Ideas for a BOV recirculate fitting?
Old Apr 2, 2008 | 08:48 PM
tdiddy's Avatar
Finally Boosted!!!!!!!
I am thinking about trying to recirculate my BOV and I am looking for ideas on how to attach a 1" silicone hose to the silicone 90 that is between my MAF and my turbo in this picture. I would like as little of an airflow restriction as possible. Any ideas would be greatly appreciated and links to the parts would be even better. Thanks!!!
Old Apr 4, 2008 | 12:24 PM
Romeo's Avatar
...I'm SOOO Off Topic
thats tough. Ive heard people tapping right into the Silicone.... but I dont know how solid that is. especially with a 1" hose.....
hmm, good question.
Old Apr 4, 2008 | 12:42 PM
mysql's Avatar
Doppelgänger
not much space there, but you might be able to squeeze in a metal 90 elbow and tap into that...
http://www.atpturbo.com/Merchant2/me...egory_Code=PPB
if not, you might also be able to get a one off made that has a 90 elbow coupler with a 1" hose coming out of it. my friend with an audi s4 has silicone hoses that look like that.
Old Apr 4, 2008 | 12:44 PM
mysql's Avatar
Doppelgänger
like ..
Old Apr 4, 2008 | 12:48 PM
chickenwafer's Avatar
Nope
I would first flip the BOV around 180 degrees so it's facing the back of the engine compartment. The SSV is held in place with a PITA snap ring so that's easy enough to do, you don't have to worry about bolts lining up and such.
Then a metal pipe like Jason suggested would probably be the best bet.
Old Apr 4, 2008 | 12:51 PM
mysql's Avatar
Doppelgänger
and ceramic coat those pipes...
today I'm going to try out the duplicolor spray paints that have ceramic in it. Ceramic paint and ceramic enamel .. worse case I wasted $15 for 3 cans of the stuff.
Old Apr 4, 2008 | 01:25 PM
Romeo's Avatar
yeah, deff turn it 180degrees, lol
mine goes 180 degrees back, around, loopty-loop and down, lol
(camera phone pic)
but it gets the job done.
I would really look into a 90 degree silicone hose with a 1" tapping on it. Im sure somebody makes one.
Old Apr 4, 2008 | 02:10 PM
staticlag's Avatar
The Professor
http://www.marinedepot.com/ps_ViewIt...ct~FT1111.html
Long live front mount turbos !!!!
Old Apr 4, 2008 | 02:11 PM
staticlag's Avatar
The Professor
So cut the hole, insert the fitting from the inside, screw down the collar, then you can attach some hose to the threaded nipple.
Old Apr 4, 2008 | 03:45 PM
Romeo's Avatar
awesome!
thats definetley something I would do if I was in your situation. Looks pretty solid and easy to me
Old Apr 4, 2008 | 09:39 PM
tdiddy's Avatar
Thanks for the suggestions. I have something similar to what Static suggested but it will be a while before I get to install anything. Take a look...
https://www.rx8club.com/showpost.php...&postcount=322
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
nferguson88
Oct 6, 2015 12:45 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
GK1707
Sep 27, 2015 07:33 PM
