Dyno Results Compilation
Old Sep 19, 2009 | 03:48 PM
  #651
Brettus's Avatar
Boosted Kiwi
Originally Posted by Shijin-Kun
Anything in specific I should do? And what exactly should I be listening for?
you don't need to start the engine . Just turn the ignition to on for a few seconds then turn it off again . You should hear two noises the second noise is approx. 3 seconds after you turn off the ignition . It sounds like a dc motor going one way then the other (cuz that is what it is )
If that checks out you need to establish if they actually open when you are driving - I'm not sure how you would do that . Anyone else ?
Old Sep 19, 2009 | 05:07 PM
  #652
shaunv74's Avatar
Power!!
Originally Posted by Brettus
Don't think it is a clogged cat.
It's easy enough to check. unbolt the cat. and physically look inside to see if it's melted or not. Then he'll know for sure.
Old Sep 19, 2009 | 05:13 PM
  #653
Brettus's Avatar
Boosted Kiwi
I just realised how you can check it . Do a dyno and see if power drops off just after the aux. port is supposed to open .
Old Sep 19, 2009 | 05:24 PM
  #654
Hymee's Avatar
Race Steward
AU
Old Sep 19, 2009 | 07:27 PM
  #655
Shijin-Kun's Avatar
Rotary Power!
I checked that and i do hear the two noises. Ok so if my aux port isnt opening then how do i get it fixed? Also if im getting 180 with a messed up aux port then dang.
Old Sep 19, 2009 | 07:45 PM
  #656
Brettus's Avatar
Boosted Kiwi
Well - we have not 100% established that it is your aux port but it certainly looks that way to me .
IDK how you could be sure without taking the lower intake manifold off . Can you log AFRS ? That might help .
Old Sep 19, 2009 | 07:49 PM
  #657
Jon316G's Avatar
Grasshopper
IDK how you could be sure without taking the lower intake manifold off.
You can always remove the APV motor and test it with 12VDC.
Then move the gear on the rear of the LIM and if it rotates smoothly, the valves aren't stuck.
Old Sep 21, 2009 | 03:06 PM
  #658
Shijin-Kun's Avatar
Rotary Power!
Aux port not opening put aside are the number ok for only having an AEM cold air.
Old Sep 21, 2009 | 03:39 PM
  #659
Brettus's Avatar
Boosted Kiwi
/\ yeah -great numbers up until the power drops off .
Old Sep 21, 2009 | 03:41 PM
  #660
Shijin-Kun's Avatar
Rotary Power!
Maybe my reny thinks its a piston engine? Lol
Heres the scanned version of my graph
Old Sep 22, 2009 | 12:59 AM
  #661
shazy's Avatar
... Be happy and leave.
181whp. DAng you have a real healthy engine. The lucky ones so far. Check the cat you never know.
Imagine you made 190WHP! That would be crazy!
Old Sep 30, 2009 | 08:17 AM
  #662
toolboy's Avatar
here's my dyno sheet from Poland
2006 model, aprox. 6500miles, AEM CAI, RB Rev8 Catback, 4th gear, dsc off
its kinda hard to compare numbers on different dynos, and it does't really matter to me as long as the car is running fine (and I think it is atm, after a few track days this year)
orange is whp, red bhp
this was done on a dyno used for tuning 4wd cars
LINK
does this power curve look ok to you ?
thanks for your imput
Lukas
Old Oct 11, 2009 | 10:36 PM
  #663
trandi47's Avatar
I think the Bosch dyno in Spain uses SAE... maikel can confirm this.
Old Oct 25, 2009 | 12:29 AM
  #664
Originally Posted by kennyfrc1
I am amazed that at 100CPI you dont get a CEL
Not sure why, it was proven back in early 2006 ...
Somebody wasn't paying attention.
Old Nov 16, 2009 | 08:50 PM
  #665
Nemesis GP's Avatar
Hey All
Iv noticed from the dyno sheets that some cars make their peak hp at rpms(6k-7k) and some at higher rpms(8k-9k).
What would contribute to making peak HP at different rpms?
Weak ignition/plugs/intake?
Obviously if one can make max HP at say 6k then surely the engine is capable of more seeing as the 8 is rated to make max HP at around 8200/8500 RPM? Which would imply that the there certain issues causing the motor to only make peak at 6k?
Just trying to identify what sort of issues may cause this.
Cheers
Old Nov 16, 2009 | 09:34 PM
  #666
shaunv74's Avatar
Power!!
Originally Posted by Nemesis GP
Hey All
Cheers
I think not reading the rest of the posts in this thread causes horsepower loss at high rpm.
Seriously that's what the whole conversation is about. Typical reasons are: weak ignition, clogged cat, or APV not opening. The different problems have different symptoms to distinguish themselves. The power peak for a stock engine is roughly at 8Krpm.
Old Nov 20, 2009 | 05:44 PM
  #667
MrVei's Avatar
tuner boy
this is my one pull, stock learned tune, had a vac leak cus after i reset the ecu the car wouldnt stay running lol, out it the next day but havent been back yet. dyno wouldnt go past 8900rpms so yeah.. 172hp 125tq
Attached Thumbnails Dyno Results Compilation-user52463_pic12412_1256599123.jpg
Old Nov 21, 2009 | 05:18 PM
  #668
Shijin-Kun's Avatar
Rotary Power!
Alright im back with a new dyno sheet.
Mods:
AEM cold air intake
Cobb AP: MM base tune
I also fixed my APV not opening issue. The numbers on the sheet are small but it says 189 whp.
Old Nov 21, 2009 | 05:53 PM
  #669
Brettus's Avatar
Boosted Kiwi
/\ that is more like it - good dyno .
what was the problem with the APVs
Old Nov 21, 2009 | 06:42 PM
  #670
Shijin-Kun's Avatar
Rotary Power!
don't know i just hooked it up to a 12v adapter like Jon told me and i guess that got it unstuck.
Old Dec 5, 2009 | 02:02 AM
  #671
Shijin-Kun's Avatar
Rotary Power!
what year, at or mt, and how many miles on the odometer. Do you have the dyno sheet by any chance?
Old Dec 5, 2009 | 04:39 AM
  #672
Nemesis GP's Avatar
Sorry Shijin I deleted my post-I did PM you and Jon though. Thanks
Old Apr 1, 2010 | 08:18 AM
  #673
speedy33's Avatar
I was at the dyno today..
i have done 3 runs and the best result is, 235HP peak (corrected) and 214NM.
i wondering about the powertrain loss of 85HP! so i have only 150HP on the wheels
That is ~40% loss!
back then as the car was new and completly stock i had 210HP, that was about 170HP on the wheels.
that was ~19% powertrain loss.
i donīt know why i have so much loss to the powertrain now? because the car feels good and i donīt feel a loss of power..
Red = BHP
Blue = WHP
Orange = NM
Old Apr 1, 2010 | 08:59 AM
  #674
MazdaManiac's Avatar
First of all, your ratings are in pferdestärke, not horsepower.
Your actual output was 146 HP.
The "corrected" number you state is an estimate of crank power, and it is obviously way off.
None of the Euro models actually made 232 HP at the crank.
You are also running excessively rich over 5000 RPM.
Old Apr 1, 2010 | 09:23 AM
  #675
speedy33's Avatar
Yes iīm sorry about the PS - HP calculation.
Iīm only wondering about the big powertrain loss of 40%
At my last dyno 5years ago i had only 19% loss..
besides now i have a lightweight flywheel and pulleys etc..
i donīt know why it is that rich at higher rpmīs. the PCM is stock with no modifications.
