clinking sound
Old Jan 9, 2009 | 11:02 PM
Zyr's Avatar
Zyr
clinking sound
Hi, hopefully this is the correct section to post this. I have a 2008 rx8, with barely 6k miles. Recently, I noticed if I enter 2nd, 3rd or 4th gear, I hear this clinking/ringing sound. If I just rev the engine in neutral, I don't hear anything. I dont hear it at 1st, 5th or 6th either. Anyone has any insights on what could be the problem. Thanks.
Old Jan 10, 2009 | 08:21 AM
04RX8man's Avatar
Rotary Powered Countryboy
is it when u PUT it into gear or while you are in gear and driving? This prob will get moved to the tech section however!
Old Jan 10, 2009 | 02:06 PM
Zyr's Avatar
Zyr
It's when i am already in gear and throttling.
Old Jan 10, 2009 | 02:21 PM
Brettus's Avatar
Boosted Kiwi
how bad is it ? If it's a small clink i would forget about it . Big clink - that's another story ....
Old Jan 10, 2009 | 05:40 PM
04RX8man's Avatar
if it's real louds and only when u are in the throttle! coasting in gear does it make the same noise? If it's only when in gear and throttle on but not while coasting sounds like the same exact noise i had an dit was the input shaft bearing was shattered and had to get the trans rebuilt
Old Jan 10, 2009 | 07:33 PM
Zyr's Avatar
Zyr
it's not a single clink... it's like a straight clinking sound, like as though something is loose. And it usually happens only when i go above 3.5k RPM, so basically from start, 1st gear nothing, 2nd gear get to 3k+ RPM i hear that sound, change to 3rd, RPM drops, nothing again, throttle to 3k+ RPM and it's back, same for 4th...
No it doesn't happen when I am coasting in gear either... i was guessing something is loose with exhaust or something... i really hope i dont have to rebuild the tranny ><
i am going to have it check out either way, but was hoping I know what could be causing it before i go so i dont get ripped off by some random reasoning they pulled out of thin air... though it's still under warranty...
92trbolzr
May 18, 2025 09:04 AM
theblinkof
Oct 4, 2023 05:24 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
Racingjunkie
Sep 29, 2015 05:05 PM
tommy26Germany
Sep 29, 2015 10:33 AM
