Water in the Tailight TSB just got Revised, New Part
Old Mar 4, 2009 | 11:02 PM
prospectjtaz's Avatar
So ya, the TSB just got revised, I have the gasket, gonna see if I can get the new pad also tomorrow.
http://www.finishlineperformance.com...05-09-2055.pdf
Old Mar 4, 2009 | 11:18 PM
rx8thunder's Avatar
Being (new) single rocks!
is this covered under warranty?
Old Mar 4, 2009 | 11:22 PM
eug's Avatar
eug
rukia is a metaphor
On last page of TSB:
• This warranty information applies only to verified customer complaints on vehicles eligible for warranty
repair.
• This repair will be covered under Mazda’s New Vehicle Limited Warranty term.
• Additional diagnostic time cannot be claimed for this repair.
Old Mar 4, 2009 | 11:30 PM
probabaly not if you have an 04, its easy to fix, will check to see if part numbers can be cross referenced.
Old Mar 5, 2009 | 09:43 AM
rafaga's Avatar
Thanks for the heads-up, prospectjtaz....this is one of the reasons why I love this forum!
Old Mar 5, 2009 | 09:55 AM
Huey52's Avatar
Registered Zoom Zoomer
This revised TSB has been out since early February, and already discussed in a number of 'water in the tailight" threads, but I guess we needed yet another one.
Old Mar 5, 2009 | 10:03 AM
TheWulf's Avatar
My 8 looks like a Smurf
FYI I've installed this gasket on my tail light and it has solved my problem. Very easy to install, hard part is getting the tail light dry
Old Mar 5, 2009 | 10:14 AM
Hoss's Avatar
So if I am reading this correctly, on my 04 I would not be able to get this covered under warranty?
What can I do if I am having one tail-light condensate?
Edit - Nevermind. On first page of the TSB it states "Applicable models/VINS - 2004-2006... With VINS lower than... (produced before March 1 2006)" . Looks like I will take a shot at getting this taken care of
Old Mar 5, 2009 | 10:49 AM
Daemos's Avatar
read again...
It clearly states "This repair will be covered under Mazda’s New Vehicle Limited Warranty term." (3 years)
Old Mar 5, 2009 | 11:55 AM
TheWulf's Avatar
Don't worry about it, just get the new gasket and stick it on. I think it was about $20.
Old Mar 5, 2009 | 01:23 PM
Hoss's Avatar
Originally Posted by Daemos
read again...
Wait, I am confused... If that is the case, why would they issue a TSB that is already invalid
2006 was three years ago... 2004 was 5 years ago.
Old Mar 5, 2009 | 01:27 PM
Huey52's Avatar
^ keep in mind that the warranty clock doesn't start until you buy the vehicle, Case in point, I bought my '05 in late March of '06, therefore I'm still within the 48 mo. B-toB warranty.
Old Mar 5, 2009 | 01:29 PM
REsuperD's Avatar
zoom zoom
if you buy the gasket from finishline, it's now a 2-piece kit that includes the other smaller piece. it's also about $20 more
Old Mar 5, 2009 | 02:05 PM
shazy's Avatar
I don't know if I should get mine. How would you clean the Watermarks inside the Tailight?
Old Mar 5, 2009 | 02:09 PM
Huey52's Avatar
White Vinegar is the cure for most all 'water spotting' ills.
Old Mar 5, 2009 | 04:16 PM
eug's Avatar
eug
rukia is a metaphor
The TSB itself has nothing to do with whether your particular car will be repaired under warranty. It's a service bulletin. Meaning it tells the service tech how to fix it. Who pays is a totally separate matter.
Old Mar 5, 2009 | 04:20 PM
boffam's Avatar
Rotating eccentrically
This TSB does not apply to me as the dealership already drilled holes in the bottom of my tail-light assembly to drain the water (and goldfish) out.
Old Mar 5, 2009 | 04:23 PM
eug's Avatar
eug
rukia is a metaphor
Sorry, my bad . Yes it's VIN and year specific, but I meant to say that it doesn't exclude earlier models from warranty coverage just based on year, since some may have extended warranties.
Old Mar 5, 2009 | 06:11 PM
SpIcEz's Avatar
The TSB has nothing to do with the warranty.
Its a guidline on how to repaire something.
If the particular car is still under warranty, that repair is free.
If it is NOT still under warranty, they still use the TSB as an instruction of how to repair it, they just charge for it.
You can buy the part yourself and fix it yourself if you are OUT of warranty.
New Yorker
40
Mar 22, 2022 06:01 AM
Warrior777
Jun 24, 2019 04:47 PM
drebbrnator
Dec 27, 2018 07:02 PM
AllSeeingChris
Aug 16, 2015 12:35 PM
Kim Jong Illest
Canada Forum
Jul 23, 2015 03:22 PM
