MSD ignition
Old Nov 24, 2007 | 11:36 AM
Clown man's Avatar
MSD ignition
hey,
would it be a better idea to get an MSD ignition or just install an HKS Twin power amp? are they the same thing or No? Also what MSD ignitions models example 6a, sport compact,... would work on the 8. as you can see I have no real knowldge of ignition upgrades. any help would be great
Old Nov 24, 2007 | 11:55 AM
heyarnold69's Avatar
Rotary wanabee
For all those who had an rx 7 -- u understand why ................ do not get an msd!!!
hks is prettier and better er! that and many have used it. Dont worry about the other reasons. ALso hks has a plug n play cable so you can instaull it yourself and not one single wire needs to be spliced.
Old Nov 24, 2007 | 03:18 PM
staticlag's Avatar
The Professor
there is no MSD that will plug and play work with the rx8. You will have to create your own inversion circuit like mazdamaniac did.
that and his MSD burned out quickly so he went back to stock.
Old Feb 8, 2008 | 02:30 PM
ltrx8's Avatar
04 Silver GT
This is from other thread I'll let you know how it goes..
Ok this may change everything..Just got some advice from tech at MSD .. This guy is a rotary nut and said he had a excellent solution that will work guaranteed. Set-up is as follows:
2 MSD part # 6302 /INFO:LINKhttp://www.msdignition.com/2007/light.html
4 MSD part # 8207 /INFO:LINK
http://www.msdignition.com/coil_blaster_6_8207.htm
I'm sorry,but this looks like the way I'm gonna go now..This info provided by MSD tech was much needed
and more reliable than frankensteining it..and hoping for the best.. Sorry if this has let any members down..
I will post results / pics when completed. Expect to hear
back from me in couple weeks..
cliffkemp
Dec 24, 2024 10:48 AM
Eraser
Aug 11, 2023 11:31 AM
tjohnmeyer
Sep 28, 2017 05:03 PM
drlubell
Sep 26, 2015 11:58 PM
Sheldon24
Sep 21, 2015 04:53 PM
