 07:19 PM
Rogueain's Avatar
Holy cow.
If you unplug the shock sensor does your door lock start working? Not sure. Let me check...
Edit: if I unplug it, there's no change. Driver's dead, passenger works fine. Just no sensor.
Does your door lock work if you physically lock the door with the lever? Yes.
Does your door lock work if you use your key? Yes.
Does your door lock work if you use your drivers side switch? The switch? No. If I manually lock it, it stays locked.
Does your door lock work if you use the passenger side switch? Just the passenger.
Does your door lock work if you use the remote? Passenger, not driver.
Old Apr 20, 2009 | 07:21 PM
DeViLbOi's Avatar
Sounds like the motor in the drivers side door then.
Old Apr 20, 2009 | 07:29 PM
Buy some electrical contact cleaner from Radio Shack.
Spray it in there and then use a can of air for keyboards.
Clean it. Pray.
Old Apr 20, 2009 | 07:37 PM
Rogueain's Avatar
Hmmm, I thought the motor and the actuator were one in the same?
Old Apr 20, 2009 | 09:01 PM
DeViLbOi's Avatar
Could be...didn't pull out the tech manual on it...but his theory on why it isn't the motor doesn't make sense.
Old Apr 20, 2009 | 09:02 PM
rx8cited's Avatar
(From the Electrical System Manual) "Door Lock Actuator - Contains a reversible motor which locks or unlocks door depending on the direction of current flow."
The actuator is controlled by the Keyless Control Module based on various inputs such as the door key switch, door lock switch, and Keyless (remote) Receiver.
I'd guess the motor is not sold as a separate item from the actuator.
Possibly one of the connectors, most likely the actuator connector or Keyless Control Module connector is loose?
Old Apr 20, 2009 | 09:07 PM
DeViLbOi's Avatar
Id have to look at the wiring diagram but I can't see the switch in the driver door going back to the Keyless module and back to the door to run that motor.
Old Apr 27, 2009 | 01:36 PM
Evan0925's Avatar
I Can Has Rx8?
I just started having this issue today. The drivers door lock only budges a little, it won't lock/unlock via remote or switch.
Perhaps it's the heat?
Old May 11, 2009 | 04:33 PM
Lord ET's Avatar
Is that a bike rack?
I had this problem for a long time wiht the passenger door actuator..and took the whole thing apart to figure it out... the motor had just died after a while. The dealership will sell you the whole loking system for anywhere from $100 to $150, so I was quoted. I went to a junkyard and bought one for $40. You can search some of my threads and posts and find out what i'm talking about. It's a 9 inch or so black plastic piece...
I even tried calling the companies of the actuator, and the motor...both very japanese, and neither would help me out.
Old May 11, 2009 | 05:13 PM
04RX8man's Avatar
Rotary Powered Countryboy
sounds like the motor to me too....
Old Nov 5, 2014 | 08:15 AM
awbrigham's Avatar
Still not working for me
Got an issue similar both doors the buttons don't work... both the keyless and the physical buttons on the door it does lock and stay locked when i use the key or physically move it i hear it trying at the door but to no avail i just bought new door lock assemblies and put them in and nothing quite irritated about that but figured worth a try i dont believe mine has said sensor i need help with this i see maybe a body control module or Keyless Control Module but dont see where to try and get one seems like i need to drop it off to mazda and yell shut up and take my money and change my direct deposit to mazda the trunk still pops with the keyless and with the key as well as the button up front
Old Nov 5, 2014 | 05:15 PM
logalinipoo's Avatar
Driving my unreliable rx8
I have the same issue. I've replaced both of the actuators with working ones from people on here and neither one fixed the problem. It started with my passenger door and then work sometimes and sometimes not. Then moved to the drivers door. now they never work but I can hear them trying. It is like they are not getting enough power. I've replaced all the fuses and searched. I've seen several topics abut the problem, but never a solution. Posted here
Old Nov 6, 2014 | 06:59 AM
awbrigham's Avatar
talked with tech
I talked to a tech yesterday were thinking a possibility of keyless control module or body control module are possibilities but at over 600 it would be cheaper for 3 hours of labor (worst case scenario) to see if its the 100$ part or the 500$ part instead of buying both and just trying it. I will update asap but snow is on its way so i might be waiting until summertime
Old Nov 12, 2014 | 09:52 AM
awbrigham's Avatar
Confirmed Summertime wait
Had a few issues with my 8 in being able to drive it without possible further damage to internals clogged cat and bad ignition system so unfortunately she will remained parked till summer ordering parts for her throughout the winter im in hopes that by summer my rally wrx and rx8 will both be completed projects by then wish me luck
Old Sep 19, 2024 | 03:30 PM
MissKate's Avatar
Driver side
Having 5the same issue. Key fob works for trunk, and passenger door. However my driver side will only work manually. Any suggestions or answers yall have found ?
Old Sep 19, 2024 | 08:13 PM
Loki's Avatar
Does the lock **** inside wobble when you try to open it with the fob? It's a relatively common problem that's solved by replacing the motor and actuator assembly. It's not hard but annoying. If it doesn't wobble, it might be a different problem (but maybe with the same fix).
Old Sep 22, 2024 | 09:22 AM
MissKate's Avatar
The driver side won't budge with any buttons inside, or fob. Only with the valet key. The key isn't wobbly inside the mechanism. So I will look at pricing new motor and actuator. Then report back. 🫡 thank you
Old Sep 27, 2024 | 06:48 AM
cajunrx8's Avatar
Rotary Crawfish
Go on Amazon and get two lock motors for a Mazda 6 IIRC, it is the same part for like 20 bucks. Replaced both on my 05 and while you are in there replace the gears in the window motors too.
Them thangs will strip the teeth at a really bad time!!!
Crazy.8
Apr 18, 2017 03:17 PM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
SIllver
Aug 1, 2015 07:34 PM
MarkX
Jul 31, 2015 07:50 AM
