R-Magic ECU
Old Dec 2, 2003 | 03:46 PM
Maestro's Avatar
R-Magic ECU
R-Magic one of Japans top rotary tuners have just released there ECU for the RX-8
http://www.rmagic.net/rmrx8/rmrx8power.htm
Old Dec 2, 2003 | 03:59 PM
mikeb's Avatar
100% Italian
please translate
Old Dec 2, 2003 | 04:09 PM
rotarygod's Avatar
If you ever need to tranclate anything use babelfish. It is crude but decipherable.
http://babelfish.altavista.com/
At the bottom you can enter in the web address as well as what language you want to go to/from.
Old Dec 2, 2003 | 04:16 PM
MazdaManiac's Avatar
All it does is remove the REV limter.
They are still researching the ECU for tuning.
Old Dec 2, 2003 | 04:28 PM
mikeb's Avatar
100% Italian
thank you
I still dont understand it in english
Old Dec 2, 2003 | 05:23 PM
Jt-Imports's Avatar
I think you will see some nice ECUs being released offically after AUTOSALON TOKYO this year, before that they are UN-OFFICALLY Available and they do my then take out the REV-limiter
Old Dec 3, 2003 | 04:00 AM
sixspeed's Avatar
Petrolhead!
Not sure what the point of this is, since all dyno tests we've seen have shown power dropping from 9000rpm. Not sure what good a higher rev-limit is without extra tuning to keep the power climbing (or at least levelled off rather than dropping)...
-andy-
Old Dec 3, 2003 | 07:46 AM
Redshift's Avatar
Spinning Dorito Junkie
-andy-
For track/autocross type use removing a rev limiter can be an advantage as it will let you hold a gear longer. Power may be falling off, but if it prevents you having to shift up a gear before having to quickly shift back down (i.e. the straight is just a little too long, but you'll have to shift right back down for a corner... your choice is bounce of the limiter for a few seconds or shift twice... both lose time) having the extra RPM over-run can be faster.
Other then that...well... not much point to just removing a limiter.
Old Dec 3, 2003 | 11:27 AM
I think the implication is that there is a speed-based rev limiter.
Old Dec 3, 2003 | 07:17 PM
BaronVonBigmeat's Avatar
Senor Carnegrande
Heh, is the sharp power dropoff at 9000 RPM's due to the engine itself, or the ECU cutting power back? I wonder how much (if any) extra the Renesis is capable of revving without self-destructing...If they could lean out the top end, plus take off the rev limiter and safely go to 10,000 RPM...drool...
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
paporx8
Nov 5, 2015 07:20 PM
stickmantijuana
Rotary Swaps
11
Sep 24, 2015 12:47 AM
stickmantijuana
Non-Rotary Swaps
Sep 19, 2015 03:15 PM
