88' 89' 90' differences Rx7
Old Nov 25, 2007 | 02:46 PM
AkinaGod's Avatar
I was wondering what the frame work differences were for the FC model RX7 with the year 88' 89' and 90'. Also do they make a 91'? Someone said they did and I can't find any. Just need to know like frame differences, exterior, and if you know anythign different with the inner workings let me know that, too.
Old Nov 25, 2007 | 03:51 PM
SayNoToPistons's Avatar
Wheels, not rims!!
"Frame differences"?...
http://mazdamark.com/about_the_fc.htm
http://www.rx7club.com/showthread.php?t=642372
Read up.
Old Nov 25, 2007 | 09:28 PM
Tessai's Avatar
88 = series 4
89, 90, 91 = series 5
s4 and s5 have different tail lights, bumpers, and side moldings (s4 = black, s5 = body colored)
Different gauge clusters and steering wheels.
Different external mirror shapes.
Slight differences in engines.
Be more specific... what trim are you looking at? What do you want to do with the car?
MOD EDIT: BE NICE. YOU HAVEN'T EXACTLY BEEN AROUND LONG ENOUGH TO CRITICIZE ANYONE YET!
Old Nov 26, 2007 | 01:03 PM
AkinaGod's Avatar
Originally Posted by Tessai
88 = series 4
That sounds about right. I thought so. Looks like i will be look at 89-91 then. Thanks. O and was this for me? "MOD EDIT: BE NICE. YOU HAVEN'T EXACTLY BEEN AROUND LONG ENOUGH TO CRITICIZE ANYONE YET!" Because I haven't a clue what your talking about if it is...
Also thanks for the links from the previous post. Checked them out too.
Old Nov 26, 2007 | 11:43 PM
Tessai's Avatar
Mod edit was for me, seems they took out a comment regarding the expense of aftermarket parts for the FC vs. those of the 240sx.
Why they couldn't send me a PM is beyond me. I've been here for over a year, I've been around enough.
Old Nov 27, 2007 | 01:43 AM
Archie's8's Avatar
Junior Member
I don't understand the mod edit; he was spot on and a 1+ yrs (not including 7club is modest, at least). Does he have to be a ******* grandpa to correct somebody??
This site is ghey. Let's see how long it's left. Probably forever over principle. ****....
Fact > Opinion!
Old Nov 27, 2007 | 09:33 AM
cool_as_crap's Avatar
from the 7 club
Because what do you know about fc's? You've only owned 2
Old Nov 27, 2007 | 11:20 AM
Tessai's Avatar
Old Nov 28, 2007 | 09:26 AM
MmSadda's Avatar
LOL you guys actually want to criticize a previous FC owner for his knowledge about his cars? Tessai knows his stuff, and knows it well; If he wants to make a comment about FCs, I would listen.
Old Nov 28, 2007 | 10:58 AM
AkinaGod's Avatar
Tessai. I was looking at FC's on Craigs list and found an 89' with small turbo mod. Either that or it was one of the Turbo II's. I forget. But anyway he says it runs rich and the second igniter runs just a bit of lag at first until it starts up. Is this something I should be concerned about or is it an easy timing issue I can fix without worry and cost? Says he has driven it with his new engine 3600 miles and the new engine didn't run boost till 1500 miles. That is all he sent me in an email. Anything else you need to know I can ask him. Better yet... What else should I ask him?
Old Nov 28, 2007 | 11:54 PM
Tessai's Avatar
#1 thing to do is to ask for compression numbers
The igniter thing is a little odd... typically, the FC coils are robust and don't tend to fail. Its possible that it is bad, but I'd look it over because it could be another issue.
Find out if a turbo engine was swapped in, if it is a turbo II, or if he added a turbo. The non-turbo and turbo motors run different compression ratios, so if he boosted the non-turbo motor without proper fuel/ecu mods it could be a time bomb. If he swapped the motor, find out what else was swapped. The entire turbo drivetrain is different, with the turbo transmission being quite beefy.
No boost for the first 1500 miles sounds like he broke it in properly, which shows he's at least taking care of it.
Most FC's run rich from the factory. Rotaries don't like to lean out, and detonation is deadly.
Things to check out before buying, for a turbo car:
http://www.aaroncake.net/RX-7/buy2.htm
General FC:
http://fc3spro.com/TECH/h2b.html
Non-turbo (contains some good general information)
http://www.aaroncake.net/RX-7/buy1.htm
Old Nov 29, 2007 | 12:06 AM
RX-GR8's Avatar
hey good information. i'm looking at a 93 RX-7 saturday. prolly won't buy it but i want to at least get a look under the hood and test drive it. i owned an 8 but never a 7. red flag number one is the engine was replaced by mazda(rebuilt) at 38k and now has 43k. rebuilt turbo too i think. he wants 14k i wouldn't go a penny over 12k.
Old Nov 29, 2007 | 12:13 AM
Tessai's Avatar
The FDs (93+) had issues with the eleventy-billion vacuum lines needed for the sequential turbo setup. A lot of mazda techs in the day couldn't figure out the problem, so they'd just call the motor dead and replace it.
Not saying that is what happened to the FD you saw, but it happened. I'm not much for the FD info, so I point you here:
http://www.rx7.org/Robinette/buyaused.htm
http://www.fd3s.net/buying.html
http://www.rx7club.com/showthread.php?t=68640
tbiggybig
35
Jul 14, 2022 06:14 PM
Quiggs321
Sep 30, 2015 05:34 PM
Stubbs
Sep 27, 2015 04:06 PM
