rolling fender or stiffer suspension???
Old May 18, 2008 | 12:58 PM
djkrazy's Avatar
Cutting the Road & Wax
I got from axis 275 (in the rear) that cause some rubbing on the itrees when i hit bumps and oither things on the road. I was told that one of the ways to avoid the problem is to roll the fender. another way is to get a stiffer suspension for the car ...... the question is if anyone else had that problem and which would be better.
Old May 18, 2008 | 08:15 PM
nuke0907's Avatar
Never Blend In
why would you put 195mm. wide tires on an RX8?
Old May 18, 2008 | 08:35 PM
kersh4w's Avatar
Hit & Run Magnet
how would you have problems with 195s?
stock is 225 and most people run 245s....
Old May 18, 2008 | 08:40 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
WTF???????????????? Give us all the dimensions of your tires and wheels.
This should be interesting.
Old May 18, 2008 | 08:50 PM
Macius8's Avatar
I dont think they make the tires stated in his sig in the size he mentioned. Think he meant 295s
Old May 18, 2008 | 08:53 PM
Mazurfer's Avatar
Ahhhhhh................I didn't notice that.
Yeah..................probably a typo!
Old May 18, 2008 | 08:55 PM
LionZoo's Avatar
road warrior
Originally Posted by djkrazy
I got from axis 195 (in the rear) that cause some rubbing on the itrees when i hit bumps and oither things on the road. I was told that one of the ways to avoid the problem is to roll the fender. another way is to get a stiffer suspension for the car ...... the question is if anyone else had that problem and which would be better.
Going to a stiffer suspension is a band aid solution. If your tires rub, going to a stiffer suspension won't cure rubbing as there will always be instances when you're into the bumpstops. It might decrease the frequency of rubbing, but the problem will still be there.
Old May 18, 2008 | 08:58 PM
Mazurfer's Avatar
^+1 on that.
Assuming you are 295........you need to roll the fenders.
Old May 19, 2008 | 10:30 AM
djkrazy's Avatar
sorry about the confusion and the typo in the thread ... my rear spec are 18 X 9.5 and 275 .... 18 X 8.5 and 245 in the front but there is no problems in the front
Old May 20, 2008 | 01:42 PM
Mazurfer's Avatar
I'm 255 wide in the back right now on 18 x 9.0 and I have some minor rubbing with my 1/2 inch lowering on RB springs but it's so minor I haven't had to do anything.....YET. A lot will depend on your offset........mine is a little strange at +38mm.
I can see how you would rub at 275(offset depending) and I think rolling is still your best option.
Old May 20, 2008 | 01:51 PM
NgoRX8's Avatar
the most important thing is offset.
i assume your offset isn't so low that rolling will alleviate the problem. if so, roll it, and have the tab where the bumper bolts up to the fender either flared or shaved.
Old May 20, 2008 | 02:23 PM
1. buy the proper wheels
2. roll fenders
3. stiffen suspension
4. drink bleach
Old May 20, 2008 | 10:20 PM
NoPistonZ's Avatar
20BWannabe
You don't necessarily have to roll the fender from well to well. I just need to roll a 9" lip center top outwards. I'm on rear 18x9.5 +35 with 275/35/18. on Tein S-Techs.....Depends on your offset, tires and drop.
I just drank bleach.
Old May 21, 2008 | 11:05 AM
djkrazy's Avatar
I am going to roll over the weekend .... i think .... i just hope that I dont crack the paint
Old May 21, 2008 | 12:13 PM
BoosTED's Avatar
I just saw tirerack sells a fender rolling tool now.
Old May 21, 2008 | 12:17 PM
BoosTED's Avatar
Here is a DIY on rolling the fenders. http://www.mazda6tech.com/index.php?...id=17&Itemid=1
Hmmm heat gun to help minimize cracking of the paint. Would that actually help that much?
Jst4fun
Apr 17, 2021 07:43 AM
hufflepuff
May 30, 2016 10:45 AM
RX-8 Racing
20
May 14, 2016 06:25 PM
duworm
Oct 1, 2015 04:57 PM
