Stock Keyless Entry Fob Doesn't work
Old Mar 14, 2009 | 03:19 PM
brillo's Avatar
Go Texas Longhorns!
Ok, I've done some searching on this and I'm only finding threads about upgrading to the switchblade key fob.
So I get up this morning and my 2004 stock key less entry fob doesn't seem to open the car. I figure its the battery, so I swapped a new one into the unit. Still no workie. My other fob also appears to have a dead battery, so I swapped it out too. No luck on getting that unit to open the car either.
Do you have to reprogram after you simply swap a battery? Thanks guys
Old Mar 14, 2009 | 04:31 PM
Silver06's Avatar
Zoom Zoom....
Hi Brillo.
That sucks.
As far as similar problems, I found this post by dannobre:
Originally Posted by dannobre
I've had both of my stock ones that came with the car die...and I've tried new batteries and re-programming them to no avail.....
I think it is a common problem..at least 2-3 of our club members have dead ones as well
You might want to PM Dan and see what he found after the fact.
Good luck.
Old Mar 14, 2009 | 04:34 PM
Nothing much..it was cheaper to get a couple from e-bay and re-program those.
Some day I will try and figure out what's up with them...I think they just quit working
Old Mar 14, 2009 | 04:45 PM
just buy some new switch blade keys and get them programmed- thats what i intend to do very soon
Old Mar 14, 2009 | 04:46 PM
2tone's Avatar
The RX-8 is missed
^^ same thing happened to me; thought it was just the battery but no luck. i'm saving up for the switchblade, but going on 3 or 4 months now of just using the key sucks when my gf is with me!
brillo's Avatar
Go Texas Longhorns!
so do you have to reprogram when you replace the battery?
Old Mar 14, 2009 | 04:51 PM
2tone's Avatar
The RX-8 is missed
i don't know, but i guess that sounds like it might work. i didn't expect to need to do that, but i never tried...
Old Mar 14, 2009 | 05:00 PM
I tried that and it didn't work for mine.....worth a try though
Old Mar 15, 2009 | 03:01 AM
ASH8's Avatar
Super Moderator
I think you do need to reprogram when your renew the battery.....
Taka has an easy Thread here on how to do...
Old Mar 15, 2009 | 03:27 AM
alan.
sorry i missed you call.. but try to reprogram..
i know that when i did my one key no fob, both of my old fobs did not work any more.. and that was like two years ago.. i doubt the batterys died..
Old Mar 15, 2009 | 12:55 PM
Shifty Devil's Avatar
You should not have to reprogram after changing a battery. The Fob simply transmits an embedded unique number code that the car electronics has recorded as valid. Changing the battery should not alter the code that is transmitted. I doubt the fob is sophisticated enough to be sending anything complicated like the rolling codes of a garage door opener. Make sure the battery is in correctly and any connections are clean and unbroken.
Old Mar 15, 2009 | 02:56 PM
ASH8's Avatar
Super Moderator
I think when you re-program the new key you have to have your old ones handy to re-do ALL at the same time....probably because a new code is issued, so the old code will no longer work in the keys that you thought were OK.
Old Mar 16, 2009 | 12:27 AM
i agree,
and btw allen. i have an extra fob.
Old Mar 16, 2009 | 02:29 AM
Lebren's Avatar
RX8club group buy vendor
This procedure worked for a lexus, it's free and worth a shot:
1] Stand within a couple feed of the car
2] hold the lock and unlock buttons down for 15 seconds or until a click is heard.
I hope it works for the 8
Old Jun 26, 2012 | 09:34 AM
Cezar's Avatar
I agree lol same feeling when I need to open the door for a girl and oh! Surprise!
Old Jun 26, 2012 | 11:54 PM
Cezar's Avatar
Aftermarket keyless system and alarm?
Hello I. Just got a rx8 the alarm system and keyless doesn't work for some reason I changed the battery and nothing... I was thinking about get a keyless alarm system is that a good idea any brands of system??? I read somewhere than if I install any alarm keyless system on my rx8 I can get some problems and my car can keep shutting off??? I hope u guys. Can Help. Me. Thank you so much
Old Jun 27, 2012 | 02:08 AM
Grace_Excel's Avatar
Charles Bundy
What year is your car? If you own a 2004 and uses the keychain FOB, you will: 1. Need to have the dealer program the FOB. OR 2. Buy a switchblade (like the one from eBay linked below) and follow the programming instructions for the Switchblade FOB.
MAZDA SWITCHBLADE KEY/FOB
I have tried Takahashi's versions of programming the FOB for the 2004 RX-8 and niether worked. It did on the switchblade, however. The only sure way of reprogramming the 2004 FOB when the battery dies is through the dealer using the Mazda-Modular Diagnostic System.
ironj221
36
Jan 20, 2026 08:28 PM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
sccarally
Gulf RX-8 Forum
Sep 8, 2015 10:34 PM
akagc
Aug 11, 2015 07:07 PM
Twiztog43
Aug 1, 2015 02:55 PM
