It cranks, but does not fire ??
Old Dec 16, 2007 | 11:49 AM
solidgold5's Avatar
Angry It cranks, but does not fire ??
Ok, so last night I tried to start up the 8 after about 2 days not driving it. It has been sitting outside, and temps are hovering around freezing.
Anyway, I would turn the key and it would keep cranking over but it would just not fire and come to life. I heard a few pops and such like it was trying to start, but no such luck. I did what the drivers guide said, WOT for 7-8 sec while cranking, and still nothing. So now I am charging up the battery and hoping some of you more experienced rotory guys can point me in the right direction. I would like to try hard to stay away from the dealer and do my own work if that is possible.
Old Dec 16, 2007 | 12:51 PM
DarkBrew's Avatar
Extraordinary Engineering
Are you under warranty? What year/mileage?
Could be flooded. Read this thread
https://www.rx8club.com/series-i-trouble-shooting-95/engine-flooding-info-questions-17498/
Has your car had all of the ECU updates (warranty)
https://www.rx8club.com/series-i-trouble-shooting-95/technical-service-bulletins-tsbs-recalls-rx-8-a-14453/
Old Dec 17, 2007 | 12:57 PM
dmorales's Avatar
Spin Triangles! Spin!
Also, check your battery. yes it can turn over and still not start cause of a battery. I learned that the hard way once.
________
OG KUSH SEEDS
Old Dec 17, 2007 | 04:29 PM
shakeyourbrakes's Avatar
mine did the same thing today, pops but no start no matter how much i tried. I went for the flooding theory and tried the DIY for washer fluid squirted into the intake port...butt my washer fluid lines were frozen over. I then resorted to hooking up with jumper cables to another car and cranking it, actually pumping the gas pedal at the same time. Finally got it to choke a lot then start, and has been fine since. I dont know, that was my procedure to get it started today, never had that happen before though.
Old Dec 17, 2007 | 04:49 PM
tajabaho1's Avatar
Destroying Threads
put a torch to it, it'll fire up in no time
jk jk, flooded?
Old Dec 18, 2007 | 03:27 PM
Parz's Avatar
Sounds like it is flooded, you will have to tow to dealership to get fixed
Old Dec 18, 2007 | 04:20 PM
Or tow it for about a block ....seriously...do a search!
92trbolzr
May 18, 2025 09:04 AM
theblinkof
Oct 4, 2023 05:24 PM
DylanForbes
25
Oct 31, 2017 05:47 PM
duworm
Oct 1, 2015 04:57 PM
Luke.s
Sep 30, 2015 05:57 PM
