75-90 or syncromax
Old May 17, 2007 | 10:56 PM
chuuuma's Avatar
75-90 or syncromax
about 5000 miles ago i chacnged my tranny fluid to royal purple syncromax and about 2 days ago it was making some weird noise when i downshift without revmatching. so today i took it to dealership n have them check it out
The sad thing is that when me n the tech guy test drove the car... it didnt make the noise i came in for... so i told him if he can just simply check my tranny fluid for me. so he jack the car up n got some of the fluid out n he was telling me how it's not the right tranny fluid ... it's too watery so he showed me the tranny fuid they put in the car n it was really thick. n he told me that i should change back to 75-90
my quiestion is i know that royal purple has 75-90 available. but which 1 is better? the 75-90 or the syncromax
the other question is that when he took out the tranny fluid he was showing me how there's some metal shavings not visible but under sun u can kinda see it reflecting in the tranny fluid and the syncromax is the the cause for that is that true? i thot it's normal to have some metal shavings...
Old May 17, 2007 | 11:31 PM
cjkim's Avatar
^noob
first off, why would you downshift without rev matching?
75w90 is correct
syncromax is for tranny's that use auto tranny fluid (ie. not the rx8)
Old May 18, 2007 | 12:18 AM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Uh why wouldn't you search here first? There are so many posts that tell you RP 75W90 MAXGEAR!
Old May 18, 2007 | 02:14 AM
R-RevX's Avatar
Closer than it appears
From my experience metal shavings in a modern transmission is NEVER EVER normal. It's an indicator of damage. Unless you grind them, I'd agree that the root cause was the syncromax.
Old May 18, 2007 | 06:18 AM
Syncromax ? wtf ?
MAXGEAR BUDDY, MAXGEAR !
Old May 18, 2007 | 08:25 AM
devildog1679's Avatar
Yea, I would definitely switch to Maxgear. Did you tell the dealer you switched to synchromax? If so, is it documented on your invoice? If it's not documented on your invoice I would keep my mouth shut and say you use Maxgear all the time.
jpz262
May 7, 2015 08:16 AM
Eldragon0
9
Sep 25, 2013 04:46 PM
JantzenRX-8
Feb 27, 2013 09:18 PM
NoRotorNoMotor
RX-8 Racing
Jul 9, 2008 08:31 PM
