Racing Brake Rotors
Old Feb 7, 2007 | 11:16 PM
RevURGT3's Avatar
Racing Brake Rotors
I just had installed my 2 piece front rotors + Hawk HPS pads. Since it was track day, I had a chance to test the before/after. The Hawk pads are very very good... I was able to brake much later than with the stock pads.
The rotors are incredibly well made and much lighter than the stock ones. Visually they do not look that impressive but I have always favored function over form...
I am getting their aluminum calipers too, they should get here pretty soon...
Attached Thumbnails Racing Brake Rotors-sm-p1010119.jpg   Racing Brake Rotors-sm-p1010118.jpg   Racing Brake Rotors-sm-p1010120.jpg
Old Feb 8, 2007 | 12:10 AM
fyi, RacingBrake has two new pad compounds coming out, but they will be shaped for their calipers only
both are suitable for track duty; one is rated up to 1200 degF and the other to 1400 degF, but also still work for low temp street use so need to swap them out with track pads. The lower temp one has slightly less dust and is quieter, pick your poison. They recomend using the Hawk HT10 in the rear to match them. They are using this setup on both the track and street with great results. They ran the high temp pad at a 24 hr track enduro and had 50% less wear than the Hawk DTC60 track pad with equal performance, they did the whole event on one set of pads and there was still more left in them.
Old Feb 8, 2007 | 06:39 PM
RevURGT3's Avatar
Thx TeamRX8, since I am getting their calipers, I will be able to test their pads too... I was very happy with the HPSs at the track and I have no complains on the road... they squak every now and then but that is fine with me...
Old Feb 8, 2007 | 09:16 PM
Can you get brake pads from Porterfield?
If not they can make them and they are local.
Old Feb 19, 2007 | 10:09 PM
RevURGT3's Avatar
Ok, I finally had my Racing Brake aluminum 4-piston calipers... the front is complete now!
Attached Thumbnails Racing Brake Rotors-sm-p1010168.jpg   Racing Brake Rotors-sm-p1010170.jpg   Racing Brake Rotors-sm-p1010175.jpg
Old Feb 19, 2007 | 10:17 PM
Very nice. Are You going to the next event at AT&T on the 25th? What suspension are you running?
Old Feb 19, 2007 | 10:55 PM
RevURGT3's Avatar
Nope, I did not know about that event. What time? I will swing by to check it out. I really don't do any auto-xs anymore, I rather save the tires for the track...
I am running MS' coilover suspension...
Old Feb 20, 2007 | 03:36 PM
Cool man, what track do you go to? have you heard about the road course being built in San Marcos? Come by and watch on the 25th, here is the info.
SASCA #2 @ AT&T Center
Sunday, February 25, 2007
SASCA February 25th Autox at AT&T Center
SASCA's 2nd points autocross of 2007 will be on Sunday February 25th at the AT&T Center. The AT&T Center is located at #1 SBC Center, San Antonio, TX, 78219.
IMPORTANT!!! All Drivers MUST have their Proof of Insurance (POI) on
file BEFORE this event. If your POI is already on file, and it hasn't expired yet, you are good to go. See this topic for full details: http://www.sasportscar.com/forum/top...?TOPIC_ID=2568
Setup starts at 7:00 AM
Registration opens at 8:00 AM
Late registration begins at 9:00 AM (additional $5)
Registration CLOSES at 9:30 AM
Novice Walkthrough at 9:40 AM
Driver's meeting at 10:00 AM
First Car out at 10:30 AM
NOTE: NO MEMBER DISCOUNTS FOR WALK UP REGISTRATION! Register online at www.dlbracing.com
Overview Map to the site:
http://www.mindspring.com/~eharloe/s...Directions.jpg
Map for entering the AT&T Complex:
Image of the event lot:
http://www.mindspring.com/~eharloe/s..._Template1.jpg
Google hybrid map:
http://maps.google.com/maps?f=q&hl=e...17402&t=h&om=1
Old Feb 28, 2007 | 05:08 PM
Speedtoys's Avatar
Yes, they can, and yes I do.
I wholesale PF to the public.
Old Feb 28, 2007 | 05:52 PM
what did the caliper setup cost ya?
Old Feb 28, 2007 | 05:54 PM
nice! they look great! good luck
Old Mar 1, 2007 | 09:43 AM
RevURGT3's Avatar
Here ya go:
http://www.racingbrake.com/RX8_FRONT...15-311-411.htm
Old Mar 2, 2007 | 12:42 PM
mshea's Avatar
So what are you guys doing with the rear's?
Old Mar 2, 2007 | 12:46 PM
scsi's Avatar
are you using all stock size rotors? i have a full set of their open slot 2 piece rotors currently. i want to get the front calipers some time down the road but they only sell them with new rotors. i was planning to just throw on the calipers and sell the brand new rotors, are the rotors that come in their stock size alum caliper kit the same as the rotors they sell separately?
Old Mar 2, 2007 | 03:55 PM
no, if you purchased the rotors they will sell you the caliper kit as an upgrade to them, you just need to prove you bought the rotors, they won't sell the calipers individually except as a proven replacement or upgrade
they have a 1 pc and 2 pc rear rotor kit, a rear caliper kit is in development but it will be for racing use only since the e-brake function won't be maintained
Old Mar 2, 2007 | 04:14 PM
savedsol's Avatar
Carbonormous
Any idea if they'll fit 17's - I still have to put on the snow wheels here!
Old Mar 4, 2007 | 12:47 PM
mshea's Avatar
So with such a sharp looking front end caliper, do I understand correctly that they don't have a matching rear set? What do you do instead?
Old Mar 4, 2007 | 12:57 PM
the same thing you do with all the other RX-8 brake kits, use the OE rear caliper with it's integrated handbrake mechanism
Old Mar 4, 2007 | 01:49 PM
^ ^ That way you can still drift!
Ha HA.......
Old Mar 5, 2007 | 01:21 AM
Mine didn't...had to swap back the stock calipers and rotors for winter.
Good idea anyway...can wear and corrode out the stock ones instead
rxwilly8
Sep 2, 2015 02:42 PM
20b-3rotor
Sep 2, 2015 08:54 AM
wayloco
Sep 1, 2015 09:03 PM
