Mazsports coolant mod help
Old Dec 24, 2006 | 03:51 AM
HERO's Avatar
I just recieved this as a Christmas gift and seem to have trouble with the directions........ Has anyone installed it and took the time to takes pics that would direct me on the route to installing it? Anything would help.
Thanks in advance
Sam
Old Dec 24, 2006 | 08:19 AM
olddragger's Avatar
Its not Christmas yet!
OD
Old Dec 24, 2006 | 08:22 AM
mysql101's Avatar
scott's directions are pretty clear. You just cut the coolant hose at the 90 degree bend, put the barb part in, then hook up the ground wire. The other end goes into the fuse box (far right side of the car in a black plastic box) and replaces the OEM fan fuses.
Old Dec 24, 2006 | 08:36 AM
StealthTL's Avatar
Relays.....
".......and replaces the OEM fan RELAYS."
You would still need the stock fuses....
S
Old Dec 24, 2006 | 08:39 AM
mysql101's Avatar
yup, wrong word. It wouldn't matter - the relay wouldn't fit into the fuse slot anyway :P
Old Dec 24, 2006 | 02:29 PM
HERO's Avatar
OD
We gave out secret santa gifts a little bit early this year haha.
The one thing im not sure on is the location of the coolant hose. Is any coolant going to leak out when I cut the hose?
Sam
Old Dec 24, 2006 | 03:30 PM
expo1's Avatar
He's as bad as Can
Sam
Yes some will leak out, do it on a cold motor and it will not be that much. https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/brillos-test-mazsport-fan-modification-97975/ Post#17 has photos
Old Dec 24, 2006 | 03:59 PM
mysql101's Avatar
My car was cold, and I didn't notice any coolant come out. Just have a washcloth handy when you do the initial cuts.
Here's the finished product:
Old Dec 24, 2006 | 04:40 PM
HERO's Avatar
Thanks everyone. Gonna install it, with confidence, tomorrow.
Sam
Old Dec 25, 2006 | 01:46 AM
N rider89's Avatar
^NieL
yeah its not too hard but watch out for the coolant. it sprayed be pretty good
Old Dec 25, 2006 | 02:03 AM
yea,
same here, cold car=no pressure= no coolant. it does not get much more simple than this mod...
enjoy..
Old Dec 25, 2006 | 05:21 PM
HERO's Avatar
Installed everything! Took about 15 minutes. Really straightforward. Thanks again for the quick help guys. So, how do we know it's doing what it should be? I don't have any type of scanner to check temps and whatnot
Sam
Old Dec 25, 2006 | 05:24 PM
You will notice the fans running a lot more than before.......other than that...not much.
Old Dec 26, 2006 | 03:53 AM
N rider89's Avatar
^NieL
yeah i can hear the fans a lot more
gwailo
May 14, 2024 06:57 AM
Hunterkelley24
Jun 14, 2022 08:32 AM
FubarI33t
Sep 28, 2015 08:45 PM
drlubell
Sep 26, 2015 11:58 PM
