Centerforce Clutches
Old Jul 6, 2008 | 09:38 PM
brandonrhodes's Avatar
brandonrhodes
Okay, I'm about to replace my clutch cause the dealership says that it's going bad. My philosophy is go big or go home so since I'm going to be eventually putting more and more power upgrades on my car would it be safe to go ahead and get the Dual Friction clutch kit and if so what flywheel should I get?
Old Jul 6, 2008 | 10:07 PM
paulmasoner's Avatar
Asshole for hire
i would PM Charles R. Hill.... he is our resident drivetrain man, as well as many other things. He also has some great connections with his company Black Halo Racing. You can discuss with him what kind of power you are eventualy lookign at and help you spec out the right clutch. No pun intended, you'll get that later... lol
Old Jul 6, 2008 | 10:46 PM
05rex8's Avatar
sold the 8... :(
+1 on Charles R. Hill. Great guy, he will get you what you need for sure.
--Jonathan
Old Jul 7, 2008 | 10:46 PM
I have the center force HD works great.
I would have gotten the BHR but it wasn't available.
Old Jul 7, 2008 | 11:27 PM
Listen to CRH, that guy knows what he is talking about.
Old Jul 8, 2008 | 12:11 AM
hakuna matata!
easy there cowboy..
Old Jul 8, 2008 | 03:11 AM
bse50's Avatar
#50
Remember that we have a very fragile transmission, a clutch that is too aggressive in terms of engagement will reduce your tranny like a lot.
There are different ways to make a clutch capable of high numbers but not all are the same in terms of engagement. Again, you should contact Charles since he told me about my tranny problems before i even had them, and now i have my transmission sitting around in the box
Old Jul 9, 2008 | 10:29 PM
brandonrhodes
Okay, thanks for all the advice. I'm going to look into getting the BHR or Mazsport's then and if you wouldn't mind helping me find the right one that would be great. Thanks for the help!
Brandon, I made this same mistake 4 years ago in getting a clutch that was WAY overrated for the RX-8. Like a 600 h.p. clutch, and all it did was accelerate the wear of the clutch pedal bracket. That is how we have discovered them to be weak and failing. There are two options available to alleviate this issue and I encourage EVERYBODY to pursue either BHR's or Mazsport's offerings for clutch pedal assembly strengthening. Lest you think I am merely trying to sell you something you don't need, the problem I speak of is rampant and you can search it on this forum.
As for your clutch and flywheel, if you want to "go big" the BHR clutch and flywheel combo are the lightest rotating mass combo you will find without having to go with billet aluminum(expensive) and I can help match you up with the clutch that will serve your needs now and in the future. If you would like references, please contact "RX8Thunder" and "ssspeedfreak" as they both have BHR clutch/flywheel kits installed and they are driving them.
Old Jul 10, 2008 | 10:35 AM
Outkast187's Avatar
I know my experience with the centerforce clutches (on different vehicles) is that they lock up much harder. Sounds great, till you are driving in a parking lot looking like you have never driven a stick. Not sure how they are on the 8 though.
Old Jul 10, 2008 | 10:50 AM
Red Devil's Avatar
Hmmm...I had a dual friction on one of my RX-7s and it was flawless. Only thing I didn't like was their recommended break in period - which took way too much of my patience...
Old Jul 10, 2008 | 11:09 AM
bse50's Avatar
#50
Harder lock up means shorter gearbox life in a fragile transmission. Ours is pretty fragile so i would prefer the softer-closer to stock engagment possible, especially on a hard driven car.
I can tell that according to my experience with broken gearboxes but i might be wrong as well
Old Jul 10, 2008 | 07:05 PM
brandonrhodes
Well I defiantly wouldn't want to do anything to mess up other parts of my car. At the same time I do want to go ahead and upgrade this part of my car to be ready for the future upgrades that will be applied.
Old Jul 11, 2008 | 10:56 PM
Outkast187's Avatar
Exactly. Centerforce probably takes that into account when they build the clutch for it, I'd hope anyway.
Old Jul 29, 2008 | 10:07 PM
Urban Legend's Avatar
Make Some Noise
Yeah stick with this clutch because I loveeee.....drag racing my car and this clutch won't wear your transmission as much as the centerforce clutch could.
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
