HID light or halogen?
Old Mar 15, 2007 | 09:19 PM
eugenewang55's Avatar
does anyone here know ways to check either ur rx8's light is HID or not??
my friend told me that if its white then it must be HID....but since my rx8 is the touring edition and it doesn't come w/ factory leather...so i thought its not...however the light is not yellowish to me at all......and if its not HID....i saw some bulb w/ code h7 on ebay ...but they are hid bulb....can i still install those on my car...??
thx for all your helps....appreciate it
Old Mar 15, 2007 | 09:29 PM
RX8SaxMan's Avatar
If you have the touring package you have HIDs
Old Mar 15, 2007 | 11:49 PM
sry i mean sports package
Old Mar 15, 2007 | 11:55 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Every 8 except the base model has HID. If you're car has a DSC switch on the left side then you have HIDs. HIDs also make a slight flash and change color slightly after you turn them on.
Old Mar 17, 2007 | 07:57 PM
well i have base model...but w/ fog lamps(the two small rounded lamb below front light; can be turned on/off independently of the main lamp) and dsc...my low bean is also significantly whiter comparing w/ the parking light....since im planning to change my bulb, just wanna make sure im having an hid...does my option come w/ HID???
thx for all the helps provided
appreciate it
Old Mar 17, 2007 | 08:09 PM
dillsrotary's Avatar
jersey fresh
the HID bulb code is ds2 i believe, the NON hid bulb code is h7.
You should be able to tell, the HID's look way different than the non hid's. They non hids look like every other car on the road, that normal yellowish/white headlight color, the hids are alot whiter with a tad of blue/purple.
Old Mar 17, 2007 | 08:17 PM
Phantom Menace's Avatar
II SOCIETY
The HIDs make a humming sound when turned on...that and HIDs are standard on Touring and GT models...
Old Mar 17, 2007 | 08:34 PM
Detrich's Avatar
幹他媽!
they also are self-leveling, if i'm correct. when u turn the headlights on, if u see them self-level, then they're HIDS.
Old Mar 17, 2007 | 09:13 PM
mysql101's Avatar
my hid's look blue when i first turn them on.
Old Mar 17, 2007 | 09:20 PM
llzjayarzll's Avatar
meow
^^ yea u got HIDs if theyre bluish at first lit, then change to regular lighter white color. halogens dont do that
Old Mar 17, 2007 | 11:15 PM
how do u tell if light is self-leveling?
Old Mar 17, 2007 | 11:23 PM
jersey fresh
you really can't, it just does it itself, i've never seen mine ajust. The driver side will always be a tad lower than the passenger side too, thats normal as well (so you don't blind on coming traffic)
Old Mar 18, 2007 | 01:10 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Park with the drivers wheel on the sidewalk and the other in the street. Then turn your lights off and then back on... You should see them move.
Old Mar 18, 2007 | 01:12 AM
btw, the auto leveling sensors are on the drivers front and rear wheels.
Old Mar 18, 2007 | 02:26 AM
Detrich's Avatar
幹他媽!
exactly. u will see the beam move or shift very slightly when initially turning them on. it's subtle, so you'll want to park with your headlights pointing towards a wall or flat surface and turn on the beams when it's dark- ie so u can see the light beam.
Old Mar 18, 2007 | 03:22 AM
TomAssBender's Avatar
Skeet skeet skeet
Ahhh and I thought my **** was fucked up! Phew. Dill is a well of knowledge.
Anyway, I know mine are HIDs cause they make the green grass appear to be this awesome color in the summer when i start it up.
Old Mar 18, 2007 | 10:03 AM
stickmantijuana's Avatar
Unregistered User
green grass, awesome color? think u should avoid the pipes before driving. jk
Old Mar 18, 2007 | 04:15 PM
uahh...im still not sure abt the package i have.....can anyone here be sure that if u have foglight and dsc then the package include hid lamb...??
btw the light does make a humming sound when i first turned them on....but not sure if the its bluish enough to be identified as hid since there are all kinds of coated halogen bulb to imitate hid in markets these days.
Old Mar 18, 2007 | 04:19 PM
jersey fresh
we've helped you about all we can eugene haha, good luck on this journey
Old Mar 18, 2007 | 05:22 PM
haha thx anyway....u guys r great
Old Mar 18, 2007 | 06:29 PM
RX8SaxMan's Avatar
YOU HAVE HID.
Old Mar 18, 2007 | 09:40 PM
mysql101's Avatar
Our HID's will appear blue for a few moments. Once it's warmed up, it will be a pure white. If the bulb was colored, it wouldn't change to white afterwards..
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Jun 14, 2022 08:32 AM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Evan Gray
Sep 26, 2015 12:30 PM
