Minor problems advise please
Old Oct 16, 2003 | 08:33 AM
Bigcat44's Avatar
I just passed 500 miles on the new car yesterday and I noticed a few problems. First when starting the car and then going to Reverse and just starting to back up within a few seconds a "clunk" noise comes from the engine. I am not using the AC and it does this everytime. Next when getting on the highway I have gotten the car up to about 6800 rpms - 7200 rpms there is a noticeable hesitation like it gets bogged down a little. Any hekp with these problems would be greatly appreciated and if I need to take it to the dealer to look at then no problem. What do you think?
Old Oct 16, 2003 | 09:09 AM
Winning_BlueRX8's Avatar
Limecat's High Priest
the clunk noise is normal...it's been explained before, but I forget what it is. It's in the manual somewhere too, I believe. I'm sure you rad it and just forgot about it though ;9
Old Oct 16, 2003 | 10:11 AM
sferrett's Avatar
Whaaaa?
The clunk on first start-up is likely the ABS doing a self-check. It will only happen the first time you exceed 1 or 2 mph (forwards or backwards) after you start the engine.
The hesitation is something I'm not familiar with.
Old Oct 16, 2003 | 10:41 AM
Bigcat44's Avatar
Thanks for the responses. You are right on the money with the abs self check and what i am getting now is the hesitation is from the ecu retarding itself to prevent possible engine damage/knock based on other threads. Thanks for the info.
Old Oct 16, 2003 | 06:36 PM
Genom's Avatar
Not so Super right now
The hesitation has also been discussed as thats the RPM the secondary ports in the engine open up and a lot of people see a drop in power when this happens.
Old Oct 16, 2003 | 07:38 PM
mikeb's Avatar
100% Italian
who needs the dealer
when you have the forum
Old Oct 16, 2003 | 10:59 PM
Ophitoxaemia's Avatar
dizzy snake pilot
i have on different occasions felt the slight drop in power at 7K, but today, it felt really strong all the way up. the air was cold this morning, 56 deg, dont know if that had anything to do with it. ive got under 1K miles so its still green.
james
Old Oct 17, 2003 | 08:37 AM
Bigcat44's Avatar
Last night on my way home I tested it a little in second gear at just over 6k the car almost wanted to stop revving. It sounded like a baseball card in bike spokes and then when I shift it would go away again until 6k. I got home and checked everything in the Engine compartment and the oil and everything was fine. This morning it didn't do it. wtf? Am I imagining this $hit?
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
arexatemate
Oct 28, 2019 08:16 AM
Vedivan1
Sep 20, 2015 04:39 PM
Vedivan1
Sep 18, 2015 12:39 PM
