New RX-8 Owner
Old Nov 20, 2007 | 09:21 PM
alexthejew's Avatar
Question New RX-8 Owner
Hello,
I am new to owning an RX-8... I have never owned a rotary vehicle before. So I have a few questions for anyone who is experienced with this kind of car.
I do know that these cars burn oil pretty quick. How often should I add oil to the car? And how often should I drain/change the oil? Can anyone recommend a good kind to use? That's all the questions I have for now... Is there anything else I should know that I probably don't?
If I posted this Thread in the wrong part of the forums, please move it to the correct place.
Thanks,
Alex
Old Nov 20, 2007 | 09:32 PM
Old Rotor's Avatar
The rotary engine is oil injected, if it's not burning oil your in trouble. Please read your Manual. Every thing you need to know is in it . Any good quality oil is fine. There is 1.8gts between the "L" and "H" on the dip stick. Change the oil and filter every 3K or four months which ever comes first. Use the Search Button on the top of the page it works well as does the "STICKY's" mesg....
Old Nov 21, 2007 | 10:15 AM
w0rm's Avatar
PUSHER ROBOT
Do it yourself oil change guide here: https://www.rx8club.com/series-i-do-yourself-forum-73/diy-rx-8-oil-change-dummies-12455/
Old Nov 21, 2007 | 10:23 AM
Currin's Avatar
CopB8
what i have heard about the kind of oil is 5w-20 non-synthetic. because it burns and if you dont get non synthetic then oil will build up and your engine will just quit on you with out warning. i heard this from a mazda dealer.
Old Nov 21, 2007 | 10:58 AM
w0rm's Avatar
PUSHER ROBOT
Mazda dealers say lots of things.
Old Nov 21, 2007 | 11:36 AM
ken-x8's Avatar
Add when it gets low. Typically a quart every 1000 to 2000 miles, but go by the dipstick. Change every 3000 miles or so, definitely not longer than Schedule 2 intervals. Name brand 5w20, API Service SL or better.
There's a FAQ in a sticky that you should read. Answers all of the basic questions, and then some.
Ken
Old Nov 21, 2007 | 03:30 PM
invasion08's Avatar
I would check your oil after every 2-3 gas fill ups and change your oil and oil filter every 3k. Mazda says 5k is ok but its really dirty after 5k, Stick with the 3k. I use Castrol GTX 5w20
Nisaja
Apr 14, 2019 08:04 AM
tigg.z
Aug 26, 2015 09:51 PM
Nisaja
Far East/Asia
Aug 20, 2015 11:51 AM
Eirulisse
Aug 15, 2015 12:34 PM
JPCZONE
Jul 21, 2015 12:02 PM
