Stand Alone Wideband Results
Old Dec 23, 2006 | 03:15 PM
brillo's Avatar
Go Texas Longhorns!
RG and I got my LC-1 installed without to much fan fare, running with the stock PCM, I'm almost surprised how lean the car runs stock, now the little digital display is going to not be as accurate as a log session since it changes so quickly, but I found the car just driving around, even with some stick in the 14.0's. Getting on the car hard I saw some 12.5's for a second, but it returned to the high 13's low 14's very quickly. My mileage seems to have gone down since the latest flash, and I assumed the stock cars were running richer to save the cat.
I have the sensor right before the cat on the highflow cat.
Any thoughts for those with the stock PCM and a wideband?
Old Dec 23, 2006 | 07:46 PM
Brettus's Avatar
Boosted Kiwi
Sounds about right - you don't get into the 11s with stock PCM unless you are at WOT & above 4000 rpm .
Old Dec 24, 2006 | 12:09 AM
brillo's Avatar
Go Texas Longhorns!
I'm surprised the warmup shows lean also (14-15afr), but then again, the sensor might not be warmed up either at that point.
Old Dec 24, 2006 | 12:14 AM
Brettus's Avatar
Boosted Kiwi
Yeah - it seems to stick around the 14.6 pretty much whenever you are off the gas.
are you running a piggyback Brillo ?
Old Dec 24, 2006 | 12:24 AM
brillo's Avatar
Go Texas Longhorns!
not at the moment, I have a int-X, but its not in now.
Old Dec 24, 2006 | 02:31 AM
LiL BenNy's Avatar
Bubblicious? DEF.
doesnt richer mean using more fuel? if so wouldnt you be getting worse mpg if you were richer? because its was adding more fuel?
ps after the latest flash my mpg went down too... a lot.....
Old Dec 24, 2006 | 04:08 AM
gr8rx's Avatar
sometimes richer means better mpg, it depends on the engine, also the afr, say if you go from a af/r of 15/1 to one of 13/1 your probably in most cases going to get better fuel economy at the 13/1 because of less detonation, and other reasons, some engines just run better with more fuel, rotaries are one of these
yurcivicsux
192
Sep 12, 2017 10:54 PM
tommy26Germany
Sep 29, 2015 10:33 AM
jtdwab
Sep 12, 2015 04:57 PM
rxwilly8
Sep 2, 2015 02:42 PM
