dentist drill sound?
Old Jan 18, 2009 | 06:19 PM
HERO's Avatar
This started about a week ago. Upon the car's first startup of the day, There's this dentist's drill kind of sound coming from the engine. It goes away once the cars is warmed up, but it has never done this before but has everyday for roughly a week now.
any thoughts?
Old Jan 18, 2009 | 06:26 PM
Secondary Air injection Pump.....
Thing is crapping out.......runs for a couple of minutes on cold start to warm up the CAT
Old Jan 18, 2009 | 06:31 PM
HERO's Avatar
hmmm, is it a necessary fix (as in, is it harmful to leave alone?)? Is it an easy fix? I really have no clue where or what it is aside from what you just mentioned. I have no problem doing the work myself though.
Old Jan 19, 2009 | 11:48 AM
am22's Avatar
Me too I got the same problem going on with my car, but I don’t know if I should replace the pump or not. Is it necessary?
Old Jan 19, 2009 | 11:56 AM
rotary.enthusiast's Avatar
The Local Idiot
It's there to help the cat hit optimal temperature faster for emissions reasons. If it's not working you will produce more emissions each time you start the car, because the cat won't be working properly for a longer period of time. It's nothing to be overly alarmed about. If it fails totally you should get a CEL.
Old Jan 19, 2009 | 03:42 PM
04RX8man's Avatar
Rotary Powered Countryboy
yes it's not a must just helps...I believe alot of the FI guys disable this all together!
92trbolzr
May 18, 2025 09:04 AM
theblinkof
Oct 4, 2023 05:24 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
Racingjunkie
Sep 29, 2015 05:05 PM
tommy26Germany
Sep 29, 2015 10:33 AM
