Non-Rotary Swaps Engine Swap Forum
LSX 7.0 twin turbo engine Swap
Old May 1, 2009 | 05:36 PM
  #126
Mawnee's Avatar
I divide by zero
Originally Posted by YaXMaNGTO
Looked like a nice Vette, and it's cool you used to hammer on it yourself.
Then you also know the level of modications it takes to strengthen ANY drivetrain of ANY production car to withstand 1000hp+. I come from the GTO world where we have to invest in expensive Kaaz rear ends, one-piece driveshafts, hardened halfshafts, built T56's, etc., so we also know the pain.
Point is, the comments from simplephp "just buy a Corvette" are superfluous. It will cost a **** ton of money to get ANY car to 1200hp and streetable, so any argument about cost is ridiculous. It's going to be expensive, so I'm saying that starting with an RX8 doesn't matter once you reach this level. Every damn thing is going to be replaced, strengthened or upgraded anyway, so the investment is going to be huge no matter what.
I couldn't make the same argument if all he was doing was swapping in a stock 350hp LS1. Then the costs vs. results don't make as much sense. I think this project is cool, and I just don't get the negative comments.
Oh no, I totally agree. No need for negative comments here, whether you like the project or not you have to appreciate the work and skills it will take to pull it off. I am doubley interested in this project because I have an interest in both the RX8 and LSx worlds
And you are right about the expense of a high power driveline. I did all my carnage with less than 700RWHP. It takes exponentially more money and skills every couple hundred HP up you go. I pretty much pushed the limits of what a corvette would take on stock bottom end and upgraded driveline. The next step up was an expensive forged bottom, new fuel system, custom solid torque tube, built tranny, solid rear, ect ect.
Old May 1, 2009 | 06:15 PM
  #127
Mazmart's Avatar
Originally Posted by kersh4w
i dont think the race rx8s have 1200hp either...
not even the 3 rotors..
There are race RX8s making more horse than that. My friend Abel claims close to 1700. i'm not sure if that's to the wheels.
http://www.youtube.com/watch?v=vTG_iVXabfw
Props to RGONZA though. To each his own; I'm a rotor head to the end .
Note: Abel's power is on Alcohol
Paul.
Old May 1, 2009 | 07:13 PM
  #128
YaXMaNGTO's Avatar
It's a Cavalier
Paul.
I don't think anybody doubted that 3 rotors making more than 1200hp existed.
I'm just not sure you can say that tube chassis drag car is a "1700hp RX8"
Know what I mean?
Old May 1, 2009 | 07:28 PM
  #129
YeahYeahYouWere's Avatar
Call me ROTO BAGGINS
Know what I mean?
I'm inclined to agree - people don't really think of NASCAR vehicles as Camrys (Camries?) after all.
Still, incredible project. Makes me feel like even more of a wuss for being nervous about replacing my own air filter.
Old May 1, 2009 | 08:09 PM
  #130
blackenedwings's Avatar
Life begins @ 30 psi
Abel's car is absolutely insane... granted its a whole different class of car, but still nice. How is this LSx swap going? I want to see some pics!
Old May 1, 2009 | 09:15 PM
  #131
kersh4w's Avatar
Hit & Run Magnet
i just came in my pants.
that was beautiful.
Old May 1, 2009 | 10:11 PM
  #132
Rotr8's Avatar
whines all the way home
Almost like it was made for it... Dead Sexy......
Old May 2, 2009 | 11:00 PM
  #133
YaXMaNGTO's Avatar
It's a Cavalier
That's a good way of saying it. It's does look it should be there.
I keep sizing up the height of the intake manifold and the fuel rail in my head. It's not too much taller than the heads, but its gonna be pretty tight under that strut brace.
Old May 2, 2009 | 11:22 PM
  #134
Mawnee's Avatar
I divide by zero
Yea I keep thinking the same thing. I think its gonna fit though, only need 4 inches or so over the valve covers. I keep looking through all my pics for one from the same angle and cant find one thats quite right to give perspective.
Found one! ..one sec I"ll get it uploaded to a host.
^ that was my 2nd engine and in the box behind it was my 2nd or 3rd differential :D
Old May 4, 2009 | 11:28 AM
  #135
olddragger's Avatar
3 rotor can make a lot of h/p---buts its the torque that is the difference between these 2 engines.
I am sure he is going to do a big stroker version 580 cu in +?? The 3 rotor tq band will not match at 1200 hp big block v/8.
i agree with you on the cam lift--and like you and i said--lifter/pushrod work will have to be done(still use the exhaust valve seals?)-- I also wonder if he is going to a low lift prototype rocker arm set up to maybe help get up to that 8.5K he mentioned? i wonder what "total" lift will be and i also wonder what duration he will be using.
I also REALLY wonder about the rear suspension and diff
That is going to be more work than getting the engine in the car.
Thank God we have pioneers around like this. Hats off to ya Bro!
olddragger
Old May 4, 2009 | 04:15 PM
  #136
savedsol's Avatar
Carbonormous
Please make a subframe kit with DIY instructions. Had some hot engine restart issues yesterday.... grrrr.
Old May 4, 2009 | 06:59 PM
  #137
shadycrew31's Avatar
WENTGERMAN
After some brief research and thoughts I'm beginning my planning on an ls3 swap should take me about 5 years to fine tune everything buy a DD and transform the 8 . I'm fine with a bolt on LS3 for now, anything over 500 whp is pointless for my intentions. The weight of the engine is low enough the LS3 weighing in at 415 and the renesis weighing in at 344 71 lbs isn't room for concern if the mounting is done correctly.
So yea I'll get back to y'all in 5 years.
Old May 5, 2009 | 02:24 AM
  #138
sounds good man, way to plan it out in advance
Old May 5, 2009 | 10:58 AM
  #139
olddragger's Avatar
1200 hp+ extreme torque will require more than a new subframe.
I cant quit posting here!
olddragger
Old May 5, 2009 | 11:29 AM
  #140
savedsol's Avatar
Carbonormous
Not all of will go the 1200hp route. An LS1 with headers, cams, Z06 manifold will be plenty!
Re: the 71lb weight difference, put the battery in the trunk and you're down to an extra 36lbs up front! Not bad. I did notice in the pics that it looks like the radiator is as far forward as the bumper grill.
Old May 5, 2009 | 11:54 AM
  #141
WENTGERMAN
Exactly 71 pounds is so easy to shave off. honestly when you take out the washer fluid bucket the pcm ecu wiring harness all that BS your golden. Id like to remove the dsc and abs system as well but I'm not sure how the brake setup would look after that.
I doubt Ill do it to my car I might get a roller for a few grand and work on that winning blue is to rare of a color to mess with.
Old May 5, 2009 | 04:05 PM
  #142
Decat's Avatar
I do not believe it is just the weight itself that needs to be made up for, it is the position in relation to the wheels and the size of the motor that would be more of a factor than just the increase in weight. You put the engine farther back towards the middle of the car like the Renesis and you get a better weight distribution. The Renesis is located behind what would be the front axle. This engine being larger in size will be located right on top of the front axle and hence more of its weight will be on the front wheels no matter how it weighs in compared to the Renesis just because of its size and position relative to the axles. So yeah handling will be negatively affected a bit, but he will probably find a way to make that better than stock if he wanted to.
But come on guys he knows exactly what he is doing and he will pull it off one way or another, he is not only a frontier finding problems we have not even thought of yet, he is an innovator and will find solutions to those problems before we even know the problems existed. I cannot wait to see how it turns out!
Old May 7, 2009 | 11:53 AM
  #143
YaXMaNGTO's Avatar
It's a Cavalier
olddragger
I get what you're saying, but, honestly, there's no way he's going to put all that torque to the ground... right?
I mean, I could have 10,000 lb-ft of torque, and if I try to take off on a wet street, I'm not going to break anything because I'm just going to spin.
This thing is still going to be light but have enough torque and horsepower that anything in the rear, short of a rolling pin with Hoosier 40 treadwear rubber coating, is going to vaporize if you lay into it. I don't think the point of the project is to tub it and stick slicks under it.
I don't know what that cam is going to do exactly, but I'm guessing that LSA is going to move the torque curve higher in the RPM range. Maybe thats what he's looking for. With a 427, it's going to make torque down low no matter what, and could help with the drivability and a more linear power curve.
RGonza! We can't read your mind! This is fun and all, but, man, give us an update tell us what's up!!!
Old May 7, 2009 | 11:54 AM
  #144
YaXMaNGTO's Avatar
It's a Cavalier
LOL you said "cams"
Old May 7, 2009 | 02:41 PM
  #145
savedsol's Avatar
Carbonormous
LOL you said "cams"
Ah yes. Singular not plural!
Old May 7, 2009 | 03:54 PM
  #146
YaXMaNGTO's Avatar
It's a Cavalier
Won't have to buy two cams for good ol' OHV. Z06 intake? you're referring to the LS6 intake?
It's cool you're looking at doing a project as well. it may not be possible, but I think would be popular if it can be kitted in some way...
Old May 16, 2009 | 03:51 AM
  #147
ciobulus's Avatar
one day in 5 th gear he will punch it and when that monster gets on it will break something so if u have 10,000 lb-ft of torque dont go out of 3rd or else
Old May 18, 2009 | 11:27 AM
  #148
MuhThugga's Avatar
He's going to need to tub it to get the power to the ground. Street tires won't be able to hold that power. Hell, I had to switch to drag radials to get any sort of grip on my car, and I'm at about 380 to the tires.
Personally, I would have gotten a carbeurator and had it stick through the hood. But I'm just old school like that, I suppose.
Old May 18, 2009 | 11:32 AM
  #149
MuhThugga's Avatar
Considering that 3rd gear multiplies the torque more than 5th gear does, I'd say you're a little backwards in your statement.
Plus, 1200 can be a little much for a clutch to handle. Powerglides/automatics are really the only way to go.
Old May 18, 2009 | 12:19 PM
  #150
YaXMaNGTO's Avatar
It's a Cavalier
An RX8 with a carburator poking through the hood? Seriously?
I don't even like anything retro, like shaker hoods, on our GTO's. On the RX8? It would like like some schizo "Mad Max" car.
He is going to use some type of shiftronic 6 speed auto transmission. He's not building it to drag race... a 2 speed powerglide is probably out the question.
Paging rgonza!!!! Any updates?!?!
