The newest 100% bolt on Greddy Hybrid turbocharger!
Old Mar 8, 2009 | 12:34 AM
  #51
05rex8's Avatar
sold the 8... :(
wow I was a few weeks too late on this deal...I got mine done from fluid. oh well, next time
Old Mar 8, 2009 | 12:35 AM
  #52
hakuna matata!
So 300whp is optimistically attainable on an otherwise stock Greddy install? I figure I'd want to upgrade injectors and ignition first though.
Old Mar 8, 2009 | 01:27 AM
  #53
Kane's Avatar
300-310 is all you get with the injectors we have stock.
And ignition is always an issue.
Old Mar 8, 2009 | 01:28 AM
  #54
blackenedwings's Avatar
Life begins @ 30 psi
From what I understand stock injectors will go near 300 whp, but anything around that range and higher would need upgraded injectors. Upgraded ignition won't hurt, but is not a requirement, although new plugs are definitely called for.
Old Mar 8, 2009 | 10:37 PM
  #55
baysj's Avatar
Lol, im only getting 240 out of my coils
Help is on the way though
Old Mar 8, 2009 | 10:45 PM
  #56
Originally Posted by paulmasoner
the ignition runs into spark blowout around 330whp under optimum conditions. if you are just a tad on the safe side(rich afr) it comes sooner than that. the coils are barely adequate for stock application imo.
what kane said about injectors, though i'd never want to run any injectors at that high duty cycle i'd upgrade injectors myself before i got much over 250-275
Dear god your sig is physically painful to look at. I hope you sell it so I can stop going into seizures from looking at it.
Old Mar 8, 2009 | 11:05 PM
  #57
Brettus's Avatar
Boosted Kiwi
more like 300 on the stock coils here and all good - i do have very good leads but not sure if that helps much ....
Old Mar 9, 2009 | 03:21 AM
  #58
turborx8's Avatar
Boost 4 Life
I just recently bought a used greddy turbo because mine died. I swapped it out so that I would have a 2nd turbo and avoid the downtime while having it rebuilt every 20,000miles.
I am VERY interested in your upgraded turbo because its only a matter of time before my other one dies also.
I upgraded the wastegate actuator to this: http://www.atpturbo.com/Merchant2/me...gory_Code=WGT1
It works perfectly but my mechanic had to fabricate a custom bracket to make it work and it rattles against something metal at idle. There is very little room to upgrade the wastegate. He said the arm would need to be shorter to have good clearance.
I guess my blown turbo will be sent out to you for the “special” rebuild.
Old Mar 9, 2009 | 04:26 PM
  #59
Mr.&Mrs.Magic's Avatar
Bryan-oh snap i'm in and your my new hero your also hella close. well thats is provied paul has sold his system before I can get to it.
subscribed
Old Mar 9, 2009 | 04:34 PM
  #60
arghx7's Avatar
Originally Posted by Bryan@BNR
That is the 60 trim not the 60-1. Huge difference.
I just caught this. The actual measurements of the T04E 60 trim and 60-1 compressor wheels are very similar, and I have run a 60-1 on my own car (T04S). What makes them perform so differently? I know the compressor maps have different shapes but the 60-1 compressor map floating around does not have efficiency listed in % values, so how do we know it's that much different? Isn't the 60-1 a 6 blade wheel and the T04E 60 trim a 7 blade wheel?
Old Mar 9, 2009 | 05:18 PM
  #61
Bryan@BNR's Avatar
Turbocharger Guru
Im no hero. I just do what I do.
The 60 trim and 60-1 have 2 totally different maps. 60-1 flows 8-10 lb/min more than the 60 trim. .108 lb/min equals 1 HP. So Divide 10 lb/min by .108. A difference of 92 HP. Now the 60 trim spools much faster than the 60-1 but who cares about 300-500 RPM spool difference.
Remember a wankel takes 20% more air flow to generate a HP. So in rotary terms .1296 lb/min equals 1 hp. I love comfusing people hahaha.
Bryan@BNR
Old Mar 9, 2009 | 05:25 PM
  #62
umm so which ones better for taking out the competion or which one ultimately makes for a faster car? Also can I ask for a price and a time line for finished product.
Old Mar 9, 2009 | 05:34 PM
  #63
Grouch's Avatar
After seeing this, I wish I didn't sell you my old turbo
Old Mar 9, 2009 | 05:54 PM
  #64
Bryan@BNR's Avatar
Turbocharger Guru
The 60-1 is the much better wheel.
I can not discuss pricing since I am not a vendor. This thread is information about the product only.
Bryan@BNR
Old Mar 9, 2009 | 06:12 PM
  #65
figued as much. I'll keep lurking for a bit and get in contact when the time is right.
Old Mar 9, 2009 | 09:14 PM
  #66
BDC's Avatar
BDC
BDC Motorsports
+1 for Bryan at BNR.
B
Old Mar 12, 2009 | 06:25 PM
  #67
Jason's Avatar
RX7store.net
If someone wants pricing on the BNR turbo upgrade send me a PM. I deal with Bryan a lot and he is a good guy.
Old Mar 12, 2009 | 07:38 PM
  #68
excellent Jason good to know!
Old Mar 12, 2009 | 07:47 PM
  #69
Nemesis8's Avatar
Bigus Rotus
Water cooled - man this coupled with Mazmart's pump and thermostat, and the BHR radiator would be 'da bomb.
Old Mar 12, 2009 | 07:48 PM
  #70
Kane's Avatar
Water cooled.... and a bird told me it might be the least expensive option for the Greddy right now....
Old Mar 12, 2009 | 08:33 PM
  #71
^ i see we have the same birds in TN you have in HI. Pretty little things arent they.
Can I get the complete GReddy kit thru you guys or will I need to get the turbo else where.
Old Mar 12, 2009 | 10:37 PM
  #72
Race Roots's Avatar
Former Sponsor
You could get the complete Greddy Turbo kit from us, I don't think $3,400 shipped is going to get any better
Old Mar 12, 2009 | 10:45 PM
  #73
Bryan@BNR's Avatar
Turbocharger Guru
Whats up Jason.
I think what you need to do is offer the greddy kit on the shelf with my additions upgraded injectors and a good base tune on one of those Cobb plug in units. Just something conservative. It would be the best thing just to prevent premature turbo failure, make way more power, and really make that kit more desireable to the public.
Jason does good business with me and I have never had a problem with him not paying or not communicating. He has marketed my stuff since I opened back in 2001.
Bryan@BNR
Old Mar 12, 2009 | 10:54 PM
  #74
Race Roots's Avatar
Former Sponsor
unless you throw 600 more at it and get a ceramic coated manifold, PC'd upper pipes, the hard to find discontinued type S BOV, and 3071R that will spool as good as anything else you'll fit down there, and support more flow than anything else to fit there
Lol, I cannot believe no one has bought that yet....
Old Mar 12, 2009 | 10:56 PM
  #75
StealthTL's Avatar
Do you have a turbo for sale, Paul?
S
