Smoke, And Slight Hesitation
Old Apr 10, 2009 | 11:18 AM
Sheehan's Avatar
Zoom Zoom
Info
04 6 Speed
64,000 Miles
Fresh Coils, Wires, And Plugs
Fresh Oil Change
Original Motor
Problem - Short Story
When I first start the car, usually after I have driven it for a short time, sometimes the car will smoke out of the exhaust pipe. The smoke appears white to me, and i can feel the car hesitate. Like its missing or something, it stutters I guess. It usually cleans itself out after 30 seconds or so and I never notice it again. Oil has been recently changed and might have a little extra oil in it? Would this matter.
Problem - The Detailed Story
Occassionally my car smokes and has a slight hesistation. This has happended 4 times now. Once in decemeber when I first got my car. And three times in the last 2 weeks. It usually happens after I drive my car, and shut it off. And then get back in it and go somewhere usually within the first mile it will do this. It smokes white from the exhaust pretty bad and once i swear there was even white smoke coming through the vents on my dash. When it is smoking the car studders and is lacking power. It hesistates and is very sluggish for a couple seconds and then it magically cleans itself out, quits smoking and runs fine like nothing ever happended.
I recently changed my oil, and it has a little extra in it, it's over the full line. I havn't removed the extra oil yet and I don't plan to. I don't think its hurting anything? The car has recently had plus coils and wires so it's none of those.
Forgot to mention, I can smell the smoke whenever it is happening. I can't really describe it though.
Thanks, Logan.
UPDATE
This morning I started the car up.
No smoke at all.
So I'm sitting there like I usually do for a few minutes to let it warm up.
And I decide to turn the heater on because I'm Cold :P
BAM - White smoke out the exhaust within 2 seconds.
Went outside to smell the smoke like you guys said I should.
I don't recommend sticking your nose up to the exhaust tips.
They will make you light headed.
But anyway, I couldn't smell anything sweet.
I kind of have a cold though so my sniffer might not be working real well.
So does this mean its some sort of coolant leak?
Old Apr 11, 2009 | 02:03 PM
Sheehan's Avatar
Zoom Zoom
Bump
Old Apr 11, 2009 | 02:53 PM
05rx8mazda's Avatar
B.I.G
umm mine did the same thing after i sucked in a ton of oil through the intake..... still occasionally smokes.. try cleaning the thorttle body and mazda clean/ sea foam it!!
chc you cat???
Old Apr 11, 2009 | 03:04 PM
Mazmart's Avatar
Is the smell possibly somewhat sweet?
Paul.
Old Apr 11, 2009 | 04:00 PM
Internal coolant leak? Is the coolant reservoir level dropping?
Old Apr 11, 2009 | 04:33 PM
Sheehan's Avatar
Zoom Zoom
chc you cat???
I'll try the sea/foam treatment and see what happens. I've been wanting to try that anyway. Thanks for the help !
Paul.
I'm not real sure if it was sweet or not. If it happens again I will be sure to do a smell test. Thanks
The coolant level hasn't appeared to change no.
Old Apr 13, 2009 | 08:10 AM
Sheehan's Avatar
Zoom Zoom
UPDATE -
No smoke at all.
Old Apr 13, 2009 | 08:35 AM
SARRAS's Avatar
Sydney, Australia
"I havn't removed the extra oil yet and I don't plan to"
Well right there is something that's obviously not correct so go fix it already!
Old Apr 13, 2009 | 08:43 AM
staticlag's Avatar
The Professor
Yeah, overfilling the oil can cause it to shoot into the intake. Startup oil pressure is really high so makes sense that if it was overfilled it would leak and smoke on startup.
cliffkemp
Dec 24, 2024 10:48 AM
Azki23
Jun 27, 2018 03:48 PM
crimson809
Aug 14, 2016 10:03 PM
pjwermuth
Sep 28, 2015 11:36 PM
DVerdeyen
Sep 13, 2015 11:19 AM
