Help!, HKS Twin Power
Old Sep 22, 2007 | 08:39 PM
mazdaexe's Avatar
Ok, so I tried to install the twin power. But the car just wont start up afterwards.
It will crank but not start. I checked the leading and trail connections and they seem correct.
For those that does have the twin power, few questions
1. The LED on the amplifier, when does it come on? I have not seen it lit. Does it come on after the car is running??
2. For the leading/trailing harnesses, is there any specific order? Or till a leading hardness goes to a leading coil, a trailing harness goes to a trailing coil is fine?
Thanx
Old Sep 22, 2007 | 10:33 PM
mazdaexe's Avatar
Thanx. didnt see that thread. that should help
Old Sep 30, 2007 | 05:08 PM
DMRH's Avatar
Thanx
1. LED lights up when IGN is on regardless of engine running
2. white cable tie, black cable tie. No specific order. I just followed that, took apunt on which white / black goes where & bingo. All worked well
REgards
tommy26Germany
Sep 29, 2015 10:33 AM
Trekk
12
Sep 25, 2015 03:08 PM
Rotary Swaps
Sep 21, 2015 04:52 PM
Rupanrx
Sep 4, 2015 06:44 AM
