Question - Head unit aux input
Old Dec 7, 2003 | 12:57 AM
WHealy's Avatar
Mr. Blue Man
I've read that the OEm head unit doen't have an AUX input. Doesn't it have to with the additional cassett tape/mini disk option? Is it just a case of that's propritary and we can't use it?
Sorry for my ignorance, as I have yet to take my head unit out. Really can't tell without one of the extra units though ...
Old Dec 7, 2003 | 07:02 AM
Kev's Avatar
Kev
[rapidus octus]
It has it's own set of signals that are in need of cracking. There's no "AUX" mode available as is and nothing like a simple set of line input rca's.
Old Dec 7, 2003 | 08:32 AM
WHealy's Avatar
Mr. Blue Man
Kev,
OK Thanks. I had a Prowler previously that had a 1.5 DIN head unit. The size made me hesitate to replace it. It also didn't have an AUX. But I did find a wiring harness that transformed the CD Changer plug (stock unit skipped way too much to be used) into RCA plugs ignoring the other inputs but making the head unit think there was a CD changer there to allow for "Source" changes. I had a Neo Jukebox with an 80 Gig drive that sounded simply awsome though that setup. The FM modulation that came with the unit was horrible by comparision. I found the plug on my own on the web. Didn't know if perhapse something existed for ours as well.
Old Dec 7, 2003 | 12:18 PM
Tamas's Avatar
Registered Lunatic
In case you're successful in finding such a module for the RX-8, please post. I also have a Neo and I want to install it in the RX-8. I'm thinking about getting the head unit modified and an AUX input opened (which I once got done with a Ford head unit - worked great).
Another option (in case you can't find such a harness) is in this thread.
Old Dec 7, 2003 | 02:05 PM
Sputnik's Avatar
Look through the threads in the sub-forum, there have been alot of people trying alot of things. So far, the only solution to be found was either an FM Modulator, or hacking into the tape drive, or using a tape adapter in the tape drive.
That doesn't mean that another solution isn't out there, it's just that noone has found it yet.
---jps
Old Dec 15, 2004 | 04:12 AM
thew's Avatar
Thews8
PIE PIE PIE..
The PIE box is the solution
Old Dec 15, 2004 | 11:43 AM
Tamas's Avatar
Registered Lunatic
Geez... talk about resurrection of an old topic :D
Old Dec 15, 2004 | 11:56 AM
8's enough's Avatar
hey WHealy, i thought you sold your 8 ?
Old Dec 15, 2004 | 12:30 PM
BlueGrimRX8's Avatar
look at the post date 12/07/2003
Old Dec 15, 2004 | 12:31 PM
Tamas's Avatar
Registered Lunatic
You do realize his original post is more than a year old, right?
Old Dec 15, 2004 | 02:26 PM
8's enough's Avatar
i do now:D
Old Dec 15, 2004 | 06:39 PM
thew's Avatar
Thews8
heheh ..
well now we have killed it ithink
gwailo
May 14, 2024 06:57 AM
Crazy.8
Apr 18, 2017 03:17 PM
arjunmshah
Aug 6, 2015 10:56 AM
MolecularConcept
Aug 1, 2015 03:15 PM
ion_four
Jul 30, 2015 09:48 PM
