Mazdaspeed Sport Spring Consensus?
Old Nov 14, 2007 | 04:34 PM
LionZoo's Avatar
road warrior
Awhile back speeddemon32 tested the Mazdaspeed sport springs and found them to be at a rate that was something like 180/100. https://www.rx8club.com/showpost.php...&postcount=100 Of course, the rate that was previously agreed upon here was 280/190 and some people continue to believe that rate. In addition, I e-mailed a vendor and he told me the Mazdaspeed coilover spring rates are 40% stiffer than the sport springs. Since the coilovers are 400/275, 280/190 for the sport springs would make sense. So with so much conflicting information, does anyone actually know what the Mazdaspeed sport springs are?
Old Nov 14, 2007 | 07:22 PM
gh0st's Avatar
they were measured on a spring compressor. how do you argue against that?
Old Nov 14, 2007 | 10:29 PM
Juice's Avatar
I made some poos
Just Wondering where you got those numbers from? I have not seen any published numbers on the coilovers other than about 90% stiffer than stock. This is from the Mazdaspeed catalog as well as Eibach (The manufacturer). I have never seen any official numbers on the Springs either. Based on my calculations:
Stock as tested by speeddemon:
~160 Fronts
~110 Rears
Mazdaspeed as tested by speeddemon:
~180 Fronts
~100 Rears
Mazdaspeed Coilovers (Using 90% up from stock)
~295 Fronts
~205 Rears
These numbers also coincide with what that vendor says about the springs being about 40% less stiff then the coilovers. The rears are a little off on the Coilover calculations as compared to the MS Springs. But I suspect that the coilovers are the 280/190 as stated pretty much everywhere as the rates for the MS Springs.
Just my 2 cents, you can decide for yourself.
Anyone want to buy the coilovers and test my theories? probably not.
Old Nov 15, 2007 | 12:35 AM
LionZoo's Avatar
road warrior
~160 Fronts
~110 Rears
~180 Fronts
~100 Rears
~295 Fronts
~205 Rears
My 400/275 number comes from a vendor who e-mailed Mazdaspeed about their coilovers. This vendor (bagman1) is for Online Mazda Parts and is on miata.net. I don't think he's here.
Old Nov 15, 2007 | 06:27 PM
Juice's Avatar
I made some poos
Ok, thanks for the info.
Old Nov 15, 2007 | 10:41 PM
devildog1679's Avatar
I have to disagree with these #’s
~180 Fronts
~100 Rears
The reason is that I have the MS springs and the ride after the install was way stiffer and the car felt great on the track. I can’t believe that a 20 increase in the front and 10 decrease in the rear would feel that much different. It has to be more, now how much more I have no idea. All I can say is that from my personal experience they are much stiffer.
Old Nov 15, 2007 | 11:15 PM
LionZoo's Avatar
road warrior
~180 Fronts
~100 Rears
Could the extra stiffness be attributable to the shocks?
Old Nov 16, 2007 | 12:42 AM
Juice's Avatar
I made some poos
~180 Fronts
~100 Rears
Yeah, I have heard many reviews on the springs saying they were much stiffer, I have not tested or used them myself though. I am just posting what speeddemon tested them as. Since he confirmed other spring rates I have no reason not to believe him or his methods of testing.
As far as the shocks making the springs feel stiffer, that could definitely be true. If the mazdaspeed shocks are running much stiffer dampening then that would make everything seem stiffer. BUT, the dampening on the shocks wouldn't have any effect on the actual spring rates. It would NOT actually make the springs stiffer but it can make the entire suspension FEEL stiffer. Just ride in any adjustable shock setup and you will feel the difference between the soft/hard settings, but it doesn't actually change the spring rates.
I just wan't to say that I am not attacking the Mazdaspeed components and I have no doubt that they are quality pieces. Its just that there is so little actually published about them that the only way to come to your own conclusions is to test them yourself which not many people are willing to do.
Old Nov 16, 2007 | 12:32 PM
You know what you are right. I forgot all about that part. So in short the MS suspension combo feels great, it may be more then some other combos but they work well together. I would like to know the actual spring rates.
Old Nov 16, 2007 | 01:03 PM
J8635621's Avatar
Pew Pew Pew
I have heard that the springs were stiffer than stock even from someone running Koni's, which are softer than stock on the softest setting I believe.
Old Nov 16, 2007 | 01:33 PM
LionZoo's Avatar
road warrior
Koni Yellows are stiffer than stock on all settings.
Old Nov 16, 2007 | 06:02 PM
I'd like to see the technique used
unlike a coilover spring, the OE type springs are not flat on one end
it would take a special sloped perch to be carried out properly ...
Old Nov 16, 2007 | 10:57 PM
J8635621's Avatar
Pew Pew Pew
My bad. I swear I read that somewhere on here. I really hope someone is able to get a definitive answer on all the mazdaspeed stuff.
Old Nov 16, 2007 | 11:05 PM
WBRxGreat's Avatar
8 no more
interesting development! How big of a difference in the reading do you think it could make?
Old Nov 18, 2007 | 12:03 AM
Astral's Avatar
Purveyor of fine bass
How does one go about finding a local place to test spring rates? I have Mazdaspeed sport springs & Tein S-techs in a box... would be interesting to throw them on a tester.
Old Nov 19, 2007 | 12:44 PM
Maybe a speed shop or a suspension shop. Lety us know what you find out.
Old Nov 20, 2007 | 07:15 PM
Demon 8's Avatar
Demon 8
I am looking at purchasing the MS springs to lower the ride height and eliminate wheel gap a bit. Will I be satisfied. I am purchasing the entire MS kit and with the cost of the springs I thought that would be a good addition as well. I have yet to consider autox which is why I dont think coilovers are a good fit for me at this time. Any suggestions
Old Nov 20, 2007 | 07:23 PM
LionZoo's Avatar
road warrior
My question would be if that were the case, why did the OE spring rates come out exactly where they should be?
Old Nov 21, 2007 | 09:25 PM
firebirdude's Avatar
User and Abuser
As well as some random springs with the rates stamped on them...??
I'm just trying to rid some gap as well. Don't AutoX it at all and I've gotten used to the factory ride feel. I would like to keep the factory shocks too. Only 18k on them. Just wanna drop the car an inch....
Old Nov 22, 2007 | 09:32 PM
sigtech's Avatar
i like them alot. I will be updating my sig soon
Old Nov 22, 2007 | 10:02 PM
CosmosMpower's Avatar
1935 lbs. FTW!
There's no way that the MS springs are softer than stock in the rear. They are pretty damn stiff, I ran a set with my Konis and I thought I was going to jar my teeth out for the first few days. They are progressive rates rather than linear so if you press on them out of the car they do seem initially softer.
Old Nov 22, 2007 | 10:35 PM
scremn8's Avatar
the more things change
speed's family has been involved with racing for years.
he has the means to find out about the springs..
Old Nov 22, 2007 | 11:50 PM
LionZoo's Avatar
road warrior
I wonder if perhaps the Mazdaspeed springs are purposely soft in the beginning of the travel to accommodate a ride height. How much travel is in the spring?
Old Nov 23, 2007 | 10:42 AM
You'd have to load a progressive spring to it's compressed ride height dimension before beginning the test to get an accurate indication of it's rate
Old Nov 23, 2007 | 08:48 PM
User and Abuser
You'd have to load a progressive spring to it's compressed ride height dimension before beginning the test to get an accurate indiucation of it's rate
Ahhh probably why we have some "false" numbers floating around then....
