Series II DIY DIY projects specific for Series II RX-8s
DIY: Series II 2009 RX-8 Oil Change
Old Aug 9, 2010 | 01:03 PM
  #51
Beefy98's Avatar
Originally Posted by ASH8
As I said I would wait for engine to get HOT..TURN OFF .then drain.
Christ can a rotary engine even survive in Australia? Isn't it like 400 degrees there?
Old Aug 13, 2010 | 05:59 PM
  #52
ASH8's Avatar
Super Moderator
401 degrees actually.....Coming out of Winter ATM, wet and COLD!
Old Aug 15, 2010 | 03:26 PM
  #53
Beefy98's Avatar
Originally Posted by paimon.soror
I dont mind the oil pan guard .... i hate that the filter is so damn hard to get to compared to the S1
I'm the opposite. The guard is a total pain wrenching 14 bolts. the filter comes right off and tightened on with a Griot's claw style filter wrench.
Old Sep 21, 2010 | 12:05 AM
  #54
WankelRenesis's Avatar
Originally Posted by jasonrxeight
I went to the dealer to change oil today
the guy changed the filter and put 4.5qt's of oil in the engine now its about 1-1.5cm above the full line. ****
Im gonna change the oil myself next time. never trust someone else.
I had the same problem you did at the dealership. I called and complain that my local mechanic would have done a better job and charge me alot less. Maybe the mechanic was just haten' you know envying our rides. An old saying "if you want something done right, do it yourself" Peace
Old Sep 26, 2010 | 03:02 AM
  #55
lucifuge's Avatar
I'm laughing my head off, this is so funny.
Old Sep 26, 2010 | 03:38 AM
  #56
ASH8's Avatar
Super Moderator
My state (South Australia) has just come out of our Coldest Winter in 40 years!!, and one of our wettest (rain) in over 15 years...finally we seem to have broken our 10 year water drought, all our reservoirs and dams are overflowing!!
But how can this be...all that Global Warming/ Climate Change BS..
Old Oct 7, 2010 | 02:04 PM
  #57
Beefy98's Avatar
just did my 2nd oil change. what a nightmare that metal sheet with the 7 screws is. I wanna strangle the engineers. My neck is effed.
BTW, if you use Castrol jugs be careful there are now 3 sizes. The 4 qt, the 5 qt, and now a new 5 liter which is 5.3 qts! The last 2 look identical. Be careful to read the graduations on the side right.
Old Oct 7, 2010 | 04:10 PM
  #58
Beefy98's Avatar
I want to cut the metal guard as shown. the big part will stay intact and u can drain the oil thru the hole already there. then the smaller piece on the side can be removed with one screw so u can acess the oil filter.
Old Oct 7, 2010 | 04:34 PM
  #59
ASH8's Avatar
Super Moderator
Can't see any reason why not...
I know it is a PITA, I remove 6 of the 7 bolts and leave the middle Rear one loose, and then just SWING the complete Sump Guard around and out of the way...that way you do not need to remove the tray completely.
AND remember these Trays Cost a Fortune...over $400 Retail
F189-34-H80D Under Cover
Old Oct 7, 2010 | 05:02 PM
  #60
paimon.soror's Avatar
Not a bad idea to cut, but you will be modifying its structural properties. This doesn't mean much, except that you may get some unwanted rattle on that edge.
Old Oct 14, 2010 | 07:54 PM
  #61
yoluun's Avatar
ロータリー最高!
Thanks for writing up this great DIY. Did my first oil change today.
I have a 2010 model but my fumoto drain valve doesn't fit (without the ADL). I wonder if anyone else has this problem.
Old Jan 3, 2011 | 09:37 AM
  #62
renebree1018's Avatar
just did my change thank you sir. good day sir!
Old Feb 20, 2011 | 12:36 PM
  #63
Mazurfer's Avatar
Surf Hard, Drive Hard
I'll admit...............this post is mainly intended for Ash!
Was helping a fellow member("T", who will be reading this eventually) in doing an oil/filter, plugs, and air filter change this morning on his 2009(S2).
Now, we could've drained the oil without pulling the sump plate, but since I had never done an S2 and needed to get at the filter, we went ahead and dropped the plate. First, I had to find the friggin filter! (ha ha)
Even given the plate removal(which isn't that bad, just do it...............don't bother swinging it on one bolt, just drop it and get it out of the way), I found it to be a huge pain in the **** in getting the oil filter out and new one in.
What freakin genius came up with that placement?
Keep in mind I have a series 1, so my oil filter cap wrech tool wouldn't work, but even so..........and I have several other types(some of which are pictured above), but there has to be a better way!
Have you tried going through the wheel well to get at that filter? What is the recommended tool for this(although I'm off to search here in a moment)............is it just the series two type cap wrech tool and the right socket extension with swivel?
("T", the fellow member), it looks like most people are saying use the "Griot's claw style filter wrench", but I wanna ask Ash what is the best?
As we discussed, I usually put mine on hand tight and then just a little bit more with a wrench, and was able to do the same thing your car, but was more jerking around than it should have been given the tightness of the space.
I just found that they do have the cap type tool for you car...............see............. http://www.finishlineperformance.com...cat=273&page=2
"T", I'd be leery about getting it at Autozone to get this as you didn't take your old filter, and the sizing would be crucial. Think I would just buy it from the above next time you need more stuff!
Good news................plugs went real well.......no issues and was cake(Um.....pie.........I mean....I like pie!).
One last one before I go look it up Ash.
What the hell is up with changing the air filter on the S2's?
True I haven't has my intake be stock in a long *** time, but I don't remember it being like it was for us today.
I finally said screw it and loosened the accordion to MAF tube clamp and then forced the intake box lid(if you will) up and back enough so he could grab the filter, yank it out, and replace with a new one.
Has it been that long for me, was the series 1 this way as well?
Seems like a pain in the ****.......so I'll have to search and see how it's supposed to be done on a series two.
Dave
Old Feb 20, 2011 | 01:20 PM
  #64
I saw that there is a nice little hole to get to the filter from the wheel well as well. If we can find a simple way to do a change from in there it would make life a whole hell of a lot easier than having to remove the sump guards and jamming our hands up the birth canal of the car. Damn rediculous.
And yea, I took my filter out the other day to remove the walls, and the damn thing is so hard to get to. Watched some vids online of S1 guys doing the filter box removal and looked easy, but the S2's are like using industrical grade plastic and rubber that u need an *** load of force to push back that box lol. On top of that you feel like you are going to break the accordion connector.
Old Feb 20, 2011 | 01:35 PM
  #65
Mazurfer's Avatar
^................well, then so far I didn't make any really non-intelligent mistakes!
If you look at the wrench tool I linked above, I do believe using that, a small extension, and possibly a swivel, you could get at it through the wheel well. If it wasn't put on by a monkey, you might even be able to remove it by hand. I guess this method would only make sense if doing a plug change at the same time.
I was cautious with the brake line that's right there, but I could get my hand in there and position it for possible torquing/un-torquing.
Old Feb 20, 2011 | 02:15 PM
  #66
Mazurfer's Avatar
And...........I was disappointed at myself because this whole thing took twice as long as it really should have.
At one point, we actually came in and looked at this thread because I wasn't expecting an MM Allen for the oil drain plug and couldn't believe it was really that. I keep looking back and what I guess was the transmission drain plug and pan? Looked more like and oil pan to me and look like it had the drain bolt I was expecting. More so than what I was looking at!
Once again, this site proves invaluable! Yes, I would've found out as soon as I let it weep out a little, but we figured we'd better check. Glad we did.
So.......Ash.....if the sump pan has an internal magnet, why place one on the outside(filter)....which is what I believe I have heard reference to.
Old Feb 20, 2011 | 04:54 PM
  #67
ASH8's Avatar
Super Moderator
1. Air filter Removal is No Different to any other OEM RX-8.
2. Swinging the Oil Pan PLATE back on ONE bolt makes it a lot easier to relocate, rather than completely removing and putting it back, particularly if you only have say 8" of space to work in.
3. Yes, IMO the "Oil Filter Cap" is the ONLY way to remove S2 Oil Filter and preferably access through the LH front Wheel removed.
Having changed my Oil Filter about 8 Times I consider my self an expert, and it is still A PITA.
4. Oil Filter Magnet, haven't you ever heard more can sometimes be better...
a) Internal Pan Magnet is permanent (you cant easily remove it or even clean it)
b) Material caught inside the Oil Filter is removed when renewing Oil Filter, and YES you do get metal inside filter can, I have shown that.
IMO the Oil Pan Magnet is only good when the car is standing and oil has/is settled.
Old Feb 20, 2011 | 05:22 PM
  #68
1. Removal process is no different but I wonder if the materials used is different, seems a bit more "tough" which I believe is attributed to thicker plastics? who knows.
2. Yup, I agree, do this every time. You do have to "pull down" a bit to fully swivel past some of the underbody compnents, but def makes the job easy
3. I will have to give this a shot. I can remove the filter no problem from the under side, but if I can remove and replace then maybe I wont need to jack the entire car up.
4. I saw your thread about this. I will have to snag one of these when i get some extra funds.
Old Feb 20, 2011 | 06:01 PM
  #69
Beefy98's Avatar
Wait did I hear this correctly? You can access the filter from the wheel well without taking off the blasted metal plate? But I dont have jack stands..
And what is the part # for the cap style oil wrench, as I'm afraid to buy anything for an RX-8 for fear that it wont fit the S2.
Old Feb 20, 2011 | 06:04 PM
  #70
? But I dont have jack stands...
Just use the scissor jack at the front driver side then. Its easy to see once you remove the wheel.
Old Feb 20, 2011 | 06:25 PM
  #71
Mazurfer's Avatar
See I had forgotten, must be my "old timers" disease creeping in.
Meh, wasn't my car and didn't want to possibly bend it in any way, so I just dropped it completely. Not that big of a deal.
Agreed!
True that......guess I really didn't think it completely through.I is a retard!
Hmmmm....I suppose so.
Thanks for taking the time to respond, I do appreciate it!
Old Feb 20, 2011 | 06:32 PM
  #72
Mazurfer's Avatar
Aw..............c'mon...........lining the holes back up ain't that tough! Well, whatever works for each I suppose. I looked at it as one less thing that would end up slicing me in some manner at some point.
Looks like I need to search on this magnet to the oil filter and read up on it.
Old Feb 20, 2011 | 06:35 PM
  #73
ASH8's Avatar
Super Moderator
YOU NEED SMALL HANDS
Old Feb 20, 2011 | 06:37 PM
  #74
Mazurfer's Avatar
I linked it above but here is one place you can get it.
It seems like it would be a combo of ratchet extensions(length) and possibly a swivel, kind of like the several combo's that makes the plugs easier.......but it looks entirely possible and if Ash says so...........then it's gotta work. I guess you either drop that plate, swing it out of the way, or.........take the wheel off and go through there. Pick your poison.
Old Feb 20, 2011 | 06:39 PM
  #75
Mazurfer's Avatar
Damn it.....ya beat me to it!
See below!
It does look like with a swivel and the right extensions, you could get the ratchet all the way out to the wheel well. Of course you'd have to be careful as there a brake components afoot out there and you would want to slip, but just breaking it loose or giving it that one final 14/ to 1/2 turn, it looks plausible. Either that or yes..............rent someone with small hands!
