Will 19x8.5 ... 35mm offset rub?
Old Dec 21, 2003 | 03:26 PM
matticakes's Avatar
Im looking to put 19x8.5 with 35mm offset rims with 235/35ZR19 tires... do you think these will rub?
Old Dec 22, 2003 | 01:44 PM
slavearm's Avatar
Boost Junkie
You will need to roll the fenders and even that might not be enough. I would go for a +40-50 range for the offset, and if you get the +40 you will run SLIGHTLY under extremely hard cornering. Anything above +40 though and you should be fine.
Old Dec 22, 2003 | 07:52 PM
RX8on19s's Avatar
Here's my 8
Here's my 8 with 245/35/19 in the front and 275/30/19 in the rear. The rims are 19"x8.5 in the front and 19"x9.5 in the rear with 35mm offset
RX8on19s's Avatar
Here's my 8
Here's my 8
Old Dec 22, 2003 | 07:54 PM
RX8on19s's Avatar
Here's my 8
These are the m-sports rims by ADR
Old Dec 22, 2003 | 08:08 PM
mikeb's Avatar
100% Italian
that grill looks sweet
Old Dec 23, 2003 | 05:39 PM
Ned M's Avatar
Re: Here's my 8
So do you get any rubbing of sidewalls against fender lip under hard cornering with this setup, or not?
Thx
Old Dec 24, 2003 | 03:57 PM
RX8on19s's Avatar
It rubs a bit when you have 4 people on the back fender. I'm going to a performance shop on Monday to roll the fender with a special tool. I'll let you guys know how it turns out.
Old Dec 25, 2003 | 08:09 PM
shepepp's Avatar
Hey RX8on19s,
I put new aftermarket rims on my RX8, but the sensors kept leaking air, so I couldn't use them. Did you have that problem?
If so, what did you do and is there an adapter available for them tha you know of?
Shepepp
Old Dec 25, 2003 | 10:36 PM
RX8on19s's Avatar
I don't use the sansor, I live with the light in the car.....
Old Dec 26, 2003 | 11:49 AM
mikeb's Avatar
100% Italian
please find out what special tool they use to roll fenders?
Hopefully not a baseball bat
Old Jan 5, 2004 | 11:38 PM
EXA4DRIVER's Avatar
http://www.robsaudiworld.com/fender.htm
This is the tool they use.
ASH8
General Automotive
2029
Apr 10, 2026 02:06 PM
gwailo
May 14, 2024 06:57 AM
hufflepuff
May 30, 2016 10:45 AM
czr
Sep 13, 2015 11:37 AM
