Ignition timing for turbo or supercharged renesis - post your maps
Old Apr 27, 2009 | 07:28 AM
  #51
carbonRX8's Avatar
U-Stink-But-I-♥-U
Why do timing threads turn into crapfests?
This was particularly non-enlightening.
The way I see it, if the experts want to keep all the secrets to themselves, I am COMPLETELY ok with that. They deserve that and our respect. But us bumblefucks want to figure some of this **** out for ourselves. I suggest that be respected as well and leave the misdirection, intentional or otherwise, out of the discussion.
Old Apr 27, 2009 | 10:12 AM
  #52
r0tor's Avatar
Originally Posted by Flashwing
Kane, it will probably be around 24 hours before I can get any information back to you but here's something for you to consider.
At first, I recall that we used a broad 30% increase in the AP values just to see if the issues we were experiencing were in fact dwell related. We kept everything else the same as our control. A 30% increase did seem to correct any spark blow out on the turbo RX8. I have been using an adapted version of those settings with adjustments made to back the dwell off in the lower and upper RPM range where a stronger spark isn't needed.
30% increase by multiplying the map by 1.3 or .7?
Old Apr 27, 2009 | 10:58 AM
  #53
Kane's Avatar
I am pretty sure it would be 130%.
Interestingly enough - Flashwings post is the first truly concise post here that actually answers my question exactly!
Add some validation and life would be good.
Old Apr 27, 2009 | 11:34 AM
  #54
r0tor's Avatar
i thought so as well, however bothered by Jeff's "fundemental misunderstanding of the factory dwell table" quote, I scared myself by finding out the OEM map numbers could be represented basically by the crank angle charging needs to start at multiplied by a scalar
but i'll just make it "5" and be done with it
Old Apr 27, 2009 | 11:36 AM
  #55
kane i swept up a little. let me know if ive missed a spot. bhr and fluid- unless you have facts to add to the search these folk are on stfu the lot of you
Old Apr 27, 2009 | 01:35 PM
  #56
Brettus's Avatar
Boosted Kiwi
Interestingly this thread was supposed to be about timing and not Dwell . Not that i'm bothered with that as at least SOME information has come out of the ensuing crapfest ....
Old Apr 27, 2009 | 01:49 PM
  #57
all apologies to brettus- let me know if there is anything else i can sweep up for you.
Old Apr 28, 2009 | 06:47 AM
  #58
robrecht's Avatar
Originally Posted by MazdaManiac
Fortunately, since I'm not financially tied to any of the coil solutions at this point ...
Don't you and Ray hold some kind of patent, or have at least applied for one?
Old Apr 28, 2009 | 11:24 AM
  #59
MazdaManiac's Avatar
Yes. I have patents, trademarks and copyrights on MANY things.
Very few of them make me any money.
Old Apr 28, 2009 | 12:32 PM
  #60
Originally Posted by Brettus
From another thread - posting it here for future ref.
I had asked Kane if the factory dwell of 595 = 5.95 ms ...
This seems logical and would be my guess.
So then, the BHR coil dwell is too high for peak performance?
Old Apr 28, 2009 | 01:06 PM
  #61
Ugh.
Take a look at the OE dwell table. You will see that the value for idle is around 1100.
Do you really believe the OE dwell request is for 1.1 seconds at idle?
If your alternator output is low, it jumps to 1.4 seconds!!!!
Do the math.
The dwell table is not in milliseconds.
The OE coils are special.
The LS2s have the widest dwell range imaginable.
However, this is not rocket science and all you Secret Squirrel nut cases need to get your heads out of your asses and stop acting like I owe it to you to spoon feed you.
Old Apr 28, 2009 | 01:07 PM
  #62
THAT'S IT!!! Screw you guys, I'm reinstalling my Mazsport Coils since it's the best system EVAR!!!
Old Apr 28, 2009 | 01:19 PM
  #63
Kane's Avatar
So I guess that was a "no" on the diversification of labor idea...
Old Apr 28, 2009 | 01:21 PM
  #64
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
Dummy, you never owned a Mazport coil set
Old Apr 28, 2009 | 01:30 PM
  #65
Roariee's Avatar
It was this big! No lie!
poor timing...to watch
dwelling on my poor timing...
hah
Old Apr 28, 2009 | 01:36 PM
  #66
What do you mean? That I do all the labor and you read about it?
  #67
Roariee's Avatar
Funny how that works...moar money to get the damned things most of the time...
And if anyone gets anything outta the whole thing...its the attys...
I got into the wrong profession...
Its certainly is not rocket science...more a touch electrical engineering, stabbing and poking charged terminals with conductive objects...and playing with fire...
Oh...and nuts...cant do any of that without your nuts handy...
Old Apr 28, 2009 | 01:38 PM
  #68
Roariee's Avatar
Or release time-lapse videos...your damn right thats what i want! Get back into your dungeon and get to blowing your **** up for my amusement and knowledge...
Old May 22, 2009 | 04:45 AM
  #69
a_ahlan's Avatar
Anji
Dwell
Kane,
I work with Ignition computers as I'm involved in conversion of Diesel engines in to NGV (Natural Gas). In the software I use to program the stand alone ignition computer, the dwell value can be adjusted in - % percentage. Basically 100% would mean dwell will be same duration as the spark duration. 110% means the coil will take 10% longer to charge and then provide spark with the same duration.
Looking at my SPT dwell map, could the map be battery voltage vs % time of dwell? That would mean 1208 might be 120.8% and 395 might be 39.5% of spark duration.
Old May 22, 2009 | 10:11 AM
  #70
Kane's Avatar
Hmmm - could be. But the scale on the 3D graph would be off....I am kinda at the point where I don't know what it is - I just know how to make it better...... not the best plan but it does work.
Old May 22, 2009 | 12:56 PM
  #71
Originally Posted by a_ahlan
Kane,
Wow. There it is. (EDIT - Sorta. Its not a direct % of available spark time, but crank rotation time.)
So after months of speculating and even erroneous input from people who are actively involved in RX-8 calibration testing and development, it took a professional ignition calibrator's input to figure out what I managed to figure out in my garage in 10 minutes with a cheap scope meter.
I'm not picking on you, a_ahlan. You are just sharing what you know.
But its just sad that all of the whiners in this thread just couldn't be bothered with the R&D, just because they knew someone had already figured it out.
It was more worthwhile to complain about it.
Old May 22, 2009 | 03:05 PM
  #72
RK's Avatar
RK
It's Not Easy Being Green
Always nice to remind people that you knew the information and kept that knowledge away from BHR customers who hadn't subscribed to your service for months. All your claims of not being able to share your hard work turns out to mean 10 minutes alone with a scope meter.
You've made your point. I'm sure the relatively small hit to BHR's rep as a company that exhanged information freely with the RX-8 community about products was well worth it. Hard to put a value on that.
Not quite as hard to put a value on the subscriptions you picked up.
Old May 22, 2009 | 03:51 PM
  #73
rotarygod's Avatar
Um you guys do realize this thread is about IGNITION TIMING MAPS right? Why is there far more arguming on dwell than there is on timing maps? Get it on track or start a new thread.
Old May 22, 2009 | 08:52 PM
  #74
Mawnee's Avatar
I divide by zero
I will still pay a few hundred bucks for the electronic guy who can get my RPM "BEEEP" to change to "SHIFT ************!!!!" In Samuel Jacksons voice.
LMAO best post in the thread
Old Jul 4, 2009 | 02:09 PM
  #75
outinnowhere3193's Avatar
outinnowhere3193
It cracks me up the **** I read and hear people talk about.. I mean don't get me wrong I've done a lot of stupid ****. As far as the LS2 coils I did my own setup with them and I'm thinking I'm set at 3.5ms.
When I set at a idle and rev my car it misses at like 4k and 5k but when you drive it...there is no miss.. I've turned and boost a few dozen times to 14psi and those coils have no misses what so ever when I'm driving.. I can cruise at the 4k or 5k without a miss but can't no load rev that high...stead that high. If I just hit the throttle and rap it out for the sound there is no miss.
By far I like the LS2 coils way over the OEM...it only took me 2 weeks till I had miss fires like no other on OEM that is.
