grinding in reverse
Old May 30, 2008 | 09:57 PM
vad6's Avatar
Question grinding in reverse
Occassionally hearing a grinding noise in reverse...any ideas? Tranny or brakes. How to determine, hmmhttp
Any insights?
Old May 30, 2008 | 10:26 PM
kersh4w's Avatar
Hit & Run Magnet
when you give gas, keep holding on the shift **** and pull it fully into gear
Old May 30, 2008 | 10:32 PM
chancejat's Avatar
Drive it like u stole it!
ha, mine does the same thing, like he said keep pressure and slowly let out the clutch,
Old May 30, 2008 | 11:45 PM
Rootski's Avatar
DGAF
Reverse has no synchro and should mesh best at idle. You might be bumping the throttle a little when you hear that grind, or have a slightly out-of-spec gear.
Old May 30, 2008 | 11:50 PM
KostasNK's Avatar
The reverse gear doesn't have synchros,so when you put reverse in you can hear some grinding. To resolve this, press the clutch put 1st, put it into neutral and then put the reverse gear.
It wont happen again this way...
:D
Old May 31, 2008 | 10:58 PM
vad6's Avatar
Thanks...will give the suggestion a try and see. Doesn't happen all the time, just occassionally.
Old Jun 1, 2008 | 12:38 AM
CyberPitz's Avatar
Huge hole is huge
I guess I learned something new today. Mission Accomplished!
Old Jun 1, 2008 | 12:39 AM
04RX8man's Avatar
Rotary Powered Countryboy
I always put it in and out of reverse about 2 or 3 times to b sure it is in so i don't grind into reverse.....
Old Jun 1, 2008 | 12:48 AM
Renesis07's Avatar
Vtak just kicked in yo!!
if you put it in and let off the clutch SLOW, you will feel it engage and youll be all good.
Old Jun 1, 2008 | 01:16 AM
Spinning Sushi's Avatar
I <3 Sushi
I tend to pop it into neutral, clutch depressed, rev it a bit, press on the clutch, then go into reverse. It seems to work every time for me.
Also known as double clutching.
Old Jun 1, 2008 | 03:22 PM
KostasNK's Avatar
You have to do all that I said above while pressing the brake pedal, so the car won't move! It eliminates the grinding while engaging reverse gear.
The only grinding I had one,or two times was while engaging reverse not in any other occasion!
Old Jun 1, 2008 | 10:15 PM
Tbolt's Avatar
Tbolt
Hey sweet I thought only mine made this sound. I pretty much do the same now, I cycle through a few gears after start up like into 1st, then 2nd, then 5th etc and then into reverse. I just be overly deliberate when shifting into reverse, and when I see the white lights reflect off the wall in my rear view mirror then I know I am all the way in reverse.
Old Jun 1, 2008 | 10:24 PM
1.3L's Avatar
Any insights?
To avoid grinding noises when shifting to reverse:
1. make sure car is not moving
2. depress clutch fully and wait 2 or 3 seconds
3. move shifter to reverse
Side notes: the 2 to 3 second pause is for a warm transmission. When the tranny is cold, 1 or 2 seconds will suffice. Also, press the clutch pedal to the floor.
-1.3L
Old Jun 2, 2008 | 06:56 AM
claus's Avatar
Lightbulb
οkay, all the above are great advice, here's the last one:
i guess the reverse on the 6-speed gearbox is far right and back; right? (i am on a 5-speed 192 one)
when stationary, switch to 2nd or 4th gear before switching to reverse... !!!
that will take care of the problem as well !!
problem is i did 40K klm not doing it before my gearbox stopped grinding on its own...
Old Jul 27, 2011 | 06:41 PM
stahlstern89's Avatar
Bad news for people here... rx8s do in fact have reverse synchros. I just replaced my reverse synchro and it still grinds if im not careful. :/
Old Jul 28, 2011 | 05:06 AM
ken-x8's Avatar
How does a reverse synchro work?
No diagram of the gears in the shop manual (at least not in the version I have), but part of the procedure for checking the clutch engagement point is to try going into reverse and see whether it grinds. Not exactly behavior I'd expect for a gear that has synchromesh.
Ken
theblinkof
Oct 4, 2023 05:24 PM
mitchrx8
Sep 13, 2015 08:05 AM
airlive
Sep 7, 2015 08:32 PM
superROB23
Sep 4, 2015 01:22 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
