Ignition timing for turbo or supercharged renesis - post your maps
Old Sep 8, 2009 | 07:02 PM
  #101
Brettus's Avatar
Boosted Kiwi
/\ wow - really ? how much powa ?
how do your EGTs look ?
I spoke to a old school rotary tuner here about timing and he thought i was running way too advanced . How come the Renesis can take it ?
Old Sep 8, 2009 | 07:03 PM
  #102
Kane's Avatar
EGT's are pretty cool 1400-1600 or so.
Powa-wise.... well I gave Chickenwafer the same timing changes...
Old Sep 8, 2009 | 08:50 PM
  #103
MazdaManiac's Avatar
Originally Posted by Kane
Id put some back in there up top.
Mine get to about 17-18 at torque peak and get up to 22-24 after toward redline... gives it some more powa...
On good fuel.
Around here, 1° or 2° more at the torque peak than what he is running will ping.
Its all a balancing act. There is more power to be had from 1 AFR point leaner than 1° of timing.
If the EGTs are good, I'd only bump the <175% up a good margin. That is where this timing table is lacking.
A whole bunch of resolution is being wasted on the 150% - 200% range.
Wasting half of the table's resolution from 100% - 200% isn't productive. I do all of that in 4 columns and save the rest for drivability and transition.
Old Sep 8, 2009 | 09:26 PM
  #104
Brettus's Avatar
Boosted Kiwi
Originally Posted by MazdaManiac
On good fuel.
Thanks for the input
Old Sep 9, 2009 | 12:30 AM
  #105
Kane's Avatar
On good fuel.
I keep forgetting about bad gas... been spoiled I guess.
Old Sep 9, 2009 | 01:04 AM
  #106
Yeah. Most of the 91 here in PHX is really 89.
Old Sep 9, 2009 | 11:54 AM
  #107
Mawnee's Avatar
I divide by zero
How does the ECU handle settings between tuning points if you lower the resolution for the 100-200 load areas? Does it stay on the previous setting until it reaches the next setting point or will it scale between them depending on which it is closer to?
Old Sep 9, 2009 | 11:55 AM
  #108
Kane's Avatar
It interpolates...
Old Sep 9, 2009 | 01:33 PM
  #109
Mawnee's Avatar
I divide by zero
It interpolates...
Ahhh perfect. So if I wanted to change this its as simple as plotting the scale that i have now and simply using whatever reference points on that scale that the new resolution needs
Old Nov 18, 2009 | 04:05 PM
  #110
Derex'8's Avatar
ReDuX
Would it be possible for someone to please post their Turbo timing maps up in excel format.
Also I'm not to excel savvy so would it be asking to much if someone could work on a Timing worksheet with Leading, Trailing and a Split table, that allows to adjust the leading & trailing by chaning the split values? THIS WOULD BE ABSOLUTELY GREAT!
Old Nov 24, 2009 | 08:27 AM
  #111
lehh1985's Avatar
hey am luis i have a rx8 whit a t70 turbo 1000 cc inj en ultimate greddy and a brand new but is runnin way rich how can i lower the injection until i get it tunne
Old Nov 24, 2009 | 12:57 PM
  #112
Brettus's Avatar
Boosted Kiwi
/\ t 70 -greddy e-mangle - no tune !!!!! oh dear
If you can't alter the e-mangle settings yourself all you can do is put the stock injectors back in and stay out of boost till you get a tune .
what posessed you to put that monster turbo in there - any pics ?
Old Nov 25, 2009 | 08:12 AM
  #113
Kane's Avatar
Can you meet with me and Nuke this weekend? I can give you all the help you need.
Old Nov 25, 2009 | 08:15 AM
  #114
Kane's Avatar
Same size as the Esmeril kit pretty much.
Old Nov 25, 2009 | 09:05 AM
  #115
Luckycat's Avatar
Here this is the T-70 turbo from Esmeril kit
Old Nov 25, 2009 | 12:43 PM
  #116
Brettus's Avatar
Boosted Kiwi
oh yeah , forgot . What possesed Esmeril to put that monster turbo in there ?
Old Nov 25, 2009 | 12:48 PM
  #117
bigger is better?
Old Nov 25, 2009 | 12:51 PM
  #118
Brettus's Avatar
Boosted Kiwi
stop going below the belt Jedi and stick to the subject at hand - oops that came out wrong ....
Old Nov 25, 2009 | 01:39 PM
  #119
Kane's Avatar
If I can't say anything nice...
Old Nov 7, 2010 | 07:52 AM
  #120
SC-ed's Avatar
How is this for a base FI timing? Isn't it too safe?
Attached Thumbnails Ignition timing for turbo or supercharged renesis - post your maps-timing.png
Old Nov 7, 2010 | 08:36 AM
  #121
Kane's Avatar
Shouldn't be too bad for a starter, what are your IAT and EGT's with that timing?
Old Nov 7, 2010 | 06:00 PM
  #122
SC-ed's Avatar
IAT 15-25 above ambient 40-45 right now. Don't know about EGT. Any concerns about them (timing related)?
Old Nov 7, 2010 | 06:17 PM
  #123
Brettus's Avatar
Boosted Kiwi
Considering that most of us run another 10 degrees (ish) than that table it does not seem to serve a lot of purpose to run quite that retarded .
Old Nov 7, 2010 | 06:24 PM
  #124
olddragger's Avatar
guess i am running lots more timing that others?
OD
Old Nov 7, 2010 | 06:28 PM
  #125
Considering that the REW runs 9° at peak torque and it is one point of compression lower than the MSP...
