If your battery dies, can you pop the clutch on the 8?
Old Mar 11, 2009 | 10:40 PM
DOMINION's Avatar
I don't buy Kool-Aid
Question If your battery dies, can you pop the clutch on the 8?
dang it
Old Mar 11, 2009 | 10:42 PM
alnielsen's Avatar
Yep, done it.
Old Mar 12, 2009 | 03:29 AM
AJ's Shinka's Avatar
Enthusiast
It was actually for me I was left stranded in the middle of the Nevada desert with a dead battery and I had to call the Dominion for help.
Old Mar 12, 2009 | 04:34 AM
Flashwing's Avatar
3-wheeler
Push start FTW!!
Old Mar 12, 2009 | 05:28 AM
DOMINION's Avatar
^LOL thats what I said. But turns out his battery died and his car got flooded when he tryed to start it.
We tryed to jump it but she would not have it.
After we put the new battery in, we had to use the washer fluid line to deflood his 8 then crank it stop, crank it stop, crank it stop. I think on the 4th try she turned over with a big *** back fire. Let her idle for a bit till the idle was smooth. Then he was good to go.
I would like to give a big shot out to devoid! you da man.
Old Mar 12, 2009 | 12:03 PM
Enthusiast
Originally Posted by Flashwing
Push start FTW!!
Thanks but Dom helped me out. I need you on speed dial I would've called Phil but he is always sleeping for some reason.
Old Mar 12, 2009 | 02:13 PM
i did mine in reverse i parking lot
Old Mar 12, 2009 | 02:18 PM
Silver06's Avatar
Zoom Zoom....
As long as the battery has some voltage to power the ECU, coils (and security system), the car will start.
I think the magic number is 9 volts....
Old Mar 14, 2009 | 10:07 PM
DOMINION's Avatar
^This one was like beating a dead horse lol
Old Mar 15, 2009 | 10:42 AM
PRX8's Avatar
Just buy either a Red or Yellow Top Gel Battery or even AC Adelco with 1000 cca
Old Mar 15, 2009 | 12:34 PM
It's much easier to throw in the tow hooks in both cars...and pull it for a couple hundred yards.
That way the battery can be stone dead...and the alternator will still give you enough current to get it going..and even if it's flooded it will start
Hell...I started a couple of cars with one rotor and drove them like that after they were running....
WranglerFan
May 31, 2022 07:51 AM
GARCIAC951
Sep 10, 2015 07:17 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
