Renesis NC Track Car - In the Build
Old Mar 28, 2009 | 06:54 PM
  #101
timbo's Avatar
rock-->o<--hard place
Originally Posted by CanOfWorms
I have been following for some time, and always had the itching thought of "why doesn't he go with Hymee?"
My question was answered
Exactly my thoughts. In fact I thought it would be too hard to resist.
This is becoming even more interesting
Old Mar 28, 2009 | 07:37 PM
  #102
Revolver's Avatar
Shootin' from the hip
NOW I understand the brake package!!!
What's the ask for one of Hymee's kits?
Old Apr 10, 2009 | 07:24 AM
  #103
ORX-800's Avatar
Hi Dave, sorry about the late reply....I think it will be around the AUD10,000 mark. Correct me if I'm wrong Hymee. Well I know that he is selling them for USD7,500.
Cheers,
Danny
Old Apr 10, 2009 | 07:25 AM
  #104
ORX-800's Avatar
Good Friday has certainly been very good from a project progress perspective. :D
Today, with the help from one of my employees (TIG welding Guru - because I can't TIG weld ) I completed the exhaust system. :mrgreen: It took a bit of effort...and I'm stoked with the result. You may remember from an earlier post that I was using a JDM aftermarket NC rear muffler assembly. It had a 2.5" inlet that split into two 2.5" pipes. However, due to the higher flow requirements of my engine, a 3.0" front section is required. Two 2.5" pipes have about a 39% larger cross-sectional area when compared to a single 3.0" pipe. So I lopped off the 2.5" inlet and massaged a 3.0" to the profile of the 2 x 2.5" junction.
Anyhow, before I got stuck into that I sorted a problem with the standard NC exhaust heat shield. The heat shield is an aluminised fibreglass moulding that had been damaged at some point and had sagged....problem solved....2 x oversized heat rivets. :mrgreen:
Since the rear section of exhaust was stainless steel, I continued with the theme and had exhaust flanges laser cut (and machined where necessary).
Will all exhaust systems I make for my vehicles I use the good ol' masking tape to join the various bends and straight sections prior to welding it out....reduces the chances of a stuff-up.
Corndog - The TIG Guru :P
...after many hours this was the end result. This is the rear assembly with the 3.0" inlet and 3-bolt flange fitted.
This is the front section that connects up to the headers. Look Mum no cat!!! 8)
.....fitted to the car. I'm stoked with the result.
I also took the opportunity to fit the Mazdaspeed front bar. It certainly provides a bigger aperture for ambient air to access the radiator.
By this time it was getting late, but I did get to fit the right hand rear footplate for the roll cage.
Can't wait of next weekend to continue with the rollcage.
Cheers,
Danny
Old Apr 12, 2009 | 02:42 AM
  #105
rotarenvy's Avatar
nice transition from the 3" pipe. it's sure going to be loud with a 3" no cat systems and the flow of a supercharger!
Old Apr 14, 2009 | 12:55 AM
  #106
Revolver's Avatar
I think the technical term you're looking for Jarl is ******* LOUD!!!!
So, not planning to run it at Lakeside then Danny?
Old mate with his crappy noise gun would have a fit...
Old Apr 14, 2009 | 01:06 AM
  #107
ORX-800's Avatar
Yeah Dave, I'll more than likely need a 44 gallon drum for a muffler strapped under the rear to get it passed the Lakeside noise ****!!!
Cheers,
Danny
Old Apr 19, 2009 | 06:06 AM
  #108
ORX-800's Avatar
During the week I made first contact with Phil Laird (the engine management supplier / tuner) to make arrangements for the installation of the Motec M400. It looks like that in mid to late June he will have a gap in his busy schedule to start the installation. :D This timing is pretty good as the supercharger kit should be available not long after.
A little bit more progress was made today with the removal of the dash and chassis/dash wiring looms. I also removed the remaining section of carpet and firewall lining so that I can get some dry ice and remove the few sections of sound deadener. This all needs to be sorted before the cage gets welded in.
Here are a few piccies showing the removal of said items.
The foot plates for the main hoop fit!!!
...and she is still dirty as!!! :oops:
Cheers,
Danny
Old May 1, 2009 | 11:51 PM
  #109
MiniMeg's Avatar
Yea, I think that exhaust system might be a tad loud for the street.
Man you do nice work.
Good Luck.
Old May 4, 2009 | 07:42 AM
  #110
ORX-800's Avatar
Not too much has happened in the past fortnight .
Spent a few hours yesterday paring out the extraneous crud from the dash and interior chassis looms . I successfully removed the SRS (airbag & seat belt pre-tensioner) system and the wiring to the instrument cluster. I still probably need around another 12 hours on it before putting it back in the chassis.
Another point of note is that I have ordered the Motec ECU. 8) After another discussion with the tuner regarding my expectations, it was determined that the M800 was required as I needed servo control for the oil metering pump.
.....oops, I almost forgot that I now have a tow vehicle to move this thing once it is finished. It's the one on the left! .
Cheers,
Danny
Old May 4, 2009 | 05:41 PM
  #111
Revolver's Avatar
Oh no! All your extra money is now going to go into keeping the big white beast in fuel - they drink worse than the RX8!
I really think Mazda should sponsor the rest of the build...
Old May 4, 2009 | 05:49 PM
  #112
ORX-800's Avatar
haha...that would be nice! I've certainly thrown a bit of coin their way over the past 20 years.
Old May 4, 2009 | 09:29 PM
  #113
Tim Tam's Avatar
I SO want a Hymee SC now. That fitment looks awesome, and some good numbers on the charts. It'd be a crime to refit the standard engine cover over the top of that work of art!
Now how can I get $10grand without the missus noticing???????? (which seems like a great price by the way)
Old May 4, 2009 | 09:59 PM
  #114
Revolver's Avatar
Group buy?
Old May 8, 2009 | 04:54 AM
  #115
ORX-800's Avatar
The wait was certainly worth it....get a load of these puppies!!! :P
Picked them up from the machinist yesterday.
They fit the caliper...which is a good start. :D
Will see if the fit the rest of the brake assembly tomorrow. Fingers crossed! :D
Cheers,
Danny
Old May 8, 2009 | 09:30 AM
  #116
DMRH's Avatar
Ha, cant be as bad as a CX-7. Since moving the family RX-8 off to its new owner I have been moving a lot more petrol into our CX-7 compared to the previous RX-8.
Best HWY
RX-8 = 10.0lt / 100km
CX-7 = 10.5lt / 100km
average CTY
RX-8 = 13.5lt / 100km
CX-7 = 16.5lt / 100km
We now return you to regular MX-5R programming.
REgards
Old May 9, 2009 | 06:10 AM
  #117
ORX-800's Avatar
We've only just used the first tank of fuel Dave. I'll let you know how the economy is going after this next tank.
Well I trial fitted the front brake assembly today....this is how it went. :mrgreen:
Bare upright and hub.
Caliper bracket fitted.
Rotor fitted.
...caliper fitted :twisted: .
The last test was to see whether the track rims (Enkei RPF in 18 x 8.5) would clear the brake assembly.
I couldn't have been happier with the result as there is plenty of clearance both radially and laterally....another box ticked. :D The caliper brackets will be hard anodised before the car hits the track.
For the rest of the day I continued paring out the wiring loom. It's slow getting smaller.
Cheers,
Danny
Old May 9, 2009 | 11:26 PM
  #118
JantzenRX-8's Avatar
This thing is absolutely ridiculous.
Props man. This thing is going to be awesome.
Old May 10, 2009 | 04:55 AM
  #119
DMRH's Avatar
Now thats just pure sex. Can some one rate this thread XXX please
REgards
Old May 10, 2009 | 05:48 PM
  #120
Revolver's Avatar
Awesome stuff Danny!
I like your idea of lots of clearance, lol. Looks pretty bloody tight to me.
Love the red and gold...
Old May 11, 2009 | 01:22 AM
  #121
skc's Avatar
skc
rev it up
You may need some ducting to keep the brakes cool
Old May 11, 2009 | 01:49 AM
  #122
Revolver's Avatar
Do you really think so?
If anything, I would have thought this car will be overbraked. It'll be a pretty light car when he's done. Can't see it being too hard on brakes, even with the performance potential.
I suppose you could cut vents in the front guards aft of the wheels to allow heat to escape...
Old May 11, 2009 | 02:02 AM
  #123
ORX-800's Avatar
You're correct Dave and for that very reason I'm sticking with the road spec brake pads.
Cheers,
Danny
Old May 11, 2009 | 02:51 AM
  #124
Revolver's Avatar
Fair enough. You can always change them if you have to...
Old May 28, 2009 | 04:16 PM
  #125
Salamanth's Avatar
This is... amazing. It almost makes me want to fly to Australia when it's done just for a ride in it.
Either that, or have you send me duplicates of your parts so I can make a USDM version of it
This should be in one of the main forums, it's too good to be hidden in the Australia thread, I found it by accident!
