Loose steering - Noise in left/front suspension
Old Feb 15, 2007 | 06:10 PM
cavemancan's Avatar
The forgestar be with you
Exclamation Loose steering - Noise in left/front suspension
Hi everyone...I need some help! I am having an issue with my suspension in the front and I've done many searches for a month now with no luck on the subject.
Basically its two issues: 1) I feel like my steering is very loose. It still handles great but its too easy to turn the steering wheel at high speeds. The car responds as it should but for some reason I feel like it should give more resistance when you are driving faster inorder to promote stability at high speeds.
2) This is more critical...After driving the car hard for more then 30 min I get an anoying sound comeing from the right front wheel well. Kinda like a creaking noise (a low pitch - rocking chair made out of metal) that happens intermitantly. I've takin the car back to the dealer for this issue with no resolution. The first time they indicated that they could not find anything (this is because you have to ride it hard for more than 30 min to replicate and I know they did not do this) but they replaced a motor mount and it appeared to get rid of the noise for a short while. Now its happening again and I dont know if its the strut, a bushing (which a mechanic friend said they looked ok), or another component of the suspension. For some reason I keep thinking its a bushing not being greased properly but I only have 26K miles on mine! I really dont care that the car as a few issues I actually enjoy working on the car if I have too and I have a few tools too. I just wish I knew what the issue was so I can fix it. The not knowing is whats anoying the **** out of me!
- On a side not I just ordered new suspension (shocks and springs) and I hope that will get rid of the noise as I suspect that it may also have to do with the shocks. Maybe installing the new suspension will also help woth the loosness. Who knows...I just like my bitch's tight! (Don't mean to offend any ladies in the group with that)
Old Feb 15, 2007 | 06:49 PM
cavemancan's Avatar
Bumppiddy
Old Feb 17, 2007 | 03:08 AM
cavemancan's Avatar
I guess no one knows what I am talking about?
Someone PLEASE help me with this.
Old Feb 17, 2007 | 06:58 AM
everybody loves their bitch tight .... ooooops did I say it out loud ?
Well, I think it has something to do with the grease thing, I think some other people having this problem just like you , search around u might find something.
Old Feb 17, 2007 | 09:05 PM
where in fla usa are you?
Old Feb 17, 2007 | 09:11 PM
I would check the sway bar bushings...and lube them.....
And check the alignment...if the alignment is out it will feel loose at speed
How many miles are on it....I have about 60K on mine and the sway bushings are shot...Can't blame Mazda though.....a lot of track time...with heavy sways and high springrate...and a lot of bumpy streets at home. This makes for worn out bushings.
They are cheap to replace though....Greasable urethane ones are about $25
Old Feb 19, 2007 | 05:27 PM
cavemancan's Avatar
Swoope,
I frequent Orlando since my brother lives there. If you could help me believe me I will make the trip next weekend...LOL!!! I actually live in Sunrise, FL next to the Sawgrass mall (I.E. Ft. Lauderdale area).
Old Feb 19, 2007 | 05:30 PM
cavemancan's Avatar
I only have 27K miles on mine and I don't blame Mazda in any way. I realized from day one that this car needs to be cared for and I was OK with that. I just hate not knowing what needs fixed.
Old Feb 19, 2007 | 11:12 PM
Originally Posted by cavemancan
Swoope,
send my a pm before you come... no problem...
Old Feb 20, 2007 | 10:12 AM
cavemancan's Avatar
Probably not this weekend (Drift competition in West Palm and 1/8th mile competition in Miami) but definatly next weekend.
Sending you a PM now with my info.
Note: I will try to bring a camera in case a potential DIY fix can be documented from this.
duworm
Oct 1, 2015 04:57 PM
DeltaJ802
Sep 29, 2015 01:20 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
