Help Please!
Old Nov 22, 2007 | 03:58 PM
RX8 Driver 1's Avatar
Help Please!
Hello everyone,
I've been searching the forums and can't find what I'm looking for. I'm going to be putting some subs on top of the stock bose system for some extra bass. However, I can't find a how-to thread or some help as to removing the stock head unit. Does the RX-8 even have RCA outputs for subs? If anyone can redirect me to a thread or give some information, I'd really appreciate it. I just can't seem to find anything.
Old Nov 22, 2007 | 04:12 PM
expo1's Avatar
He's as bad as Can
This will help in regards to removing the radio https://www.rx8club.com/series-i-do-yourself-forum-73/diy-radio-removal-add-aux-input-36001/ RCA jacks are a custom thing. U might want to find another member with subs and see how they wired them.
Old Nov 22, 2007 | 08:32 PM
juiceRx8's Avatar
Did u Knw Ur Grlz on my..
if u r just adding a subwoofer system, there is no need to remove the radio. All connections can be made at the amp in the trunk under the rear deck. U can grab the signals going into the factory amp and split them into a line driver that will maintain the voltage and run the outputs to both the factory and aftermarket amps. Use all 4 channels to maintain a non-fading sub output. There are other ways to hook this up, however this is the ONLY correct way otherwise you will lose bass output the higher your volume goes.
Old Nov 22, 2007 | 08:37 PM
juiceRx8's Avatar
Btw, I highly recommend an amp with a remote gain or bass EQ ****.
Old Nov 23, 2007 | 02:53 AM
Great! I'm glad you told me that before I started ripping apart my head unit. Are there any how-to threads for doing this that anyone is aware of?
Old Nov 23, 2007 | 06:59 AM
firebirdude's Avatar
User and Abuser
I know you're new..... but there is a FAQ thread at the top of this section....
https://www.rx8club.com/series-i-interior-audio-electronics-24/speaker-sizes-harnesses-kits-etc-audio-install-reference-74664/
Look for the black connector going into the bose amp. Here's the wire colors
https://www.rx8club.com/attachment.p...chmentid=12503
I used the Audiocontrol LC6i for my line out converter. Very happy with. All of this and more in the first link.
