[help] power steering problem......
Old Mar 10, 2007 | 04:06 PM
RX-8_PENNZOIL's Avatar
Exclamation [help] power steering problem......
Pls forgive my poor english below.....
tonight , i want to install my E-Manage U. into my 8 ....
the first thing i did was to release the battery , then setup the " wire" and took my original ECU out , those thing spent me over 2 hrs to finish it, coz original ECU really hard to get it out......
after that , i connected everything and start the engine.....
i found that my P/S light was ON , then i checked all the fuses and connectors were no problem ...... so i tried to connect back my original ECU , the "light" still ON ........
if you guys tried my same problem...... hope can share yours solution/s.... thx
ps. recently , every morning when i start my 8's engine , while i turn left/right my steering wheel must have some " vibration " occur.... but after i turn it serval times , those problem will be gone...... does you guys know why??? can it be solved ???
Old Mar 10, 2007 | 05:08 PM
StealthTL's Avatar
Cool Reset.....
When you disconnect the battery, the computer forgets where the "centre" of the steering sensor is - you have to tell it with the reset procedure.
Turn the ignition and engine on, then steer all the way left, all the way right, then left again. It's easier if you get moving, slowly. Then turn off and restart, the lights should go out.
S
P.S. Your signature file is too big at 70k plus. The limit is 20k, please change it.
Old Mar 10, 2007 | 06:43 PM
woo..... thank for your good help..... i wil try it later , left-right-left....... ok....
just now i read some thread said steer " L-R-C " , some other said steer" R-L-C " then press 20X brake..... etc.
by the way , i have changed my signature size.....
Old Mar 10, 2007 | 07:40 PM
SushiFan's Avatar
The steering vibrations could be due tot he steering rack spoil.. you should get it checked out.... this is a common problem..
Old Mar 10, 2007 | 07:59 PM
SushiFan's Avatar
You can refer to this thread for the video to see if that's what your are talking about..
https://www.rx8club.com/series-i-trouble-shooting-95/steering-rack-problem-rx8-110230/
Old Mar 11, 2007 | 04:36 AM
cuscorex's Avatar
爆 走 RE风 林 火 山
tis is a wear/tear tingy tat occur in times to com.tis 'mornin sickness' occur in stages.it'l onli get worse s time goes; turnin it several times til the engine is in full warm-up conditn;everytime the car is cooled,start,the prob starts too...the onli rectify,chg the whole steerin rack,& its quite a costly item,no joke man.
wat u saw in the clip fr sgrenesis is @ its 'almost most critical stage'.he'l hv to drive wif the prob, fightin the 'jerk' everytime he rolls off when the engine cools off.
Old Mar 11, 2007 | 05:55 AM
S
i tried your method.... but the light still "ON".....
is there have any different between "left-hand side" and " right-hand side" car???
and "Turn the ignition and engine on" , is it must need the engine in running status?? or just turn the key to "ON" possition (engine havnt run) ??
" steer all the way left, all the way right, then left again." ,
after steer all the way left , do i need to hold it a second then go right ?? and the "last" left steer , do i need to hold it then start the engine????
Old Mar 11, 2007 | 06:05 AM
whole steerin rack?? wht is that?? is it a sensor?? or a "parts"....
can you post up some pics for those thing look like??? thx!!
Old Mar 11, 2007 | 07:31 AM
SushiFan's Avatar
ermmmm steering rack is something that looks like a rack? heh heh. It roughly cost about $2k-> parts alone.. have to factor in labour too. For the interest of safety... do get it fixed. $2k is less than $many many k in the hospital anytime of the day. =)
Old Mar 11, 2007 | 11:21 AM
blackjack's Avatar
Kei-Office
go to monster garage, thet have all necessary equipment to solve your problem.
Old Mar 11, 2007 | 12:33 PM
i live in macau...... not your place.....
Old Mar 11, 2007 | 05:42 PM
SushiFan's Avatar
lol!
Old Mar 11, 2007 | 10:17 PM
blackgt's Avatar
try browsing thru this link .. very informative ..
http://auto.howstuffworks.com/steering2.htm
this will explain to you what is sterring rack and pin pivot concept.. :P
PS: always work for me to go to this site to explain technical stuff to my little one whenever he ask me how things works .. ahrhar
Old Mar 11, 2007 | 10:54 PM
INXS's Avatar
INXS
Time for u to relocate..
Old Mar 12, 2007 | 12:00 AM
thx for you big help......... now i know what is is...........
Old Mar 12, 2007 | 12:48 AM
blackgt's Avatar
any time bro!!!!!!!
Old Mar 12, 2007 | 01:14 AM
StealthTL's Avatar
Cool Help....
Here is a guy with the same symptoms, and how he fixed it (for free....)
Steering fix.
S
Old Mar 12, 2007 | 12:17 PM
blackjack's Avatar
Kei-Office
ooops.....
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Fickert
Sep 9, 2015 01:21 PM
Tsurugi
Sep 7, 2015 08:27 PM
