What is the correct/optimal tire pressure?
Old Mar 1, 2007 | 03:31 PM
mshea's Avatar
My OE Dunlop's call for 51 lb. max pressure. 50 lbs. all the way around feels overinflated but I can't find any recommendations in the owners manual or door sticker.
What is best for optimal performance?
Thanks.
Old Mar 1, 2007 | 03:44 PM
jzief128's Avatar
What are the Detes?
It's 32 PSI cold (at least for the bridgestones), and I'm pretty sure that its right on the the door sticker.
Old Mar 1, 2007 | 03:48 PM
mshea's Avatar
32 seems a heck of a lot more logical....anyone else?
Old Mar 1, 2007 | 04:15 PM
Brettus's Avatar
Boosted Kiwi
32 sounds about right . I think if you track its recomended to be up around 36
Old Mar 1, 2007 | 04:44 PM
mshea's Avatar
Thanks, gents. 32 looks right. What the heck is Dunlop thinking?
Old Mar 1, 2007 | 04:56 PM
OnRails's Avatar
51 is just the max pressure that the tire can withstand.
Old Mar 1, 2007 | 05:08 PM
invasion08's Avatar
as long as the tire is 225/45/18 then the psi should be 32
Old Mar 1, 2007 | 06:37 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Thanks.
Sorry--but this is really a dunce question.
Look on the frame, look in the owners manual, search the forum?
Old Mar 1, 2007 | 07:10 PM
mshea's Avatar
Yeah, well I thought it would be a dunce question too. Except, as I said, it isn't on the frame or owners manual and a search turned up nada.
So thanks for your contribution.
Old Mar 2, 2007 | 12:29 AM
You're welcome.
The recommended tire pressure is on the sticker on the driver's door jamb and on page 10-7 of the manual and also if you search using "recommended tire pressure".
Old Mar 2, 2007 | 03:39 AM
c41250n's Avatar
32 all around!
Old Mar 2, 2007 | 09:32 AM
CosmosMpower's Avatar
1935 lbs. FTW!
You should never inflate your tire to the max pressure, that's why it is the MAX pressure. I run my stock RE040's at 32 PSI on the street, tried 34 and found I was wearing the middle a bit much. For autocross I run 36 front 34 rear on 255/40/17 Falkens
cliffkemp
Dec 24, 2024 10:48 AM
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
