Should i install turbo kit @ 70,000 miles
Old Sep 17, 2008 | 04:48 PM
SHINKA RX8's Avatar
i was going to install the greddy turbo kit with int-x but my rx8 has 70,000 miles on it, and it is well maint. oil change every 1,500, ingnition coils every 20,000 miles what do u think. should i or should i not. also i drive the car every day but i dont drive it hard.
Old Sep 17, 2008 | 07:00 PM
simplyphp's Avatar
What year? Has your engine been replaced yet? If you engine hasn't been replaced yet go have a compression check done and have them do a full inspection of all your car's engine components. I would be weary of putting a turbo on a 70k engine that wasn't replaced, unless its' an 06. But an 06 with 70k miles seems unlikely.
Old Sep 17, 2008 | 07:11 PM
zoom?'s Avatar
bro your car can take it but plan on redoing the apex seals soon if not do them now its not e.z but if you can think you can do it
Old Sep 17, 2008 | 07:42 PM
SHINKA RX8's Avatar
Its a 2004 and the engine has never been replaced every engine component is up to date.
Old Sep 17, 2008 | 07:57 PM
05rex8's Avatar
sold the 8... :(
get a compression test, if passes, go for it
might as well enjoy the car while you have it, and turbo is going to raise the fun factor immensely
Old Sep 17, 2008 | 11:41 PM
hakuna matata!
if your engine is healthy (compression).. there is absolutely NO reason why you shouldn't if you can..
DO NOT CHEAP OUT though.
Old Sep 18, 2008 | 10:15 AM
SHINKA RX8's Avatar
Im going to get the compression test today and if its good the turbo kit is on its way asap. thanks guys
Old Sep 18, 2008 | 11:37 AM
NgoRX8's Avatar
good luck.
Old Sep 18, 2008 | 03:03 PM
CyberPitz's Avatar
Huge hole is huge
Good luck, man. Lets hope for another turbo'd 8!
Old Sep 18, 2008 | 06:29 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah if the compression looks good boost that **** up
Old Sep 19, 2008 | 03:06 AM
kersh4w's Avatar
Hit & Run Magnet
usually people lower the compression in their engine before boosting.
Old Sep 24, 2008 | 09:07 AM
renesisking's Avatar
i have a question, my rx8 was recently dynoed i have an 04 grand touring 6spd, and i got chassis dynoed by a dyna pack protable one, (yes i know they are not that accurate[/i]) but, i lost a significant amount of power. I saw online on my fone at myrotarycar.com stock was running 178.4 hp, and 134.4 torque. My numbers were quite dismal with 148 hp to 128 torque. There is oil in my intake filter, but when i took out my intake filter i was still running consistant numbers. I was told to get a compression check done, but i was told it is probably not the case, i was also told that my CAT's could be bad and are impeding flow into my exhaust so i might need a whole new cat and a catback, but i am still not able to figure out how oil is going into my intake. Can anybody help me out? Tips? Advice? I ran synthetic in my car but i called up a mazda dealership nearby and they said "run regular oil, its a rotary, just run normal 5w-20" and i told them that one of their techs told me that i could run my car on regular but the guy at the dyno said just run premium, and that I'll get better curves and it'll unclog my injectors. Heres the low down on my car.
2004 Mazda RX8 6MT
stock, except for clutchmasters FX100 clutch.
Regular gas, and synthetic (which i plan on changing to regular)
Old Sep 24, 2008 | 03:42 PM
hakuna matata!
^ coils, plugs, wires, seafoam de-carb, bgk44
then dyno again.. (follow the proper dyno procedure.. make sure abs/dsc isn't kicking in)
how many miles anyway?
Old Sep 24, 2008 | 03:49 PM
Brettus's Avatar
Boosted Kiwi
2004 Mazda RX8 6MT
you're all over the place like a mad womans lipstick .
Old Sep 24, 2008 | 06:39 PM
Musker's Avatar
Can having bad coils, plugs, and wires cause an engine's compression test to read less than if the parts were brand new?
Old Sep 24, 2008 | 06:41 PM
CyberPitz's Avatar
Huge hole is huge
No, because when doing the test, you remove the spark plugs deleting the whole plug/wire/coils from the equation.
Old Sep 24, 2008 | 06:52 PM
Musker's Avatar
I see... so doing a compression test before buying new plugs, wires, and coils, would be the smartest way to do it, depending on how much you're getting charged for it.
Old Sep 25, 2008 | 10:30 AM
my car as 65k approx and i put in stock plugs less than a year ago, (i think stocks are NGK) and yea i did turn off my trac/dsc and what is bgk44? i had my cats checked and my intake manifold, and everything checked out fine by my dealer techs but i am taking it to mazda still. i was told from another post that my intake air flow might need a clean up, and the blowback is from an oil hose connected to the intake and that i should get an oil can catch. anybody know about those?
Mxttz0r
Jul 5, 2019 03:19 AM
jay_tibo
22
Sep 13, 2016 08:10 PM
MolecularConcept
Aug 5, 2015 04:43 PM
k4thomas
Aug 5, 2015 03:03 AM
kaboshe
Jul 17, 2015 03:14 PM
