Series II DIY DIY projects specific for Series II RX-8s
DIY: Improve OIL Cooler Air Flow Up to 10-15%
Old Jul 23, 2009 | 04:40 PM
  #51
SARRAS's Avatar
Sydney, Australia
Originally Posted by stanknasty56
wow thats a pretty cool diy mod, wish i would of known of this when i was putting on my new rotors, too bad they dont make small fans we could just put behind the oil coolers, that would be bad ***
go over to https://www.fluidmotorsports.com/ and check under RX-8 and then under Radiators and Cooling - there be Fans!
Old Jul 24, 2009 | 12:58 AM
  #52
try this one..
link for fans..
Old Sep 2, 2009 | 01:21 AM
  #53
ASH8's Avatar
Super Moderator
AU DIY: Oil Cooler Air Flow Modification No.2
6 months ago I changed my Oil Cooler Inner Fender Vents by making holes Larger (see thread).
https://www.rx8club.com/showthread.php?t=168650
However, still not happy with the restriction of Air Flow I did this to vastly Improve Air Flow through my Oil Coolers.
I bought another new set of OEM Black Plastic Fender Vents to keep and use only for Winter, so my car is back to stock at the moment...(it is Winter here going into Spring).
With the Original (modified) set I removed ALL the Plastic Molded Step Ribs which left me with a very large hole matching the actual size of the Oil Coolers mounted in the front of car.
I locally purchased some Aluminum Screen mesh for $3.00, and cut 2 pieces to lap over the hole on the inside of the liner, I then slightly bent the mesh so it was in the same "curved" form or shape to the original.
It is important you fixed the mesh so the "Diamond Pattern" is VERTICAL, it is too hard to bend if Horizontal.
Using 10 Pot Rivets and 10 small washers for each side I fixed the mesh to the plastic liners very firmly, the end result can be seen.
So, will it work, IMO it has to be far better than original.
Once Summer arrives I will swap over to my new mesh liners, when temps reach about 77F or 25c.
Very easy to remove the 9 Black quick clips and 3 screws, each side.
I won't be using these during Winter because of road water and too much cold air.
Sorry, I cant give you Test results yet, but stay tuned.
IMO this is the best outcome to lower oil and help engine temps for Summer.
Having said that Oil Cooler Fans would be ideal for long periods in traffic or when stopped.
I will see how this goes, but it will throw far more hot air out than any fan, provided you are moving.
The cost..
$112.00 for the two new liners, $3 for the mesh, Rivets and Washer I had in stock.
Swoope (Scott) this one is for you...mate...
Attached Thumbnails DIY: Improve OIL Cooler Air Flow Up to 10-15%-1.jpg   DIY: Improve OIL Cooler Air Flow Up to 10-15%-2.jpg   DIY: Improve OIL Cooler Air Flow Up to 10-15%-3.jpg   DIY: Improve OIL Cooler Air Flow Up to 10-15%-4.jpg   DIY: Improve OIL Cooler Air Flow Up to 10-15%-5.jpg
Old Sep 2, 2009 | 01:28 AM
  #54
ASH8's Avatar
Super Moderator
Forgot to add..
You can position the Vertical Diamond Mesh, so the "Curved" side of the Diamond is shooting hot air flow out towards the wheel opening and not towards the engine bay....another plus..
See 5th pic..
Old Sep 2, 2009 | 01:31 AM
  #55
Wind Dance's Avatar
Central Valley RX8
Cool, this plus fluidmotorsports oil cooler fans should be quite a combo.
Old Sep 19, 2009 | 02:21 AM
  #56
Ooooh I like this... nothing like free mods
Old Sep 19, 2009 | 08:10 PM
  #57
viprez586's Avatar
05 RX8 Sold///05 Evo VIII
Paint them black and they'd be super stealth. Good job, I'm actually considering doing this since I only drive my car in summer.
Old Sep 19, 2009 | 08:28 PM
  #58
Very Good!!!!
Old Sep 19, 2009 | 08:33 PM
  #59
Brettus's Avatar
Boosted Kiwi
interesting - you will need to be careful the mesh does not clog over time or else you may get the opposite effect ...
Old Sep 19, 2009 | 09:08 PM
  #60
@!!narotordo's Avatar
FLAME ON!
Yo ASH8 I got some info coming for for ya.
I took off my right side liner. My left one is still on. I parked my car and will hit the oil coolers with a infrared gun thermometer to see what the numbers are. Care to take a guess at the different heat numbers?
Old Sep 19, 2009 | 09:09 PM
  #61
FLAME ON!
Thumbs up
+1 I cant wait to get some fluid ftw!
Old Sep 21, 2009 | 03:05 PM
  #62
michaelsk8er's Avatar
Where did you get the extra set of liners? I assume the dealership for a premium?
Old Sep 21, 2009 | 03:11 PM
  #63
check with Paul @ Mazmart or www.onlinemazdaparts.com
  #64
Ash: nicely done mate! Paint those guys black and you'll be all set.
just make sure to keep those clean so they don't clog up
Old Sep 21, 2009 | 05:28 PM
  #65
ASH8's Avatar
Super Moderator
Considering they are only for Summer and I will be replacing them with the OEM's for Winter, any "debris" and I consider there will be little would clearly seen when I swap them over after 7-8 months.
It would go a long way before it came close to the restrictive air flow of Originals.
Thanks Jedi
Old Oct 18, 2009 | 03:18 PM
  #66
ASH8's Avatar
Super Moderator
Hot!...what were the numbers mate...
Old Oct 18, 2009 | 10:01 PM
  #67
KRMRX8's Avatar
Numbers would be good to see however, all that screen mesh seems to add up to covering at least 60% of the total area. Imagine pushing all the screens strips together so it forms a solid piece. How much is left for an opening then? I suspect the numbers will be similar or worse with the diamond style screens.
Old Oct 18, 2009 | 10:09 PM
  #68
JinDesu's Avatar
went back to srsly broke
I'd be more interested in air turbulence. I don't know if it affects airflow, since it's after the coolers, but meshes are more destructive to airflow than open ducts.
On the note of area, the stock slits are TINY. I'll try to take a measurement when I can get time off to work on them.
Old Oct 19, 2009 | 01:01 AM
  #69
ASH8's Avatar
Super Moderator
It is 55% according to maker, better than the 15% the original factory vents.
HUH?
Anything has to be better than the OEM for Hot Summer Weather..
Old Oct 19, 2009 | 01:15 AM
  #70
ASH8's Avatar
Super Moderator
Ideally you can have an Open Duct, But what about small stones,sticks and rocks from wheels, it would damage and destroy cooler fins in very little time.
"destructive to airflow", possibly if mesh is placed on top (ON) coolers themselves..like at the front, at the rear they are 3 inches (gap) away from coolers.
The openings I cut are larger than the original OEM slits, more to the size of the actual cooler, so yes ideally no liner or covering would be the best, but as I said what will protect coolers.
This is the best and only compromise.
When the single cooler (FC RX-7 and earlier rotaries) was under the radiator there were no restrictions for exit air and engine fan assisted, BUT, the coolers were smaller.
Hope to have some temp numbers soon, weather has been very cool here so these are still not on.
Old Oct 19, 2009 | 01:32 AM
  #71
Flashwing's Avatar
3-wheeler
Well I've been missing my whole lower mud guard for over a year now and that cooler works just fine.
Old Oct 19, 2009 | 01:46 AM
  #72
ASH8's Avatar
Super Moderator
Well really, did I say the cooler would not work fine with out it?
The "Mud Guard" is there for a reason
Old Oct 19, 2009 | 01:50 AM
  #73
Flashwing's Avatar
3-wheeler
I agree! In this case it's job was to be fodder for the shredded tire I hit coming back from Sevenstock last year.
Old Oct 19, 2009 | 01:56 AM
  #74
ASH8's Avatar
Super Moderator
Got ya!
Old Oct 19, 2009 | 08:04 AM
  #75
JinDesu's Avatar
Thanks for the info Ash. I am planning on doing your original modification (cutting the slits wider), especially because I have difficulty finding good wire mesh around me.
