HELP! Lights and ACC on but Car will not even crank!
Old Mar 26, 2009 | 12:10 AM
Derex'8's Avatar
ReDuX
Was driving home and came to a stop light. Car came to an idle & then stalled. I tried to start it back up but it didn't even budge, nudge or crank. Nothing, but strangely all my lights, radio, and electronics work. So not battery.
Is my alternator shot? What else could be the culprit?
Need help ASAP!
I should also add that this happened a day after I installed the BHR ignition. Oh and already checked my coil & plug connections & ground wire, all of that is fine.
Old Mar 26, 2009 | 12:24 AM
Jon316G's Avatar
Grasshopper
Should have nothing to do with the alternator.
Sounds like something that would occur when the starter interlock switch isn't engaged.
Where did you run your ground?
Old Mar 26, 2009 | 12:29 AM
Derex'8's Avatar
ReDuX
It's bolted down along with battery tray(which is aluminum), which is bolted to chasis.
Should the Ground terminal be in direct contact with the chasis or does it matter? As it is now it's bolted down on the battery bracket.
Old Mar 26, 2009 | 12:37 AM
Derex'8's Avatar
ReDuX
To dark right now but will check in the morning all my fuses. Damn this **** sucks had to get AAA to tow me the rest the way home. Might I add this happened to me 1030 @ night and was stranded in not the most friedliest parts of town.
Old Mar 26, 2009 | 12:43 AM
I8U's Avatar
I8U
Check the fuse box under the hood. Most importantly check the ENGINE fuse, that was my problem when I did the LS2 coil swap.
Old Mar 26, 2009 | 12:56 AM
Brettus's Avatar
Boosted Kiwi
also - check the switch on the clutch pedal .
Old Mar 26, 2009 | 12:59 AM
Derex'8's Avatar
ReDuX
^^^Huh? switch on clutch pedal?
Old Mar 26, 2009 | 01:00 AM
Brettus's Avatar
Boosted Kiwi
yes - the one that won't let you start the car unless the clutch pedal is down ....
Old Mar 26, 2009 | 01:03 AM
Aluminum is not that good of a conductor. Rewire to chassis
Old Mar 26, 2009 | 01:09 AM
Derex'8's Avatar
ReDuX
Wow!!!! thats embarrasing owned car going on 3 yrs now and knew nothing about that switch tisk:tisk:tisk
Well thanks for all the suggestions fellas, will run by all these in the morning and go from there. Been one hell of a day and just need to rest my mind & body now.
Please feel free to keep all suggestions coming...
Old Mar 26, 2009 | 01:18 AM
Jon316G's Avatar
Grasshopper
Yup... that is the starter interlock switch:
HELP! Lights and ACC on but Car will not even crank!-starter-interlock-switch.jpg
Agree.
I used a chassis ground to the right of the master brake cylinder:
Old Mar 26, 2009 | 01:21 AM
I8U's Avatar
I8U
I used the chassis ground under where the stock air box would be.
Old Mar 26, 2009 | 01:24 AM
Brettus's Avatar
Boosted Kiwi
if you get a loud click when you turn the key but motor does not turn over it could be your stater motor
Old Mar 26, 2009 | 01:25 AM
Derex'8's Avatar
ReDuX
Oh snap thanks for the picture, will have to check that out. Was thining of something else
Oh and no click @ all when key is turned.
Old Mar 26, 2009 | 03:29 AM
Jon316G's Avatar
Grasshopper
No problem.
And there are two ways to check the starter interlock switch:
  1. Simply press in that white shaft to engage the switch and try starting the car.
    Obviously, you don't need to press the clutch pedal in.
  2. If you suspect the switch itself to be faulty, disconnect the wire harness and take a single wire and jump the two terminals.
If the car still doesn't start, then its definitely something else.
Old Mar 26, 2009 | 08:19 AM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
This sounds pretty silly, but worth adding... if you jump the terminals, make sure the car isn't in gear when you try to start the car if you don't have the clutch depressed.
oops!
Old Mar 26, 2009 | 12:43 PM
Derex'8's Avatar
ReDuX
Well it was indeed the 15A engine fuse in the eng bay. But now my problem is the fuse keeps blowing. What gives? Is there a short a somewhere thats causing this fuse to keep blowing out?
Where could this short be?
Old Mar 26, 2009 | 12:45 PM
Brettus's Avatar
Boosted Kiwi
First place i would be looking is the coil install ....... double check everything
also :do you have an aftermarket midpipe ? If so , check the o2 sensor wire is not shorting out - this happened to me once ......
Old Mar 26, 2009 | 12:47 PM
I8U's Avatar
I8U
Re-check your connections since you just did the coil upgrade. Fix that ground also.
Old Mar 26, 2009 | 12:48 PM
Derex'8's Avatar
ReDuX
I regrounded the coils wire to the chasis. I guess I need to go back over and recheck all coil & wire connections
Old Mar 26, 2009 | 12:57 PM
I8U's Avatar
I8U
Well, if the ground isn't the issue just throw in a 20amp fuse! HAHA, I keed I keed. No don't do that, I'm not real sure what all components draw power through that fuse. Did you check all the fuses in the engine bay and the interior fuse bank? I found a couple that were blown from the coil swap.
Old Mar 26, 2009 | 01:02 PM
Derex'8's Avatar
ReDuX
Ok fellas replaced fuse again, retorqued my battery terminals and coil ground down(which were a tad loose), pushed in and secured all coil & plug wires. Fired her up & everything seems fine thus far, will keep an eye on it though.
Thanks a ton for everything, Damn I love this forum. Saved me some major time & headache. Can't imagine how something so small disabled my whole damn vehicle. haha
Old Mar 26, 2009 | 01:04 PM
Derex'8's Avatar
ReDuX
Yeah I looked over all the other fuses in the bay & they all checked out fine. Will give the interior fuses a look over though!
HAHA you know what I was seriously considering replacing that fuse w/a 20A
Old Mar 28, 2009 | 07:28 PM
Derex'8's Avatar
ReDuX
Well the problem has returned...
Does anyone know what is ran by the 15A engine fuse?
I have much reason to believe there is a issue with the coils. I will reinsatalling my stock ones tomorrow and seeing if this will be duplicated. I'm going to also run a check on them with a multimeter, before uninstalling.
I'm also getting a flashing security light whenever this happens. (which according to the shop manual could be a com error between coils)
digitalmonkey79
Jul 29, 2015 12:09 AM
harithac
Jul 25, 2015 04:21 PM
netrovers
Jul 20, 2015 03:32 AM
ironj221
Jul 16, 2015 10:16 PM
AussieGray
Jul 16, 2015 03:58 AM
