turbo manifold idea...
Old Jun 22, 2008 | 05:03 PM
neit_jnf's Avatar
use the front and rear ports for a divided turbo manifold like previous rotaries and use the center port just for the wastegate?
what do you think? too much restriction until the wastegate opens?
Old Jun 22, 2008 | 05:11 PM
Brettus's Avatar
Boosted Kiwi
Interesting idea - what advantage do you see ?
thinking about it some more - it won't work .
Old Jun 22, 2008 | 05:37 PM
That would be a huge restriction to the exhaust unless the wastegate was open.....won't work
Old Jun 22, 2008 | 08:00 PM
neit_jnf's Avatar
well, the center exhaust port is significantly smaller than the other two so at low rpm and load it shouldn't be of much impact to performance except maybe increasing velocity at the other ports (good for spooling)
then, having a divided manifold could be good for better spooling a turbo with a divided exhaust housing and when the center port wastegate opens it controls boost without disrupting the main flow to the turbo...
Old Jun 22, 2008 | 09:23 PM
Brettus's Avatar
Boosted Kiwi
at maximum rpm and boost you are going to be significantly restricting the exhaust - wont work .
Old Jun 22, 2008 | 11:07 PM
chickenwafer's Avatar
Nope
It's still not redirecting flow away from the turbo, that's how a wastegate controls boost. If the wastegate is shut, the exhaust will just exit out of the other port.
It's like putting a wastegate on a single exhaust valve of a dual exhaust valve piston motor. Won't work.
Old Jun 23, 2008 | 08:10 PM
rotarygod's Avatar
Not going to work.
Hunterkelley24
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
05rx8mazda
Nov 28, 2015 09:42 AM
MolecularConcept
11
Sep 29, 2015 09:21 PM
Evan Gray
Sep 26, 2015 12:30 PM
