Sport Package Std on 6sp
Old Jan 7, 2003 | 04:26 PM
fritts's Avatar
I was wondering it seems like I have read this in reviews on the 8 that the sport suspension package,(18"Rims, Big Brakes,sport suspension) were going to be standard on the 6speed 8. If this is so, man, Mazda is creating a great deal at 26,600 or whatever it is.
Is this true that the sport package is std on the 6sp in the U.S.
Old Jan 7, 2003 | 04:46 PM
Quick_lude's Avatar
Love to rev!
Hehe.. I was wondering the same thing.. I just asked about the 16" "base" wheels. If we get the 18"/suspension/brakes for 26600 that would be an amazing deal.
Old Jan 7, 2003 | 05:24 PM
snow_tires's Avatar
i just looked at the press kit,
(in north america)
the 6sp manual only comes with the sport suspension and 18 inch wheels.
BANG!
Old Jan 7, 2003 | 05:44 PM
cueball's Avatar
No big brakes?
Old Jan 7, 2003 | 06:21 PM
Hercules's Avatar
Originally posted by cueball1029
No big brakes?
EDIT: There are 16" brakes on the standard model, 17" on the high power.
Old Jan 7, 2003 | 06:54 PM
RedRotaryRocket's Avatar
Hey Herc,
Where is this data from....not to be a party pooper, but I don't think it is accurate. How can they have 16" brakes on the non-sport model when the wheels are only 16"? Unless the RX-8 employs a really cool inboard brake design, this just isn't possible. Besides, 16" and 17" brakes are ridiculously huge. I would expect 13" max....though larger would be cool :D
Old Jan 7, 2003 | 06:57 PM
Hercules's Avatar
Originally posted by RedRotaryRocket
Hey Herc,
Mazda has put out a press kit chock full of information.
I've verified my findings in this thread with an attached image, so take a look for yourself
Here's the thread.
Old Jan 7, 2003 | 07:01 PM
Ah...there's the problem. 16" type and 17" type are refering to the wheel size, I believe. If you convert the mm to inches, you'll see that the disc diameter is 12.7.
Old Jan 7, 2003 | 07:03 PM
Off topic, but does that nifty press kit happen to list the compression ratio?
Hercules's Avatar
Long day... you understand
I don't wake up at 7:30 in the morning during my winter break often :p
Old Jan 7, 2003 | 07:05 PM
323mm is roughly 13 inches for the big wheels
303mm is roughly 12 inches for the little wheels
302mm or again roughly 12 for the back wheels either way
Old Jan 7, 2003 | 07:07 PM
In any case, 12.7 is GREAT for a car that weighs ~2900 lbs. If my memory is correct, the brakes on the FD RX-7 were 11", and it weighed nearly the same.
Old Jan 8, 2003 | 12:04 AM
B-Nez's Avatar
10.0
From the Full Presskit PDF file, page 122 (as numbered on page). There is a complete chart of all the specs, but could not find it individually in the images area. Export is kinda small:
Edit: Forgot the 3rd piece of the chart:
Old Jan 8, 2003 | 12:08 AM
Quick_lude's Avatar
Love to rev!
Curious how they don't list curb weight..
HEY! We lost 3 ft/lbs of torque! :p
Old Jan 8, 2003 | 12:16 AM
eccles's Avatar
Prodigal Wankler
I wonder why the Japanese 6-speed gets a slightly taller 3rd gear. There must be a good reason why they'd bother to cut a separate cog just for that one variant.
Anyone? Beuller?
Old Jan 8, 2003 | 01:51 AM
Gord96BRG's Avatar
That's accurate - it just isn't referring to the diameter of the brake disc. This form of reference to the size of the brakes is used in Europe and elsewhere, where they refer to the size of the wheel required to clear the brake disc and caliper. So, the "16" brakes" require a 16" diameter wheel at a minimum, and the "17" brakes" require a 17" diameter wheel at a minimum (note that the Sport suspension package uses 18" wheels anyway - so you should be able to get winter wheels and tires in a -1 sizing on 17" wheels!). The information also lists the exact brake disc diameter separately.
Regards,
Gordon
Old Jan 8, 2003 | 05:26 AM
RX-3_13B_Tommo's Avatar
I can help
Go to the mazda usa new RX-8 page. On it you can build your own, with the pagake and trim and the whole ****. It's awesome
crimson809
Aug 14, 2016 10:03 PM
snowrydr01
Nov 23, 2015 09:40 AM
Oct 3, 2015 09:51 AM
duworm
Oct 1, 2015 04:57 PM
