Burned CD Problem
Old Nov 27, 2003 | 09:11 AM
Marcus Desaul's Avatar
Burned CD Problem
Last night I burned a CD from MP3s on my computer. Switched them to CDA files so a normal CD could recognize them, but when I put the CD into the 8, the system didn't recognize it and spit it back out.
Anyone have this happen to them and if so...did you find a way to make it work?
Old Nov 27, 2003 | 09:33 AM
KC_RX-8's Avatar
i had that same problem with mine.... it either spit it out of if you changed tracks, it took FOREVER!!!
solution: burn your cd's slower.... use 2X if you have to but every cd i've burnt after that has worked perfectly!!
hope that helps. good luck!
Old Nov 27, 2003 | 02:55 PM
brothervoodoo's Avatar
RainMan is Back
Can't say I've had a problem with burning .cda tracks specfically for CD Players. I have a Plexwriter and it burns fine at 8x. Maybe you haven't fully finalized the session, and some older cd players might have a hard time reading? I remember back in the day that slowing the burning process used to help in some applications. Good luck.
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
WranglerFan
Aug 21, 2022 01:29 PM
OnebaddRx8
Aug 25, 2019 11:34 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Vedivan1
Sep 18, 2015 12:39 PM
