Nitrous Install Going Down Next Wed. Any Comments Appreciated...
Old Jun 13, 2008 | 01:37 PM
0_o Flash's Avatar
I am having my nitrous installed next Wed. I was wondering if some of the other Nitrous users would have some helpful hints for me. I'm having a local yet very reputable shop do it for me, but they have been given a copy of all of Charles R. Hills instructions / suggestions to follow. The guy I got the kit from said he could only run a 35hp shot. I am looking to run the 55hp shot. If in the event something goes wrong, what am I listening for when I do my first trial run with it? What can I expect? What should I do if I hear something abnormal?
Kit being installed includes =
* Zex 8021 Wet Kit
* Zex Remote Bottle Opener
* Zex Bottle Heater
My Mods =
* K&N Drop in Filter
* AP Pulley
* Greddy Pullies
* SR Motorsports Mid-pipe
* Greddy SP2 Exhaust
* Cobb Access Port ( Still running Jeff's baseline tune b/c he has been so busy he has yet been able to check my settings and send me another level tune )
Also one last question. Has Jeff released a Nitrous map yet that advances timing to allow for a 65 or 75hp shot to be stable???
Please only post if you are going to provide some experience or words of wisdom.
Old Jun 13, 2008 | 02:56 PM
Rote8's Avatar
The sound of Crickets?
Ray?
Calling Dr. Hill.....
Old Jun 13, 2008 | 03:01 PM
0_o Flash's Avatar
lol thanks Rote8 I have read, re-read, talked via the phone with him and I feel the performance shop has a clear understanding of the install. I'm just more-or-less worried about what I need to listen for to ensure it's running right. I'm getting 6 HP pulls on the dyno for free. I want to do 3 for a Baseline and the other 3 w/ Nitrous. I just don't want my engine to go BOINK
Old Jun 13, 2008 | 03:28 PM
laythor's Avatar
I zoom therefore I am.
looks like Jeff is doing a live swap for at least the next day... http://mazdamaniac.camstreams.com/
Just be careful with your shots, you have 3 runs to tweak it so use em.
Old Jun 13, 2008 | 06:59 PM
jones75254's Avatar
^^ And be sure that once everything is installed and ready for a test run that you turn car on, pressurize the system (use remote to open the bottle) and THEN get out of ur car, go back and inspect the connections for leaks as well as pop the hood and check for any leaks.
Luckily ol Ray has good hearing cuz when we went out for the first test run he could here the low "hiss" of a small leak in the trunk and we were able to torque that connection tight prior to making the run......remember that Ray? he he ahhhh nostalgia
Old Jun 13, 2008 | 08:31 PM
0_o Flash's Avatar
My esteemed colleague, MazdaManiac, doesn't know JACKSHIT about nitrous so you'd be talking to a brickwall if you ask him anything about it(and that's if you can get him to respond at ALL!). I still love him like a brother, anyway.
Flash, it has been proven time and time again that; 1) The RX-8 will easily handle a 55 shot but 65 and 75 are not recommended, and, 2) You would need ignition advance REDUCTION to use larger shots than 55. The AP hasn't yet been configured by MM to safely use larger shots.
Have the shop call me if they have issues or questions.
Will do Charles. I really appreciate all the guidance you have given me. I have put my old K&N on for them to tap into the intake. Once I receive your spacer, the stock intake is going back on.
Thanks Jones. They are giving me 3 hp runs on the house and they said I could get 3 more for a Baseline & w/ Nitrous numbers. Would it be a good idea for me to use the trial run on a dyno?
Old Jun 14, 2008 | 03:32 AM
tajabaho1's Avatar
Destroying Threads
1. get the BHR spacer so you don't really have to drill a hole in your intake
2. whatever you do don't cut the f'ing stock fuel line
3. open the gas hatch for a while to let the pressure bleed out, whatever anyone says, this is ******* true and evidence by the shitload of fuel squirting and not squirting when I did my install and uninstall and then install again
4. set the solenoid WOT before you place in the lines
5. make sure everything is tight unless you want a fireball on the highway
Old Jun 14, 2008 | 09:03 AM
Rote8's Avatar
How does one install a wet shot without tapping into fuel somewhere?
Are you suggesting a separate fuel tank in the trunk for use by the Nitrous?
No, I am not being sarcastic.
I am thinking of adding a small Nitrous shot soon and want to be clear on what is required, and how to do it correctly.
Old Jun 14, 2008 | 09:13 AM
tajabaho1's Avatar
Destroying Threads
no I suggest you go get yourself a new fuel line, only costs 20-30 bucks man, trust me
2-3 8s already burned because of tapping the stock fuel line
Old Jun 15, 2008 | 09:24 AM
tajabaho1's Avatar
Destroying Threads
my car counts as 2 :D so yea, 2-3 cars
Old Jun 15, 2008 | 01:58 PM
laythor's Avatar
^ lawlocopter!
Old Jun 15, 2008 | 03:42 PM
Easy_E1's Avatar
Waiting to see results. My kit's on the way,,,,,,, still.
Old Jun 15, 2008 | 04:05 PM
tajabaho1's Avatar
Destroying Threads
....and all this time I have been using you as a shining example of the reliability of the Zex kit and my installation guidance.
well, the reliability of the kit is top notch, seeing as it survived my endless destructive nature for this long
your installation guide obviously worked, if not my car would have been destroyed by now :D
Old Jun 15, 2008 | 08:53 PM
0_o Flash's Avatar
Late next week, E. As soon as I get the TN I'll pass it along.
You going to be in TN Charles? You should take a trip over here to NC and see me, maybe make sure my install is set up right. I obviously would compensate you for your time.
Old Jun 16, 2008 | 11:29 AM
Cattywampus's Avatar
Turbos blow!!
Old Jun 16, 2008 | 01:59 PM
0_o Flash's Avatar
**** happens...on your site you have your spacer for "100,00" I just mis-read it damn
Old Jun 16, 2008 | 04:18 PM
0_o Flash's Avatar
LoL no harm done I was just messing w/ ya back charles. I have talked so much about you that these guys are getting aggravated at me lol Oh well I want it done right. Can't wait till your spacer gets done, I think it's gonna look a hell of a lot cleaner
Old Jun 17, 2008 | 12:22 PM
Rote8's Avatar
Um, I seem to be missing something here.
1) Don't use stock fuel line.
2) Buy new stock fuel line, use that.
Again, what/where DO you tap?
Old Jun 17, 2008 | 12:32 PM
tajabaho1's Avatar
Destroying Threads
uhhhh, well, don't buy STOCK fuel line, buy a better fuel line
see the problem when you splice the stock one is that sometimes it slips and uh, bad things happen
Old Jun 17, 2008 | 06:31 PM
jones75254's Avatar
It was actually at the module.
....smartass
Old Jun 27, 2008 | 09:53 AM
tajabaho1's Avatar
Destroying Threads
psh.......rules are made to be broken, Ray!!!! oh ****!v why is my car on fire!?!?
yurcivicsux
192
Sep 12, 2017 10:54 PM
Jelliott5384
Oct 26, 2016 05:15 PM
Brokegang
Jan 3, 2016 12:45 PM
